07-05-2008, 03:38 AM | #1 |
Rep 73
More details on new iDrive
This has been confirmed for September in UK:-
(Scroll down for Screen shots..) In September 2008 option 609, BMW® Professional Multimedia Navigation system, will be revised on the following models: 1,3 & 7 Series The updated system includes a new iDrive Controller with shortcut buttons, together with a more intuitive iDrive menu system. The highlights of the new system are as follows: New iDrive Controller with more intuitive operation High resolution Control Display with vibrant screen Revised iDrive menu structure Interactive help with on screen description of function Built in hard disc drive for improved speed of operation and data storage More detailed navigation map New navigation options and settings to enhance route planning Multimedia capability with 8GB storage for audio files Improved voice control New layout for Favourite buttons with new direct function keys (model specific) New iDrive Controller and Control Display The new iDrive Controller now features shortcut buttons. These provide access directly to systems which are regularly used by the driver: CD / Multimedia Radio Telephone Navigation The “turn-press-slide“ system previously used has been enhanced. From the Main menu a sub menu is selected by turning the controller and pressing down. To then navigate to the sub menu you then tilt to the right to open each further sub menu. This opens a window on top of the last screen. Tilting to the left moves back a screen. Using any of the shortcut buttons (CD, RADIO, TEL, NAV) at any point returns the user to the last screen used within that menu. The other controller buttons function as follows: MENU Returns you to the Main menu BACK Back to the previous screen, for up to 30 steps OPTIONS Some sub menus have settings and specific functions that can be set by using this button Hard Disc Mode The new system is hard disc based rather than running from a DVD map. This provides the following benefits: Improved speed of operation Factory installed navigation map Storage capability for other data Single DVD Drive in dashboard The navigation map can be updated by: Workshop programming system Loading an update disc in the DVD Drive Navigation Enhancements – Route Planning The new navigation map provides route planning enhancements: Full screen mode 3D perspective view Assistance window Height mode Night view Travel planner (multiple stop-off points along one route) Navigation Enhancements – Assistance Window The following changes have been made to the functionality available within the Assistance Window: Zoom in / out separately from the main window With manual navigation destination entry, after input of several characters, a wizard type list is displayed Any list containing locations will be displayed in a map in the assistance window (eg. points of interest, traffic information) If a route is planned, the Assistance Window will highlight it, making it easy to see where a location is in relation to the route Entertainment details allows you to display details of the music you are currently playing When a destination is set the Road junction zoom is an option that will show an enlarged graphic of the junction exit on your planned route Navigation Enhancements – Night View You are now able to select a night view for the navigation map. Navigation Enhancements – Travel Planner The new navigation system can also be used as a travel planner to plan routes with up to 30 stop-off points. When you set-up a route you can freely insert new addresses into anywhere between the start point and the destination. When a stage destination is reached the navigation system automatically sets the next destination. You can also reverse the direction of the route and save routes you have created for future use. Multimedia Capability – Music Storage The hard disc drive provides 8.0GB storage for audio files. Music can be stored on the hard disc from three sources: Audio CD Data CD/DVD USB device in data port Usable storage capacity on the hard disc in 7.6GB, this will hold circa 2,000 songs at 128kbits/s. Audio CD ‘Save music to car’ function ‘rips’ the music to hard disc drive Music is converted into a WMA file with a fixed data rate of 128 kbits/s and is saved on the hard disc drive Music can be played while the music is saved Audio CD’s ripped and saved to the hard disc drive are shown in the music collection with a CD icon by the corresponding title Data CD/DVD ‘Save to vehicle’ function copies audio files from a data CD or DVD to the hard disc MP3, WMA and AAC formats are compatible Audio copied to the hard disc drive is shown in the music collection with a folder icon by the corresponding title USB device ‘Import New Music (USB)’ function copies audio files from a USB device to the hard disc MP3, WMA and AAC formats are compatible Audio copied to the hard disc drive is shown in the music collection with a folder icon by the corresponding title The new navigation system includes a new USB data port hidden in the glove box to import the music, this USB data port cannot be used to play audio files You cannot import music to the hard disc drive from option 6FL USB audio interface, located in the arm rest The new USB data port in the glove box can be used export all of the audio files from the hard disc drive, onto an external USB device. This facility is for the customer to use if the vehicle is to visit the workshop, or if the customer is changing their vehicle. Exported audio files can be imported back to the vehicle by uploading via the USB data port. Note: It is not possible to play music files that feature copy protection, although they will be copied to the hard disc drive from CD/DVD or USB device. The CD / Multimedia menu includes a sub-menu which allows you to search the audio you have saved using the following criteria: Genre / Artist / Album / Track To enable use of this facility every audio file stored in the car must be encoded with data (it is called the ID3 tag). This information is not always available on an audio CD. On the hard disc drive there is 4GB space allocated to a database called Gracenote. This database is accessed when an audio CD is ripped and the audio file is saved with the track data if it is available. There will be additional options for BMW® ConnectedDrive customers to supplement missing data. The Gracenote database can also be updated during a workshop visit. Bluetooth telephone integration The new system supports PIM services (Personal Information Manager.) Future bluetooth handsets we recommend with PIM services will transfer the phone’s contact data to the hard disc, this will include contact addresses held in the phone memory. The car will have a ‘Central address book’. Information transferred by the phone will appear in all relevant menus (phone menu, navigation address book and Contacts.) Voice Control Improved voice control (where fitted.) |
07-05-2008, 05:52 AM | #2 |
Rep 371
07-05-2008, 08:35 AM | #3 |
218
Rep 3,592
'08 E92 M3 6MT | IB | FR | RAC RG63's | VRS Ti Exhaust | Fabspeed HFC & Xpipe '09 X5 35d SG/SB '11 X3 28i AW/CN/FW (wife's car |
07-05-2008, 09:06 AM | #4 | |
1979
Rep 1,847
07-05-2008, 09:13 AM | #5 |
156
Rep 1,429
As much as I would love to get the more detailed map and HDD, I like the look of the one button iDrive much better.
