12-09-2018, 09:09 AM | #1 |
Rep 8
E92 M3 Measured Dimensions incl Lift Points
I am awaiting my new Dannmar M-6 lift. To make sure I get the posts in the right place (hoping not to drill two sets of mounting holes), I am laying out all the lift points and dimensions of all the cars I work on to make sure they fit in the garage while on the lift and the lift arms can hit all the lift points.
To that end, I did a layout for my (well, OK, my wife's) M3 and attached it to this post. All the measurements were done with plumb bobs, squares and straight edges so they should be take as approximate, as this is good enough for my needs. The center is just the dimensional center of the lift points and should not be considered the CoG. There are both English and SI (Metric, mm) dimensions. Anyway, thought I would share.
==> 2012 M3, Space Gray, Comp Pkg, Manual, PS4S tires, European Delivery
12-09-2018, 01:48 PM | #3 |
Rep 8
Bizarre... here are images of the PDF..
http://bocafallsweather.com/images/M3/m3m.png http://bocafallsweather.com/images/M3/m3e.png
DrFerry6731.50 |
