02-09-2019, 02:21 PM | #1 |
588
Rep 467
Sterckenn upper splitter fitment
I just installed these sterckenn pieces. There are beautifully constructed but don’t seem to fit very well. Both sides have the same gap so it’s consistent. Anyone have the same issue?
02-10-2019, 06:39 PM | #6 |
588
Rep 467
02-10-2019, 07:32 PM | #7 |
2163
Rep 4,107
02-11-2019, 10:12 AM | #8 |
BimmerPost Supporting Vendor
2871
Rep 11,374
Based on the photo the bumper insert was not installed in the correct position. I recommend having a body shop remove it so that it does not crack. Then they can adjust it.
02-11-2019, 11:34 AM | #9 | ||
smoke if ya got 'em
1070
Rep 2,179
02-12-2019, 02:34 PM | #12 |
smoke if ya got 'em
1070
Rep 2,179
Mine has small gap on each side. It's possible there's variation in the sets since these are carbon. It's fitted all the way to the back underneath. Pressing around, it seems the outer bottom sides are not totally stuck on.
02-12-2019, 06:55 PM | #13 |
448
Rep 1,846
I just got a set of the same from iND and will be here next week. I will see if I have any issues with fitment. Super bummer if the fitment is not spot on considering how much they are
02-13-2019, 11:58 AM | #14 | |
49
Rep 149
I had no issues with my parts whatsoever. Fitment was spot on without any gaps. By looking at your picture it seems you positioned them to close to the edge. Did you use a shop for an install ? I was trying to do it by myself but gave up on that since 3M tape ain't easy to remove and you have only one chance to do it. That's how mine are mounted: |
02-13-2019, 12:38 PM | #15 |
smoke if ya got 'em
1070
Rep 2,179
Then they made the part too long (left to right). So you have to position from the inside first to not get a gap, but then how would you know if the tape will stick to the bumper on the outer edge? I positioned from outside to the inside.
I have pics, will post later. |
02-13-2019, 12:40 PM | #16 | |
smoke if ya got 'em
1070
Rep 2,179
02-13-2019, 05:27 PM | #19 |
83
Rep 316
He helped me out with the info, so here is the link:
https://www.ebay.com/itm/REAL-Carbon...53.m2763.l2649 |
02-14-2019, 03:04 PM | #20 |
Master of my own domain!!
153
Rep 1,049
They need to be moved more out toward the edges of the outside of the car. This should decrease that gap. I have them on my car and have to do a few placements. Heat up and slowly remove or take to a body shop.
02-16-2019, 12:23 PM | #22 |
444
Rep 1,061
Yes, the gap can definitely be minimized if you move around splitter. I still have the splitters and used to have the full sterckenn carbon package, they definitely make one of the best quality aftermarket carbon parts you can buy. Feel free to check my IG for pictures.
https://www.instagram.com/yasmpower/
2015 F82 YMB M4 (Feb 28th ED, re-deliveried on Apr 18th) |My 2015 YMB M4 ED Journal 2008 E92 SSII M3 Coupe (Sold) | My long gone 2008 E92 SSII M3 2002 E39 SG 530i (Gone) |
