09-24-2018, 10:15 PM | #1 |
38
Rep 147
Wireless Charger
New Apple Watch ✓
New iPhone XS Max ✓ M3 Wireless Charging? Nope! Man I am bummed that it's so close to fitting but not quite. I am considering removing the rubber grommet on the top to allow a bit of room. Looks irreversible though so curious what others have done? Thanks |
09-24-2018, 10:18 PM | #2 |
2914
Rep 2,785
Drives: 2020 M4 ZCP / 2023 X3 M40i
Get a smaller phone. Fits my iPhone XS!
09-24-2018, 10:29 PM | #3 |
38
Rep 147
Update: sliced the rubber piece and cut the two plastic sides off with a utility knife. Fits and charges! Woo hoo
I only had to shave off maybe 1/8" basically just square it up because it is at an angle which causes the phone to pop up |
09-25-2018, 12:59 AM | #4 |
12
Rep 59
09-25-2018, 01:23 AM | #6 | |
38
Rep 147
09-28-2018, 06:01 PM | #8 |
38
Rep 147
09-29-2018, 08:23 PM | #9 |
///M SubDriver
1844
Rep 2,787
Drives: 2017 M3, 2020 X7 40i
So does your phone get really hot while charging, especially if you are using a few apps with it on the wireless charger (like a navigation app or a music app)?
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's) |
09-30-2018, 02:17 AM | #10 | |
38
Rep 147
09-30-2018, 10:54 AM | #11 |
///M SubDriver
1844
Rep 2,787
See how well it works on long drives (30+ min) while using multiple apps on the phone (like for navigation, music, etc). In my case, anything longer than about 30 min or so and my phone will get so hot, it will shutdown due to overheating - and that is with one app running like Waze or Google Maps. Now, I use an iPhone 6s with a wireless charging sleeve, since the iPhone 6s was never originally designed for wireless charging. However, when I use any other wireless charger, my phone hardly gets warm which makes me think the BMW wireless charger is the problem, not my phone/sleeve combo.
Hopefully the heat issue is not an issue with the newer iPhones with built in wireless charging....
10-02-2018, 12:59 AM | #12 | |
38
Rep 147
10-02-2018, 01:39 AM | #13 | |
Rep 3
SteveC90 has provided the design and I am having it made for less than £10 here in the UK. |
10-02-2018, 06:56 AM | #14 |
12
Rep 29
I would assume it would be fairly simple to purchase any of the high quality and inexpensive Qi chargers at any reputable establishment, and make something work in the same area. Or even where the cup holders are or something. Obviously, easier said then done, but I don't think it would be too difficult for someone who really wanted to do it.
10-02-2018, 09:30 AM | #15 |
///M SubDriver
1844
Rep 2,787
I don't think so. I have left the armrest open as an experiment and it did not make a difference. I even bought the OEM BMW wireless charging sleeve as it was more open on the back (assuming it would help with better cooling) but my phone would still overheat.
That area inside the armrest is a bit warm anyway since it is right above the transmission tunnel - but not much. However, it is very obvious that the extra heat generated is from the wireless charging process.
