10-31-2018, 08:46 AM | #1 |
Studntloan
581
Rep 620
Hey guys, Im listing up a 1996 E36 M3 track car for my cousin. The car was built From the ground up at Autocouture Motoring and has over 250 hours in the shop alone A lot of time and parts have been put into this car to make it perfect and track ready with no hiccups He has easily spent over 40,000 even on a hook up to build this car perfectly Not including the car itself The car was torn down completely and stripped and prepped for the roll cage The car has 80,000 miles before being torn down during the tear down process the interior parts were lost and we grabbed a used speedometer for the car which shows about 125 I believe on it I know I'm going to be forgetting a ton of info but here it goes! - The Engine was built by Chuck Stigley by the previous owner, not sure the specs other then it has cams while in our possession we had the car tuned by rk tunes - The cage was built by John Weinberg from Berg racing - The car put down 265whp Some new Parts Include- Stop Tech St40 Front BBK Ma Shaw LTW Wing Ma Shaw Rear Windows New Windshield Cae Shifter Bimmerworld full Race exhaust 1 new rear axle Knock Sensor Coil Shim Air mass meter boot Idle Control Valve Intake manifold gasket Spark plug connectors New Bulbs Speedometer Sensor New Gasket kit for Fuel tank 2 X Planted Floor Mounts 2 Recaro seats with head support Misc dash switch New wiper assembly Allstar full length mirror New battery 2 sets of silver Kosei Track wheels 17x8.5 Fire suppression kit Vehicle steering wheel quick release Momo steering wheel Clutch masters FX850 Twin Disc Race Clutch kit with steel flywheel New rear brakes Turner Gruppe N suspension Active diff bracket Diffsonline Diff- Type 3 clutch, 3.73, LSD 3 clutch, REM ring and pinion polishing, Motion Control Front sway bar and camber plates Z3 rack Reiger Front lip As of recent the car just came from from Munich Motorsports for a full once over nut and bolt as well as adding an ABS system to finish off this perfect beast. Its a very quick car with a capable drive, it did 58.5 at Limerock this year before the ABS was installed as well as a 138 at NYST It only has around 6 hours of driving if that since the build was completed. Paint is in great condition, ( To be honest its better then most street e36 cars ive seen at some shows ) This is not a street car and is perfect for someone looking to skip the build bullshit and just start driving! Please PM me with any questions at all, The car is located in Westchester County NY and I will assist with shipping. |
