BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
EXXEL Distributions
      07-14-2008, 02:42 PM   #1
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
is your oil pan drain plug exposed? like this?
I was expecting to see the pan have some cover over this area. or did the dealer leave them off?
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      07-14-2008, 03:31 PM   #2
MDCTFTW
123
Drives: E92 DCT
I think mine is exposed.
MDCT ... so you can drive and eat a hamburger at the same time.
      07-14-2008, 03:42 PM   #3
gadget
gadget's Avatar
108
Drives: 09 e92///M SSII DCT
I'm not the most mechanically included, what am I looking for in the Pic?
      07-14-2008, 07:52 PM   #4
bmwwr250f
bmwwr250f's Avatar
Drives: 08 m3
I have yet to see any of the M3s come with a cover over the oil drain plug. I know my 08 doesn't and i have looked at 10 other 08s that had no cover either.
      07-14-2008, 07:59 PM   #5
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
Underneath the car. Car on a lift. Front of the car is at the top of the pic.
Actually, he is asking if there should be more cover, like a panel or something, under the engine, around the oil drain.
      07-14-2008, 09:55 PM   #6
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
Originally Posted by Laszlo View Post
Seems like a panel is missing... the e46 was completely covered... surprised. But maybe it's just not needed to save weight and money.
Yep, E46 had a plastic plug there. Mine is open like the others.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      07-14-2008, 09:58 PM   #7
sayemthree
sayemthree's Avatar
597
i am referring to the small circle opening above and larger ovalish opening below the black jack point. they are both open and expose the plugs. the e46 and S4 Ihad were totally covered.
      07-14-2008, 09:59 PM   #8
sayemthree
sayemthree's Avatar
597
thanks greg- is the large opening the oil drain plug? whats the small opening plug for?
Greg do you have an exploded parts view on the air filter intake and its related parts, snorkel, silencer etc?
      07-14-2008, 10:19 PM   #9
GregW / Oregon
Commander-In-Chief
2122
Under engine panel openings
What I won't do for you guys! Both openings in the thrust plate expose drain plugs--front sump and rear. The rear also exposes the oil sender connection. The drain plugs are very small with recessed hex wrench openings.
"The E92 M3, just like the E46 M3, is equipped with a reinforcement plate, known as the thrust panel, made from aluminium alloy. The thrust panel primarily increases the torsional strength while also acting as a lower motor cover and oil pan protection. The thrust panel is fitted to the axle carrier with six bolts from below, and has two openings for changing the oil."
      07-14-2008, 10:33 PM   #10
skierman64
skierman64's Avatar
127
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
Greg, that was above and beyond the call of duty.
I vote you Forum Member of the Month. Thanks.
Is that a torx oil plug?
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      07-14-2008, 10:35 PM   #11
GregW / Oregon
Commander-In-Chief
2122
Of course.
      07-15-2008, 02:50 AM   #12
swamp2
swamp2's Avatar
611
Drives: E92 M3
Nope, just regular hex.
      07-15-2008, 10:28 AM   #13
sayemthree
sayemthree's Avatar
597
awesome Greg - thanks!
so for DIY oil change you have to drain both?
      07-15-2008, 11:33 AM   #14
MDCTFTW
123
Drives: E92 DCT
The tech did both when I took my car in at 1200.
      07-15-2008, 11:36 AM   #15
GregW / Oregon
Commander-In-Chief
2122
2 oil drains
Yes, you obviously need to do both, since there are two low points. I'm not sure how the S54 got away with just one.
      07-15-2008, 02:49 PM   #16
sayemthree
sayemthree's Avatar
597
looks like water in at point 1 would drain out at point 3?
      07-15-2008, 02:50 PM   #17
sayemthree
sayemthree's Avatar
597
4 must be the "silencer"?
      07-15-2008, 02:55 PM   #18
sayemthree
sayemthree's Avatar
597
NICE! all three inlets take in "cold" air.
      07-15-2008, 03:46 PM   #19
GregW / Oregon
Commander-In-Chief
2122
Yes, and there are also drain flaps directly under the hood vent.
m3post
