01-03-2019, 04:59 PM | #1 |
Rep 92
OEM Muffler mod w/ DPs to retain stock noise level w/ exhaust valve closed
I’m new to the F80 M3, but have had previous M3s and other BMWs…here’s some background on what I’m trying to accomplish:
1) I want a quiet exhaust when the valves are closed…but louder when it’s open. A) Closed: Quiet like OEM w/ exhaust valves closed. B) Open: I like the DP w/ OEM exhaust sounds/level. 2) I’m getting a tune to delete the Cold Start (our bedroom is below the garage, and I leave for work around 5:30am…the initial start-up wakes up my wife, even when I quickly put it into gear and drive away). 3) Since I’m getting a tune, I figure I’d also get DPs so that I can better utilize the new tune…hard to resist, plus I know I’ll want the extra power later on; I also wouldn’t mind a louder exhaust when the valves are open. Proposal: My thought is to do the opposite of what the E90/92 M3’s did w/ the OEM muffler…cut open the F80 muffler, and replace some of the piped sections w/ perforated holes to quiet it down further Does anyone have pictures of what the internals look like…I have the flow diagram (attached), but I’ve yet to see a picture of a real muffler? *I know some people think modifying the OEM muffler is “poor form”, or unbecoming of a “M3”…I don’t really care. I just want something that sounds good and does what I need; if there’s another aftermarket exhaust that does what I need, I’d be interested…but so far all I could find are mufflers that are louder than OEM. E90/92 OEM muffler mod (pic 1): Cut open the muffler, and replace the perforated sections (those covered w/ steel wool, see attached pic) with straight section. The steel wool is wrapped around the perforated sections, then there’s insulation in the empty volume that help absorb the exhaust noise. F80 Muffler: Pic 2 F80 OEM muffler internal flow paths: Pic 3 Proposed mod to muffler (pic 4): Add 4 sections of perforated tubing in the central sections. I didn’t want to add anything in the outer sections, as it appears there’s some unique noise tuning that may be going on (Helmholtz chamber?). constructive feedback? any personal experiences doing something similar?
Current: 2016 F80 M3 & '66 GT40 kit
Previous cars: 2011 E92 6MT ZCP, 2012 135 DCT, lotus 7 turbo rep, 2005 350z, 1993/1994/1999/2016 Miata, 1998 Mazda RX-7 (FD), 2008 VW GTI, 1995 BMW 325is, 1995 Mazda RX-7 (FC Turbo II) Previous bikes: 2011 Ducati 848, 2007 Ducati 748s, 1999 Honda CBR600, 1988 GSXR750 |
01-03-2019, 07:27 PM | #3 |
5001
Rep 6,864
I don't think you will need all that. Just get the tune with cold start removed and you will be amazed at how much quieter it is. Also, I would suggest having the tuner force your exhaust valve closed during startup to mitigate the "startup roar" that most tunes come with.
01-04-2019, 12:03 AM | #4 | |
Rep 92
01-04-2019, 05:44 AM | #5 |
2516
Rep 2,079
Reading this post I thought I was reading my own message.
I also wanted a car that’s quiet in the morning when I leave at 5:30 AM and my wife sleeps in the bedroom above the garage. I also wanted a valve controlled exhaust that’s quiet with flaps closed and loud with them open. Here’s what I did: - cold start delete (and roar elimination) - this allows me now to start the car in the AM and even let it idle for a minute or two With that setup I was able to even try aftermarket exhausts. I had the AA full Signsture exhaust, which was junk. I had just the midpipe and I also had a Dinan muffler. With each setup the cold start was super quiet but you had some loudness with valves open. That loudness was too much for me after a while and didn’t make me like my exhaust sound more. Now I run just the AA midpipe connected to my ZCP OEM rear Muffler. I’m very happy with it. I also accepted the fact that my car will never sound the way I want it to sound - it’s not sexy v8. The exhaust sound is actually the thing I hate about my car the most. |
materialdistractions135.50 |
01-04-2019, 09:05 AM | #6 | |
Rep 92
01-04-2019, 12:44 PM | #7 | |
136
Rep 498
02-02-2019, 09:17 PM | #8 |
Rep 92
Follow up:
I finally installed DPs & the BPM Tune (w/ cold start delete)... 1) w/ exhaust flaps cold: It's quiet...I'd prefer it to be slightly quieter, but it's knocked down enough that chasing 1-3 dB isn't worth it. 2) w/ exhaust flaps open: love it... BPM tune: wow...super easy, straight forward, and the power is nuts. it's low 40's & rainy here...even on the freeway the tires won't hold. boost builds much faster & the turbo spool noise is more evident. overall I'm loving it, thanks for all the help!
02-03-2019, 10:19 AM | #9 | |
55
Rep 193
