12-05-2018, 08:01 PM | #1 |
12
Rep 88
Supercharged m3 question
Good evening guys! I need some help here!
Ess m3 VT2 595 I am experiencing some issues. When I put down my foot hard, the car hesitated to accelerate. I full throttled my car, but I didn't feel the power, at some point around 6K rpm I suddenly feel the power. I don't know why but it feels like the clutch is slipping? But there is no warning on clutch overheat or something. This happened right after I fix a exhaust leak before the oxygen sensor, my friend told me it is because the ecu is still learning since I don't have any exhaust leak anymore. Also when I let the throttle go at high speed I can hear some wired noise come from under the hood. This is driving me crazy, ever since I installed supercharged my car doesn't run properly. |
12-05-2018, 08:45 PM | #3 |
345
Rep 791
I saw your other post. So you had it on for about 1,200 miles right?
How many miles are on the engine now? When did you change our your spark plugs? I had a hesitation that was fixed when I replaced all 8 ignition coils. I am on a 625 kit |
12-05-2018, 10:50 PM | #4 |
12
Rep 88
So currently the supercharger has 2000 miles the car has 62,000 miles I swap the spark plugs right after the supercharge are installed did not change the coil pack
12-05-2018, 10:51 PM | #5 |
12
Rep 88
12-06-2018, 03:10 PM | #8 |
BimmerPost Supporting Vendor
2933
Rep 21,744
Low power I normally see attributed to a few common things. Boost leaks are the first thing I would check. Make sure the manifold didnt lift. Doesnt sound like its the case in your scenario but a weak belt tensioner/slipping belt causes low boost up top. Rare occasions I have seen the bypass valve cause issues.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
12-06-2018, 03:48 PM | #9 | |
12
Rep 88
12-06-2018, 04:15 PM | #10 |
2933
Rep 21,744
That is suction side so wont be a boost leak. Regardless still fix the leak but a boost leak would be on the compressed side. Looks at the manifold to throttle body seals and make sure they are tight.
