12-06-2018, 04:11 AM | #1 |
494
Rep 240
Alternator issue possible
I'm getting the 4 light cluster display that denotes an alternator issue, codes were read and there are voltage spikes. The question is this only happens when the outside temp is in the 40's and below and it's intermittent for about 3-5 minutes (limp mode for about 2 seconds each flash of the lights). After the car warms up it doesn't happen again. Is this something anyone else has seen or had happen before?
12-18-2018, 10:32 PM | #4 |
115
Rep 232
Just went through something similar... I will be replacing the alternator next month. I posted a thread on it not too long ago here
12-19-2018, 02:51 AM | #5 |
#buildnotbought
10855
Rep 4,893
Without the codes one cant say anything sensible about this.
Describe the voltage spikes and how you've measured these.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
