10-28-2018, 02:15 PM | #1 |
18
Rep 132
Replacing N55 waterpump & thermostat
Hi guys, water pump is leaking and need to replace. What I would like to know, is there anything else I need to order & replace other than the pump, replacement bolts & new thermostat?
2012 DSB e88 135i Dinan S2
10-30-2018, 11:49 AM | #2 |
500
Rep 647
Coolant. You could do the expansion tank and hoses too if you really feel like it.
https://www.fcpeuro.com/products/bmw...11517632426kt3 lifetime replacement is mint for water pumps. Change it every year if you want. |
Blu3RSX27.50 |
11-07-2018, 05:17 PM | #3 |
Rep 7
That’s all you should need. But if any of your coolant hoses have been in contact with oil from a leaking oil filter housing gasket, now is a good time to replace them. Be sure to use OEM blue coolant. If you use the typical green you’ll be repeating the job much sooner.
