BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Cosmetic/Visual (Exterior + Interior) Modifications
European Auto Source (EAS)
      01-07-2019, 05:30 PM   #1
KicknShift
14
Drives: e92 m3
Low beam malfunction. Water damage.
Decided to swap headlight bulbs and f’d up hard and didn’t tighten one of the screws around the cover enough apparently. I went for couple weeks no problems then a storm came and I drove for an hour or two and the next day got an adaptive headlight low beam error code. Now the passenger side bulb fails to light up. Tried swapping bulbs and didn’t work. I noticed condensation inside the headlight and when I opened the cover to swap the bulb a few drops of water had fallen out.
Not sure if maybe the ballast is the next attempt to fix or if the headlight itself is damaged and needs to be replaced. Halo’s still work fine. Any ideas?
      01-07-2019, 05:47 PM   #2
BayE30
1341
Drives: 2011.75 E90 M3 ZCP
just replace the xenon ballast, its a $260 part. OEM is "Automotive Lighting".
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V]
      01-08-2019, 07:12 AM   #3
m235boy
54
Drives: M235
There's also the adaptive module next to the ballast I think.. Check both if they're wet.
      01-09-2019, 06:58 PM   #4
KicknShift
14
Drives: e92 m3
Thanks guys. Decided since I have to remove the headlight I might as well kill two birds and install some dtm angel eyes from Bavgruppe while I have the bumper off. Blessing in disguise.
m3post
