10-25-2018, 02:21 PM | #1 |
373
Rep 500
M buttons keep resetting
Hey folks,
Yes I've searched. Over the last few weeks, my 2015 M4 stopped "remembering" the M-settings. In other words, if I reset them and calibrate them as I wish...the settings remain active until the car is shut off. When I restart the car (after the DME shuts down), I am back to the default settings (M1-Sport/Comfort DSC on, M2 Sport plus/sport plus MDM S3) Backgorund info I Added the IND red buttons (M1, M2) and damaged a couple of the connectors when I removed the steering will switch set. I assumed the problem was from this and just yesterday, replaced with sets with brand new BMW OEM parts. Problem is still there. Also, the car was reprogrammed at the dealer after a minor collision (they updated software so as to replace headlights and PD sensor since the BM3 flash seemed to give them trouble)....I have since reflashed the custom tune I have checked to make sure the PROFILE is correct (based on other suggestions I found online) Other than BM3, I have done no coding of specific ECUs. Bad head unit? Just seems temporally related to the button change intially Any suggestions, other than a dealer visit?? Thanks |
10-26-2018, 03:51 AM | #2 |
219
Rep 464
I had this exact problem just last week. My car is 18 f80. I reflashed ecu and it worked again.
Instagram:catpupu_f80 |
blockdoc373.00 |
10-26-2018, 04:58 PM | #4 |
219
Rep 464
Glad it worked out for you!
blockdoc373.00 |
05-24-2020, 02:16 PM | #5 |
114
Rep 340
Hey guys, pinging this as I'm having the exact same issue and have BM3 on my F80. I've tried changing maps, flashing back to stock, but M settings still get reset when car shuts down. When you say reflash the ECU, what exactly do you mean?
05-25-2020, 02:26 AM | #6 |
373
Rep 500
Are you using a charger while flashing?
05-25-2020, 02:31 AM | #7 |
219
Rep 464
I meant reflashing the map. You've already done it so I have no idea how to fix it. However aside from charging up the battery (either with a charger or drive for 30+ mins) and reflashing again, there are a couple of things you can try: 1. backing up the settings in idrive to an usb drive and reset to factory settings 2. Unhook the battery in the trunk for 5-10 mins and reconnect
05-26-2020, 10:10 PM | #8 |
114
Rep 340
figured it out. I have a wifi agent I use with my BM3 tune. the wifi agent is hardwired into my cigarette lighter under the passenger dash, so never goes to sleep or turns off. as a result this prevents the car from somehow saving my settings when its turned off. when I unplugged the device from the obd port everything saved as normal. next step is wiring in a switch to turn the power to the wifi agent on and off!
05-22-2021, 12:16 AM | #9 |
23
Rep 50
I've been experiencing the same issue with my car.
My M settings do not save. After I crank the car it defaults to what I think are factory settings. I tried unhooking the battery for 15 mins, flashing to stock tune. Nothing. I even reached out to the tuning company and we did a reflash of the entire car. I changed key fobs and also updated my I drive to the latest version. Along with the M settings not saving, my oil service comes up and doesn't go away. I did everything stated above and reset it on the dash but it keeps coming up. I needed an oil change before the tune which I got a few days later at the BMW dealership where they reset it and it came back. They did me a favor by not flagging my car to void the warranty s/o to them. Does anyone know what could be causing this and how to fix it? |
07-01-2021, 01:45 PM | #10 |
2896
Rep 3,726
Any resolution to this? I am thinking my key fob battery may be dying so I am going to try replacing it to see if it works.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
07-07-2021, 08:41 PM | #11 |
150
Rep 511
I'm not sue if this covers the issue but...
F.Y.I.: If you run "BM3", every time you re-Configure a map and/or Flash a new one, your M1/M2 will be reset sometimes (?), along with your iDrive Amp. - equalizer settings. This is normal SOP. Cheers!
///M Joy
07-08-2021, 01:18 AM | #12 | |
2896
Rep 3,726
My memory for M1/M2 buttons worked fine without the Zeitronix unit powered on, which is why I think it's an issue with the wiring or unit itself
07-08-2021, 10:37 AM | #13 | |
150
Rep 511
///M Joy
07-20-2021, 12:42 AM | #14 |
23
Rep 50
07-20-2021, 01:13 AM | #15 | |
2896
Rep 3,726
Now I'm onto chasing other things that are wrong with the tuning side related to rough idle lol
07-20-2021, 04:53 AM | #16 |
29
Rep 114
Mine is also hit or miss. Sometimes the M settings are fine, other times it resets. Currently have the Re|Flex installed. I noticed that when flashing the ECU when the re|flex is disconnected (just the box, the wiring is still there) it tends to hold the M settings. Not 100%, but more often than not. This leads me to think it might have something to do with tapping into the canbus.
2013 F30 335i - Totaled 2016 F80 M3 - PS2+ | MHD | Wedge Performance | |
12-14-2021, 09:57 AM | #18 |
2896
Rep 3,726
Your kit was wired improperly. I think the BM3 solution is the way to go if you are doing flex fuel these days.