07-05-2008, 11:01 AM | #6 |
152
Rep 5,124
i know that the new button seems kind of against the whole purpose of i-drive (simplicity), but after using the system before, I think it will be much better to have an MMI-like system with quick shortcuts instead of having to always go back to the main menu or pausing in one direction to navigate. This is going to be a big improvement!
07-05-2008, 11:23 AM | #7 |
Ambassador of Crunk
17
Rep 606
Would the more detailed navigation maps and functionality come from an updated dvd, or does this require updated hardware/software in iDrive?
07-05-2008, 12:54 PM | #8 |
Rep 6
Just one an fantastic steel like button is enough. All the things said about iDrive seem to me like prejudice. It is a great system with all one can get with the voice recognition features already present in the E92.
07-05-2008, 12:59 PM | #9 |
152
Rep 5,124
07-05-2008, 01:38 PM | #10 | |
20
Rep 246
07-05-2008, 01:39 PM | #12 |
1979
Rep 1,847
Wouldn't it be easier to reach/use if the Idrive controller was on the dashboard below the screen,especially if you have a passenger using the center armrest.
07-05-2008, 01:54 PM | #13 |
156
Rep 1,429
I like the iDrive in the back, that's a great idea.
07-05-2008, 02:11 PM | #15 |
152
Rep 5,124
07-05-2008, 03:09 PM | #16 |
71
Rep 1,032
Drives: 997 GT3 RS
Garage List 2007 Porsche 997 GT ... [8.50]
2005 Mercedes Benz ... [0.00] 2008 E92 M3 (Bought ... [0.00] 2007 E93 335i conve ... [0.00] 2006 E92 325i Coupe ... [0.00] 2001 E46 M3 (Sold S ... [0.00] |
it looks good ... shortcut buttons much needed ...
2007 Porsche 997 GT3 RS |PCM with NAV and GSM|Roll Cage|PCCB|Xenons|Sports Chrono Plus|PASM|Leather Pack|Silver Seat-belts| |
07-05-2008, 03:23 PM | #17 | |
205
Rep 1,864
Drives: F80 M3
Garage List 2016 Porsche GT4 [0.00]
1999 Porsche Spec B ... [0.00] 2014 Ram 1500 Laram ... [0.00] 2007 Porsche GT3 RS [10.00] 2013 Tesla Model S 85 [0.00] |
"In September 2008 option 609, BMW® Professional Multimedia Navigation system, will be revised on the following models: 1,3 & 7 Series" It makes the most sense that the 2009 E90 LCI update would include the updated interior with new iDrive, otherwise we'd see a separate exterior and interior LCI. But who knows, Bimmerfile has stated elsewhere that there is a surplus of 2008 cars in the US so that may have influenced BMW's decision. |
07-05-2008, 04:13 PM | #18 | |
1120
Rep 8,017
07-05-2008, 05:46 PM | #19 | |
792
Rep 2,234
609 is the code used for the Professional sat nav now as well. |
07-05-2008, 08:57 PM | #20 |
MacroRisk
109
Rep 2,523
Tedious: Don't give a rat's that it is a repost as I just saw this post ( ) and don't wish to search as if I had OCD.
To the point: I do want this new interface for iDrive.
Just thinking of something not so witty ///M3 E92 '09 Jerez Black | 6MT | Ext Fox Red | Tech | Prem | 19s |Heated Seats | iPod |Smartphone | Euro Deliv June 09 Sold: 540iT / 530i / 323i |
07-05-2008, 09:06 PM | #21 |
55
Rep 649
I hate BMW. this happens all the time. the idrive is a nightmare and what it needs is shortcut buttons and revised menu and the navi is crap etc. and I'm stuck with the crap version.
07-05-2008, 09:09 PM | #22 | |
MacroRisk
109
Rep 2,523
I was using the latest version in a 3er in Germany last mth and found the latest iDrive to be: (1) useful; and (2) easy to use (can you use a PC/Mac? ... clearly you are able to do so as you are here...) I just want the user interface enhancement presented by the MMI-like buttons.
