11-02-2018, 05:45 PM | #1 |
275
Rep 466
Anyone have their DME fail on them?
Hi. So have started to get a few misfires, but does not seem to follow any particular cylinder. Predominantly on bank 2 (cyl 5-8), but today had one show up on Cyl 1 as well.
Am thinking it might be the MAP sensor as one time I did get code 2738. This morning, I got 2B55 (P1681), which based on my search points to the DME, with instructions to reflash the DME. I believe I am on the original DME software (for my 2008 model), so definitely could benefit upgrading to the 240E+ SW....so am thinking of doing this as the first step before throwing money at other parts (like coils, plugs, etc). Anyone else with a similar situation on 2B55 before? UPDATE, 11/7 Here's an update: 1) I believe my intermittent errors were related to the engine harness wire (plastic conduit rubbing away). I had put a temporary plastic conduit and was still getting errors, but i repositioned it slightly and believe it's keeping the wire away from being exposed to the engine heat. Will do this properly have have the wire rewrapped the next time I have the plenum off 2) So in the past week, have had zero DTC errors and car runs fine 3) As an additional upgrade, I went ahead and upgraded the DME software yesterday. I was on 100E (E89X-08-03-540) and am now on 241E I believe (E89X-18-07-520). As others have mentioned, upgrading to 240E/241E has improved the drive-ability a bit. I would say tip-in throttle response and transition from low RPM is a bit smoother (and less harsher than before with the older software). My wife had always complained before of the car's "jerkiness" in her mind on throttle transition. I typically drive with the POWER button on as without it's a bit too laggy on throttle response. In all, I think the DME SW upgrade was worth it 4) The only other variable that I can't rule out is that I may have gotten bad gas. I normally fill on Chevron 91 near my house but the past couple weeks, there were 2 times that I did a quick fill near work (4-5 gallons)....at a Chevron station as well, but felt like the car ran like shit right after (and right around when I started getting these intermittent codes). Problem is my codes were only on Bank 2 cylinders and with it varying from cylinder to cylinder....so believe if it was bad gas (like higher ethanol content) that this should have affected both Cylinder banks. 5) So in short, everything's running great again and didn't have to throw money on plugs, coils, etc. For reference, here's the relative maintenance on the car: - Both TA have been replaced (Bank 1 at 100K and Bank 2 ~117K mi) - Spark plugs are OEM plugs and replaced around 103K mi - 5 of the Coils are still original. 3 coils were replaced in the past year or so (Cyl 1, 2, and 8)...as those had rubber caps a bit damaged probably from the past owner during spark plug installs As a another round of preventative maintenance, I plan to pull my injectors next week and to send those out for flow testing and rebuild of the gaskets, pintle, etc. Curious to see the flow rates on the injectors on a 120K+mi vehicle. Last edited by kimiraikkonen; 11-07-2018 at 05:00 PM.. |
11-03-2018, 03:25 PM | #2 | |
457
Rep 539
It would only throw the increased emissions engine code but it kept happening after replacing multiple O2 sensors, coil packs, the battery, entire exhaust from the headers back and also the wiring harness for the engine
CP-E DP's / Remus Race / ETS 7" FMIC / AFE DCI / Cobb V3 / ETS CP / HKS BOV
11-05-2018, 04:14 PM | #3 | |
Rep 4
Cheers |
11-05-2018, 04:37 PM | #4 | ||
457
Rep 539
I can say that I never noticed any performance issues, just rough startup every now and then and a rough idle for a few mins until things warmed up a bit. Also the software wasn't updated because it was already the latest software, the car was one of the last few coupes off the assembly line so software wasn't an issue.
11-05-2018, 11:48 PM | #5 |
275
Rep 466
Please share what codes you are getting. Are you getting a 2B55 code alongside other misfire codes? Was getting a misfire last week and the DME error...but it's disappeared all of a sudden. Some of the plastic conduit was rubbing away on my wiring harness...which I put a temporary sheath over...seems to have resolved it. Am taking my car tomorrow to have the DME flashed to the latest software as a baseline as well.
11-06-2018, 01:20 AM | #6 |
BimmerPost Supporting Vendor
3387
Rep 7,542
Highly doubt it's the DME hardware. 2B55 is normally a collateral toque management/emergency program code triggered by another component that is likely the real issue.
If you previously received a map sensor code you should probably replace that sensor to start.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
11-06-2018, 11:38 AM | #7 |
78
Rep 337
i had very similar issues and after several attempts with my local indy i took it to the dealer who said it was a fried DME - reluctantly replaced the DME (i doubted that was the issue but was out of options) and still had misfires... they took it back for a week and said they couldnt pinpoint the issue but that the car was working fine after they cleaned up a few things. worked for another month but misfires came back. i ended up trading the car in, sadly.
11-07-2018, 04:43 PM | #8 | |
Rep 4
27C7 was/is the code that I keep getting. Sorry to derail your thread, was slightly excited to find an online mention of my problem for the first time. |
11-07-2018, 04:57 PM | #9 | |
275
Rep 466
1) I believe my intermittent errors were related to the engine harness wire (plastic conduit rubbing away). I had put a temporary plastic conduit and was still getting errors, but i repositioned it slightly and believe it's keeping the wire away from being exposed to the engine heat. Will do this properly have have the wire rewrapped the next time I have the plenum off 2) So in the past week, have had zero DTC errors and car runs fine 3) As an additional upgrade, I went ahead and upgraded the DME software yesterday. I was on 100E (E89X-08-03-540) and am now on 241E I believe (E89X-18-07-520). As others have mentioned, upgrading to 240E/241E has improved the drive-ability a bit. I would say tip-in throttle response and transition from low RPM is a bit smoother (and less harsher than before with the older software). My wife had always complained before of the car's "jerkiness" in her mind on throttle transition. I typically drive with the POWER button on as without it's a bit too laggy on throttle response. In all, I think the DME SW upgrade was worth it 4) The only other variable that I can't rule out is that I may have gotten bad gas. I normally fill on Chevron 91 near my house but the past couple weeks, there were 2 times that I did a quick fill near work (4-5 gallons)....at a Chevron station as well, but felt like the car ran like shit right after (and right around when I started getting these intermittent codes). Problem is my codes were only on Bank 2 cylinders and with it varying from cylinder to cylinder....so believe if it was bad gas (like higher ethanol content) that this should have affected both Cylinder banks. 5) So in short, everything's running great again and didn't have to throw money on plugs, coils, etc. For reference, here's the relative maintenance on the car: - Both TA have been replaced (Bank 1 at 100K and Bank 2 ~117K mi) - Spark plugs are OEM plugs and replaced around 103K mi - 5 of the Coils are still original. 3 coils were replaced in the past year or so (Cyl 1, 2, and 8)...as those had rubber caps a bit damaged probably from the past owner during spark plug installs As a another round of preventative maintenance, I plan to pull my injectors next week and to send those out for flow testing and rebuild of the gaskets, pintle, etc. Curious to see the flow rates on the injectors on a 120K+mi vehicle. |
