11-20-2018, 01:43 PM | #1 |
548
Rep 216
Global Motoring Group's KRATOS Turbos Master Thread
Brand:
Greek God, KRATOS, is the personification of Strength and Power in Greek mythology. This ethos has defined the direction of the KRATOS brand. KRATOS came into conception through a group of engineers with 25+ years of private label design and manufacturing turbo systems for various house-hold name performance brands. These engineers saw a untouched segment in the high end European market for True OEM Style Dual Ceramic Ball Bearing Turbo System Manufacturing and through that revelation the KRATOS brand was born. KRATOS systems are forged from the finest raw materials and assembled with strenuous attention to detail. Every component is purposefully designed and engineered-in-house and tested to extreme standards. KRATOS is The Only True Dual Ceramic Ball Bearing OEM Fit CORE-LESS Turbo System Manufacturer. KRATOS aims to provide exclusive turbo systems for premium European performance vehicles. This goal is achieved through pride and purity of engineering as well as uncompromised use of top tier materials and manufacturing methods. KRATOS was recently acquired by Global Motoring Group LLC, not to be confused with racing company GMG. This has further emphasized the focus of the KRATOS brand is to provide OE fit turbo solutions to top tier European performance cars. Power and Results: Testing: Product prototypes have been in testing through 20k+ miles of daily driving at 750whp+ on beta test vehicles. In addition, KRATOS was approached by Strom Motorsports road racing team due to the inefficiencies and failures of the factory turbos they had experienced. Strom Motorsports recently took first place in the GT4 class at the Bathurst 12HR. Durability and endurance testing has primarily been completed Strom’s 25HR endurance M4 race car as well as their time attack M4. Power: List of modifications
This Dyno Graph depicts the capability of the KRAS55Bi on a stock BMW S55 engine with the supporting modifications listed above at 32psi on E85 fuel. Notice how power continues to climb to the rev limiter which is a results of the compressor wheel, turbine wheel, and manifold A/R ratio design. The goal was to achieve 800whp on a stock engine safely while limiting midrange torque and horsepower for the safety of the connecting rods. More boost or timing was not applied to the stock engine for higher horsepower figures as durability and reliability are one of the main focuses of the KRATOS brand. It's imperative that the test vehicles go through the proper sequence of durability testing at each tested power level before increases in power are applied. As KRATOS has been working very closely with BM3 and HCP tuning, with a built engine and cylinder head the KRAS55Bi will be capable of supporting up to 900whp with the proper tuning. This Dyno Graph depicts the capability of the KRAS55Bi on a stock BMW S55 engine with supporting modifications listed above on 93 octane fuel only. As 93 octane is a much hotter burning fuel, along with that comes higher egt's at given boost levels as well as a lower detonation ceiling. With that in mind, HCP Tuning devised a custom tune as boost and timing are tapered in the upper rpm to increase reliability and repeatability of power. This Dyno Graph depicts the differences in power between the same BMW S55 engine on stock OEM turbos E30 Fuel Only with all modifications listed above without Fuel-It PI vs. KRAS55Bi on E85. There are other S55 that have made more power with stock turbos and stock fuel system, however this is the power that was made on the same vehicle which is why this data was used. Notice at 6900rpm there is a Difference of 327whp between the stock turbos and the KRAS55Bi. These figures are used for reference only, but they do give the end user an idea as to the difference of power that can be achieved when upgrading from a stock OEM turbo system on E30 to a KRAS55Bi on E85. Many BMW S55 owners have come to accept that fact that owning a FBO S55 with hybrid turbo upgrades limits them to approximately 700whp before running into connecting rod failures. The introduction of the KRAS55Bi proves that early connecting rod failure on stock engines is more a result of high exhaust back pressure along with extreme torque demands rather than a pre-mature mechanical limit of the rotating assembly based on data from several high mileage 750+whp beta test vehicles. The shape of the dyno curves listed above are a visual representation of the KRATOS Engineering Team’s success at disproving this fact. Technical Summary: Ceramic Ball Bearing Cartridge (Patent Pending): KRATOS ceramic ball bearing technology encompasses industry leading technology in an OE fitment package. The use of ceramic ball bearings in true OE fit cartridges is entirely unique to KRATOS. This translates into ease of ownership and increased performance for the end user.
