12-30-2018, 09:36 PM | #1 |
843
Rep 1,497
Weird Tire Wear
Was working on the exhaust today, and noticed my passenger side rear tire is wearing badly on the inside. Almost looked as if it was rubbing on something although I saw nothing that stood out. Going to get it by buddies alignment shop this week, but was curious if anyone else has seen wear like this? Wear on the inside isn't uncommon but in my case it's only the passenger side rear tire. BTW, stock 19" wheels on stock Pirelli run flats. X5 mileage is right around 63K.
12-30-2018, 09:45 PM | #2 |
Retired Curmudgeon
2985
Rep 4,047
Two things cause inside tire wear; camber and toe. My guess is one or both are out of spec.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
12-31-2018, 11:44 AM | #3 |
Mmmmm…
1151
Rep 2,426
Drives: F15
It's normal for the rears to have slightly more wear on the inside, but not on one-side only.
2015 BMW X5 xDrive50i
BMW CCA 509766 |
M302_imola842.50 |
12-31-2018, 11:57 AM | #4 |
843
Rep 1,497
01-04-2019, 10:35 AM | #5 |
843
Rep 1,497
Mechanic says that alignment is dead on and he chalks the abnormal wear to lack of rotation. I should have been more diligent in rotating the tires. Didn't think it was a huge deal being all wheel drive but I was wrong. Plus I've only owned it about 7K miles and I don't previous owner rotated them. Oh well, need to find a new/used tire now as that tire is on it's last leg. Hit me up if you have 1 Pirelli scorpion 255/50/R19 fun flat lying around. I'll post in classifieds as well.
01-04-2019, 10:14 PM | #6 | |
83
Rep 207
Curious to know how long staggered setups last? My shop said to plan on half life on the rears when I go staggered. |
01-04-2019, 10:27 PM | #7 | |
843
Rep 1,497
I've wondered the same about the staggered setup. Guess I'll find out soon enough. My E46 M3 had a staggered setup and the rears didn't last long of course it was rear wheel drive. Looking at the Atturo AZ850 tires once I go staggered. At they're fairly cheap if they don't last long. |
01-06-2019, 12:47 AM | #8 |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
Just replaced my tires and I was surprised to see I had very even wear in both rears. The fronts are much more tread over all but the insides were much more worn down due to camber. But both sides were even to the other. Got 25k out of my Dueller RFT. If I would've "rotated" the fronts side to side I bet they would have gone another 10k. Rears were maybe 1-3k from being getting bald spots.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wife’s now) |
BimmerTy192.50 M302_imola842.50 |
07-03-2019, 10:33 PM | #9 |
Rep 4
Hi everyone - seemed to be the right place to ask this question.
So today our right rear tire failed on our 2015 35i. It has 38k miles, Pirelli Scorpion run flats. Seems like the same kind of damage being described here. So I'm guessing this is typical? The tire place said they see this a lot because of what they called a more "aggressive negative camber" on the X5. I can understand why that would cause this problem, but I have a hard time believing it's standard. Thoughts? BTW it's a CPO we got at 30k miles, so we are not the original owners. I don't have the picture where I can upload via url, but it's literally a 8" tear right at place where the tread meets the sidewall. Plus, the inside of the tire is a LOT more worn than the outside. The left rear was on it's way, but hadn't failed yet. |
07-04-2019, 07:19 AM | #11 |
1226
Rep 1,915
07-04-2019, 08:12 AM | #12 |
11574
Rep 11,136
On my E70 X5, I was washing the car one day and noticed the threads separating on the inside of the rears. The outside looked just fine. With the camber of these tires, it’s important to keep an eye on these things.
07-04-2019, 08:44 AM | #13 |
Rep 4
I was off earlier - we got this as a CPO at 20K, so I'm not sure what happened before that. It had the standard 30k service and tires were rotated then. I didn't have any idea about this issue so didn't think to do it more frequently. If I had to guess they were only rotated at the 10k service intervals, so three times.
We had them replaced at a local Les Schwab where we get free tire rotations - you bet we'll be in there every 5K from now on. Or is there recommended interval that helps prolong tire life? Also the tire guy recommended maybe going a bit over standard tire pressure too - anyone try that? Is the issue just on the rear tires, or do all four have a camber adjustment? |
07-04-2019, 10:54 AM | #14 |
Mmmmm…
1151
Rep 2,426
Drives: F15
I never rotate my tires. I do however go higher on tire pressures. I use the over 100 mph tire pressure specs.
BMW CCA 509766 |
07-04-2019, 03:32 PM | #15 |
Well versed in the care and feeding of BMWs
261
Rep 733
I haven’t rotated mine, either. I run the label pressures, 36 & 44, and keep a close eye on them. When I replaced the Pirelli RFTs at 50500 miles they still had another 5k left and were evenly worn across all 4 tires.
Might be a good idea to confirm that your servicing dealer is rotating your wheels. Mine doesn’t and they aren’t the only ones. And, as always, YMMV definitely applies.
B&O, parking assistant, executive package, 3rd row seats and the manual rear shades are the ONLY items we didn't order. Having everything else makes our F15d a NICE ride.
05-04-2022, 07:14 PM | #16 |
Rep 10
Tire wear & rotation
G05 with 15k miles with excessive wear on both front outside edges. Obvious alignment issue. Shop wouldn’t do an alignment because they want the tires replaced first.
The shop manager (The Senior Guy) explained that this type of wear was typical of x5 and is worsened by the roll of Run Flat tires. And, bmw never ( not ever ) rotates x5 tires. He was clear. The wear pattern is very different front to back. Like a FWD, one can replace fronts and skip the rears once. But (he said) never rotate to even out the wear. And, all Run Flat tires will be discontinued within 2 years. Ecologically speaking they are a huge problem; so OUT they go. Better get em if you want them. There are some brands already on close out (since I now have to fire shop.) I think lots of you will view this BMW service “position” as a BS story. I’m tempted too. I do not NOT want the next set to end up with 7/8 great tread and 1/8 worn to danger. I’m buying the new 3MPSF Mich set. We’re avid ski drivers. Would enjoy your opinions. |
05-06-2022, 07:36 AM | #17 | |
843
Rep 1,497
05-07-2022, 09:37 AM | #18 | |
11574
Rep 11,136
M302_imola842.50 |
05-11-2022, 09:22 AM | #20 |
400
Rep 648
I have found alignment shops are not always doing a good job, people relying on their alignment machine over the naked eye. Just last weekend I could see my car wasn't right, but alignment shop claimed it was done. In their defense, they had not been exposed to H&R VTF and SPC camber arms before. So I'm heading back again this week for a redo.
Regardless, if alignment is done right and you are not constantly driving with lots of weight on one side of the vehicle, rotating tires or not should not make one tire wear down differently than the other side. If you have a square set up and aligned correctly, the only way you should be able to get uneven wear, is if a shop doesn't bother marking the tires and puts back tires in the wrong place. I.e switches front and back on one side only. (Side note; I'm not sure about all the sizes of OEM wheels, but I believe for the F15's, the 19" versions are the only ones that are not staggered. AFAIK vehicles with OEM 20", or 21" wheels are all staggered set ups, and can't be rotated. But I could be wrong.) I hope your new alignment takes care of issue. I'd recommend marking your tires also, so you know they were put back on the vehicle in the right place anytime you have work done. |
