09-07-2018, 05:13 PM | #1 |
190
Rep 271
link for 2019-1 NEXT map
Since this is a popular topic, and people are asking for it, I decided to make a new thread even though I have posted the link in other threads.
Enjoy it. |
09-07-2018, 05:56 PM | #2 |
Rep 74
09-07-2018, 06:18 PM | #3 |
190
Rep 271
09-08-2018, 10:08 AM | #4 | |
Rep 74
09-09-2018, 08:14 AM | #6 |
76
Rep 152
Still can't get it to work so not sure if the file 2019-1 is complete.
The system never prompt for update.. I have updated to 2018-1 myself with life time code so I'm familiar with the process. After inserted the USB in the armrest, the update screen just doesn't prompt. Anyone else? I'll try to download it again
Jeff
Current Ride - 2016 Toyota RAV4 Hybrid - 2014 X5 xDrive35 M - 2013 ML-350 (Gone) - 2012 Audi Q7 TDI (Gone) |
09-09-2018, 08:47 AM | #8 | |
458
Rep 570
09-09-2018, 09:21 AM | #9 |
Freude am Fahren.
835
Rep 1,287
Drives: F15 X5 xDrive35i
Different headunits.
NEXT for the NBT, Premium for the CIC and EVO for the NBT EVO.
Freude am Fahren.
09-09-2018, 07:30 PM | #10 | ||
76
Rep 152
I have tried Fat32, exFat and NTSF but none of them will work. I'll try plug in the usb prior to starting the car to see if that makes any difference. I recall previously I had the car running and inserted USB for 2018-1
Jeff
09-09-2018, 08:02 PM | #11 | |
Freude am Fahren.
835
Rep 1,287
Freude am Fahren.
09-09-2018, 09:36 PM | #12 |
190
Rep 271
When I downloaded last week, file was complete, it took a while to download. The process is the same as 2018-1. Make sure your USB is wiped clean and put all folders and files on 1 volume. USB should only show one volume: folders 1-4 and files.
09-10-2018, 07:34 AM | #13 | |
Rep 74
Ive tried doing the above, ive also tried doing the original way the files came which is a couple files + the folders "1" "2" "3" "4" and i've still not been able to get the update to recognize. I am also running NEXT software on my BMW (2015-1) |
09-10-2018, 09:43 AM | #15 |
Rep 74
can someone post a screenshot of what its supposed to look like? also im using a macbook pro -> do i format to FAT ? there is no option for Fat32 but i think MS-DOS FAT is FAT32
09-10-2018, 10:15 AM | #16 |
Freude am Fahren.
835
Rep 1,287
Mac adds EFI partition, which makes the drive unreadable by a BMW. The only way on the Mac to make it right is to use a command line. Where in Toronto are you? I can borrow you my USB with a map if you've got NBT.
Freude am Fahren.
ed1167.00 |
09-10-2018, 11:19 AM | #17 | |
Rep 74
maybe thats why its not reading it would really appreciate it! feel free to pm me a number and i can reach out to you! id ont mind coming to ya |
09-10-2018, 11:54 AM | #18 | |
Freude am Fahren.
835
Rep 1,287
Freude am Fahren.
ed1167.00 |
09-10-2018, 08:23 PM | #19 | |
Rep 74
That USB Stick came through upgraded to 2019-1 :-) now question for anyone in canada, is it worth the 3-year Real Time Trafic Information? its a $200 subscription for 3 years. I have been using waze but waze i've found will often lead me into traffic not away from it. |
09-10-2018, 11:21 PM | #20 |
Freude am Fahren.
835
Rep 1,287
I use it all the time. Gives me enough information to decide on the optimal route and avoid unexpected traffic and all on the car display, which I find much less distracting to use than a phone.
Freude am Fahren.
09-25-2018, 08:53 AM | #21 |
211
Rep 627
Drives: X5 F15 M package
folks,
did anyone successfully upgrade to 2019 map version? I am trying using the usb in console on X5-F15 2015 but no luck to read the data. Drive is 64 GB, FAT32 formatted; the root structure is: 1 2 3 4 NBT_NANT_111174.3.111.pkg.sig NBT_NANT_111174.3.111.pkg config.nfm README.txt when i jumped in the car i turned on the ignition then put the drive in the USB in the central console. and nothing happened. also i am trying to read and generate FSC using ENET cable and 1B CIC FSC File reader.exe on a windows 8 VM running on MAC. your help is appreciated. |
09-25-2018, 12:12 PM | #22 |
197
Rep 535
I have installed it. My advise is to use a pc. Even in a windows VM on mac, as soon as you eject, osx will mount the fat32 and create a bunch of thrash files on the root folder (invisible) which will prevent idrive from detecting the disc.
Another not advisable option is to format in VM, and after all writing is done, yank the USB out and see if it works in idrive. As long you arent writing to the disk, it should be fine.
Present: 2014 X5 50i
3rdRow;ACC;HK;HUD;X5M Filters;Bootmod3;FenderFlares;NBTevo6+ATM+carplay; MPBK;612m;X5M-CF-rear-view-mirror-cover;ALPjammer;eurostyle-mirrors Past: 2013 750i xdrive, 2008 535xi |