One Piece Turbofold (Patent Pending): The cornerstone of the KRAS55 line of turbos, the completely re-engineered one piece turbofold is a part of the reason of safe power can be achieved. The turbofold reduces backpressure significantly, making engine operation at higher output safer and more reliable. In testing, data proved a 1.1:1 Backpressure rating at 32psi. A car making 32psi of boost would see 35.2psi of pressure on the manifold side. This allows for the engine to cycle without additional stress of vacating spent exhaust through a manifold with high resistance. If not addressed, excessive back pressure causes undue stress resulting connecting rod failures as well as loss of power and engine efficiency. Mathematically matched A/R ratio.
OEM Fitment and Core-Less Design: The integration of ceramic ball bearing technology into true OEM fitment is unique to the KRATOS brand. Like all other KRATOS line of products to follow, the KRAS55 series retains use of factory oil and water lines without use of adapters of any sort. Many customers may weigh downtime and core usage as important factors in their buying decision. KRATOS products allow customers to retain their cores for whatever use they prefer and create no downtime other than installation.
S55 Specific Inlets: The factory S55 turbo inlets at their narrowest point have an internal diameter of 42mm. This poses a problem if a compressor wheel with a larger inducer diameter is used. To address this, all KRAS55 turbo systems include a set of custom designed 4 ply silicone inlets as well as a matched ported billet aluminum elbow which are designed to support flow capabilities of even the larger wheel options.
Compressor Wheels: KRATOS compressor wheels are in a league of their own. Each compressor wheel is designed and tested in house for each specific application in mind. These compressor wheels will only be found on KRATOS products and hundreds of hours have been spent on testing and design in order to match the intended use. KRATOS also performs shaft speed testing to ensure that compressor designs are not being run beyond their efficiency range or flow capabilities.. There are currently two options for compressor wheels on KRAS55 turbo systems. KRAS55Bi: 850+whp
KRAS55Ti: 1,000whp+
Warranty: All KRATOS products have a limited 2-year warranty from date of purchase that covers all manufacturing defects. Availability and Pricing: All KRAS55 products require NO CORES! KRAS55Bi: $7,895, Early Q1 2019 KRAS55Ti: $8,995, Late Q1 2019 All Global Motoring Group brands maintain a focus on manufacturing and sell product through the vendor network. All interested consumers can find a licensed dealer in their area through direct contact with a Global Motoring Group representative at info@asrkratos.com. Global Motoring Group ensures that sufficient KRAS55 stock is kept to reduce the chances of backorders and shortages. All buyers can expect their products to be shipped within 24-48 hours after their purchase no matter the season. This being said, high volumes of interest have been observed and many of the first units to ship will be spoken for. Due to this, we will be opening a pre-order list for customers who would like to reserve systems that will be first to ship. More information on preorders will be made available in the coming weeks. Current KRATOS Platforms include BMW S55, Mercedes Benz M177/M178, and McLaren M840T (Currently in R&D Phase). Last edited by Sales@KRATOS; 07-01-2019 at 11:45 AM.. |
11-20-2018, 04:15 PM | #2 | |
ECUTek Master Tuner
10442
Rep 1,731
Drives: F80 M3 YMB
These look very promising!
11-20-2018, 04:23 PM | #3 |
BimmerPost Supporting Vendor
24266
Rep 190,952
11-20-2018, 05:46 PM | #4 |
91
Rep 444
I remember seeing these back at sema about a year ago. These look great and like a very nice turbo option with pure.
Any reason for the delay in go to market? I believe you originally were hoping for q1 2018 Look forward to some results Sales@KRATOS
2017 Mineral White M3
Mods to COME |
11-21-2018, 09:00 AM | #5 | |
548
Rep 216
We decided to push our market release back for a few reasons. First and foremost, many things changed with the production process to reflect how the product is expected to perform in the market. The KRATOS brand was initially structured to do productions runs of a few months worth of inventory. Given the response that was received, that model was changed to doing larger batch runs. Additionally, minor changes were made in the product to reflect the results seen today. The purchase by Global Motoring Group and consequent internal restructuring were a time consuming but necessary and positive process. During this time, additional testing was completed and more miles were logged on the KRATOS hardware. KRATOS takes the testing phase very seriously and tests for reliability and performance far beyond industry norms. |
11-21-2018, 10:22 AM | #6 |
Mr Bill
296
Rep 545
$8-9K when Pure is $4k, and VTT is $4-5K?
