11-13-2018, 08:52 PM | #1 |
1105
Rep 1,389
2009 E90 DCT - Quick Deceleration When Off the Throttle
I assumed it was normal, and maybe it is, but just wanted to check and see if its normal on an e90 DCT causes relatively quick deceleration when letting off the throttle on the highway. I would describe is as not close to coasting, and slowing down noticeably in any gear at any speed. I tried searching and couldn't find anything on it.. Any thoughts? Do most people here experience this or is it normal to "coast" when letting off the throttle in Auto?
11-13-2018, 10:16 PM | #2 | |
689
Rep 2,717
Drives: M3
Garage List 2016 BMW X5M [0.00]
08 BMW M3 [0.00] 14 BMW X5 50i - sold [0.00] 09 BMW 335i - Sold [0.00] 09 BMW 328i - Sold [0.00] 07 BMW 328i - Sold [0.00] |
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
IanMan384.00 |
11-13-2018, 10:17 PM | #3 | ||
1105
Rep 1,389
11-13-2018, 10:22 PM | #4 |
689
Rep 2,717
Drives: M3
it is normal... unlike my wife's X5 which just glides when I let off the gas my car just starts slowing down with engine braking....
When I'm driving and see the light turn red I just let off the gas and downshift and end up not even touching the brake until the very end when car rolls with 5mph and it's time to stop... it's been like that always and my car is always been running strong. At first it's weird but you'll get used to it.
wfdeacon881105.00 |
11-13-2018, 10:23 PM | #5 |
689
Rep 2,717
Drives: M3
I'm sure everyone else with DCT can attest to this
11-13-2018, 10:24 PM | #6 | |
1105
Rep 1,389
SDPLV493.00 |
11-14-2018, 02:56 AM | #7 |
261
Rep 1,029
My DCT coasts when I let off at highway speed. BUT....if I have cruise control set at say 65mph and gas it to pass, then let off, it'll apply the brakes to slow back down to the set speed. And yes, the brake lights come on when it does that.
"The likelihood of one individual being right increases in direct proportion to the intensity with which others attempt to prove him wrong."
2015 F82 M4 - Sakhir Orange Metallic 2013 E92 M3 / 2013 E92 335is / 2010 E90 335i / 2007 E90 335i |
ItsGary1457.50 |
11-14-2018, 10:07 AM | #8 |
1105
Rep 1,389
I guess coast is a relative word I used... At 75 mph in 7th, yeah mine coasts also I guess.. This is moreso at 30-50 mph auto mode, where I rarely have to use the break much when coming to a stop/slowdown, even in Auto.
11-14-2018, 10:12 AM | #9 |
167
Rep 1,159
Yup extremely normal. I've only changed my brakes once after 205,000 kms lol
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
wfdeacon881105.00 SDPLV493.00 |
11-14-2018, 10:48 AM | #11 |
348
Rep 203
The DCT is a manual gearbox with automated clutch.
A traditional automatic uses a torque converter with planetary gears immersed in fluid which makes the transition through the gears very soft, as well as allows it to coast and roll forward at a stop. In a manual, the gears rotate with the motor. When you let off the gas in gear, you'll slow down with the rotational mass of the motor but once you press in the clutch, you'll coast, since the rotating mass of the motor is no longer connected to the drivetrain. In a DCT, we do not use a clutch to go into neutral when coming to a stop or letting off the gas, the clutch is automated. So as a result, you'll have engine braking as the gears are rotating with the motor and connected to the drive train. It is completely normal. Last edited by MrGatsby; 11-14-2018 at 07:17 PM.. |
11-14-2018, 07:14 PM | #12 | |
52
Rep 41
11-14-2018, 07:56 PM | #13 | ||||
348
Rep 203
I initially vowed to only get a 6 speed M3, but after driving the DCT, I was beyond impressed as I still feel just as connected to the car as i do with a true manual, yet maintain precise and lightning quick shifts, with the ability to relax during my daily hour commute. |
wfdeacon881105.00 Cbozz688.50 |
11-16-2018, 10:45 AM | #15 |
that's what SHE said!
75
Rep 1,163
Pretty sure you can engine brake in an automatic (planetary gears, torque converter)
11-16-2018, 11:17 AM | #16 | |
348
Rep 203
11-16-2018, 11:33 AM | #17 |
174
Rep 137
Drives: 2008 E93 Space Grey M3 DCT
11-22-2018, 05:23 PM | #18 |
mTekMods
2149
Rep 2,906
The compression and mapping of the dme makes the rev drop very quickly, under 3k rpm it’s not as immediate as the higher of the rev range.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
