02-01-2019, 09:15 AM | #1 |
202
Rep 193
Vehicle Speed Sensor A Circuit?
Anyone know if "A Circuit" is referring to specifically one of the 4 speed sensors? Or is it something else entirely?
Cannot seem to find anything anywhere to help pinpoint where this fault code (P0500) is coming from.. |
02-01-2019, 01:07 PM | #2 |
111
Rep 234
get yourself a foxwell nt410 or something that can monitor the 4 wheel speeds. View the real time speed readings and youll see which sensor is at fault.
I have had both of my left wheel speed sensors go bad as have others, more than likely you have a bad speed sensor.. |
02-01-2019, 01:54 PM | #3 | |
202
Rep 193
02-02-2019, 11:50 AM | #5 |
8912
Rep 4,107
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
02-06-2019, 09:16 PM | #6 | |
202
Rep 193
Update: the more specific BMW code is 2B13, and apparently came from the right rear speed sensor. Replaced that, cleared the code, code is back again. Any thoughts? Something else that could cause the sensor to be unable to get a reading? |
05-11-2019, 10:46 AM | #8 |
14
Rep 18
05-13-2019, 10:40 AM | #10 |
202
Rep 193
Pretty much. All sensors and wiring checked out at the shop, eventually determined it was a stored code that was not fully clearing from the system. Full reset to factory settings solved it.