I think you've priced yourself out the market for this chassis.
2018 GLC63
2016 Miata 2020 X3M (sold) Turbo Miata Racecar (sold) 1995, 2009, 2015 M3 (sold) |
11-21-2018, 10:52 AM | #7 | |
548
Rep 216
While ASR Engineering and KRATOS are separate brands, we are managed by the same Global Motoring Group and this is a relevant question. In short, yes. The ASR Engineering of the mid to late 2000’s grew much faster than anticipated; this led to managerial and PR shortcomings of which have been aired out. Although issues of management arose, there was never an issue regarding quality of the product or of engineering prowess. The ASR Engineering of now no longer operates as a stand-alone company, but as a brand owned and operated by Global Motoring Group. With this comes a more streamlined and corporate standard operating procedure. Just as management has, the direction of the ASR Engineering brand has shifted. ASR Engineering now focuses its efforts on engineering and manufacturing of true forged carbon fiber performance parts. Information on this will be published in the coming months beginning with endeavors for the McLaren 570S and following with product for the BMW S55. ASR Engineering will also be entering the realm of cooling components, i.e. intercoolers and heat exchangers. Last edited by Sales@KRATOS; 11-21-2018 at 11:39 AM.. |
[DELETED1]469.50 |
11-21-2018, 11:40 AM | #8 | |
91
Rep 444
Mods to COME |
11-21-2018, 12:21 PM | #9 | |
548
Rep 216
We do not compare our products to offerings by other companies as they are very different products in nature. While we appreciate your opinion as this is something many S55 owners may think at first glance, these are our differences. We are the only manufacturer offering dual ceramic ball bearing cartridges with OEM fitment for this platform and any platform at that. Our commitment to uncompromised quality and performance brings with it a product that costs worlds more to manufacture than any other current market offering. All of the technical segments listed in the product release above are components where KRATOS has decided to spend more time and money in order to produce a new class of product. The majority of the current market segment is hybrid stock turbos. Of which, reliability and performance compromise aside require use of cores. Core charges at time of writing this revolve around $2,500. KRAS55 owners are afforded the ability to retain their factory cores, which allow them to return their cars to stock should they desire to do so. If they do not, those cores can be sold to subsidize the purchase of the KRAS55 system. This leaves you with a similar cost to that of hybrid turbo, for an entirely different class of product. When compared to other casted systems, every component of the product has been custom designed for S55 (as we do with every single new development) and are not designs and concepts carried over from previous BMW platforms. KRATOS has made efforts to be fully transparent in its manifold re-engineering and has stated the real world results of those efforts in the form of backpressure testing. Again, KRATOS is the only manufacturer offering dual ceramic ball bearing cartridges for this platform! Our patent pending 316 stainless steel manifolds and patent pending 316 stainless steel dual ceramic ball bearing OEM fit cartridges are a few of the standout differences. We are not simply a BMW turbo manufacturing brand. We are a true turbo manufacturer that works amongst different platforms with multiple patents pending on many of those platforms. KRATOS is an innovator in the turbo technology space. KRATOS performs testing beyond industry norms. Customers can rest assured that more miles have been traversed, more heat cycles have been completed and more dyno passes have been done on KRATOS products prior to release than on any other line of turbo product. The powerband of the KRAS55 is in a class of its own. KRAS55 turbos give a linear powerband that allows the user to go beyond what were previously accepted as limits of the platform. In addition, there is a system capable of 1,000whp+ available which further accentuates the differences between KRATOS and other brands. Customers can be more comfortable buying a US made product from a brand and company that will fully back and support it. The value of the KRATOS product is in its reliability, the engineering experience required to design them and a company who backs their product 100%. As stated previously while we do appreciate your opinion, one of the reasons we increased production is because of interest based on the info provided at our current price point. We hope that this helps you better understand why the KRATOS products are in a league of their own. |
chetrickerman10442.00 whoop_ass355.00 overlook637244.50 ICantDrive4Sht199.00 WeekendWarriorz672.00 AYF8080.50 mashimarho2110.50 |
11-21-2018, 12:23 PM | #10 |
Mr Bill
296
Rep 545
Agreed they do not require cores, but neither do the VTT's. All include the manifold as it's part of the design. I'm sure there will be a few that go here, but this will only be for extreme builds vs mainstream aftermarket. I suspect those that will go this direction will instead go with something like the Doc Race single kit, etc...
I definitely could be wrong, time will tell.
2018 GLC63
11-21-2018, 01:00 PM | #11 | |
ECUTek Master Tuner
10442
Rep 1,731
Drives: F80 M3 YMB
The thing that makes these look attractive to me is that the manifold is completely flow optimized stainless steel (which is much better at not cracking under high heat situations), the ball bearing CHRA which is much better at handling high shaft speeds, and last is how they actually test the back pressure of the turbine side, which likely no other companies do.
Sales@KRATOS548.00 FSociety3812.50 |
11-21-2018, 01:43 PM | #12 | |
548
Rep 216
KRATOS did not simply copy a stock manifold and manufacture a casted version to implement a larger turbine for the sake of offering a core-less system. As listed in the press release, the manifold our engineering team designed is vastly different than stock and the data provided further supports that claim. The perception that the KRAS55Bi would appeal more to those striving for extreme builds may be a valid one for those that aren't familiar with the premise behind the KRATOS brand concept. The mainstream school of thought, as of recent, that anything over 700whp on a stock S55 engine is a ticking time bomb has now been proven as inaccurate. Many S55 owners were not aware that extremely high back pressures and early onset torque tuning were 2 major factors contributing to connecting rod failures in addition to loss of power in the upper rpm band. One of these factors can be easily addressed with tuning changes. However, the mechanical part is a constant that can not be rectified without a change in physical hardware to the KRAS55Bi. That being said, this would appeal to any S55 owner that values the cost of R&D and Engineering to help increase durability and reliability of their stock engine at those given hp levels. Although, we do agree that the KRAS55Bi would appeal to many looking into custom single or twin turbo offerings. They will now have the option of purchasing an OE style system that performs at similar power levels with a much more usable powerband, while being able to utilize their existing bolt on parts and without the requirement of any major modifications. Last edited by Sales@KRATOS; 11-21-2018 at 01:49 PM.. |
chetrickerman10442.00 |
11-21-2018, 01:58 PM | #14 |
548
Rep 216
11-21-2018, 02:18 PM | #15 | |
3138
Rep 2,953
Thought it was Global Motorsports Group. Still very excited Product looks good |
11-21-2018, 03:38 PM | #16 |
548
Rep 216
12-10-2018, 12:47 PM | #17 |
548
Rep 216
As the release of the KRAS55Bi for the first quarter of 2019 nears, we felt it would be an appropriate end to 2018 if we were to post a video of one of our stock engine beta test vehicles showing the highest horsepower ever produced (812whp) with a stock style OEM fitment twin turbo system on the S55 platform.
12-10-2018, 03:45 PM | #18 |
75
Rep 437
I like the product but price tag is on the very high side !! Yes 812whp is a lot but its at 32psi... any aftermarket turbos at that boost level will produce power around that level.. but the stock engine wont last long either .. people are making 600whp on stock turbos at 22.5psi so 10psi more = anywhere between 100 and 200whp more
12-10-2018, 03:48 PM | #19 | |
ECUTek Master Tuner
10442
Rep 1,731
Drives: F80 M3 YMB
Estimate on when the KRAS55TI will be released?
12-10-2018, 05:02 PM | #20 | |
548
Rep 216
This particular beta test vehicle has over 30K miles on it of which 20K+ miles have been with the KRAS55Bi's installed daily driven at 750whp-775whp without fail. We understand there is a lot of information in the press release which can sometimes be overwhelming and overlooked. Here again is a quick excerpt regarding engine reliability at this power levels with the KRAS55Bi. We hope this helps clarify some things. "The introduction of the KRAS55Bi proves that early connecting rod failure on stock engines is more a result of high exhaust back pressure along with extreme torque demands rather than a pre-mature mechanical limit of the rotating assembly based on data from several high mileage 750+whp beta test vehicles . The shape of the dyno curves listed above are a visual representation of the KRATOS Engineering Team’s success at disproving this fact." |
overlook637244.50 KakashiSenpai461.00 |
