06-29-2008, 09:14 PM | #1 |
258
Rep 1,238
Drives: 2020 X6M Competition DG
How to remove M3 trunk lip spoiler correctly?
Ok folks, I purchased a CF M3 lip spoiler for my trunk lid.
The question is how do you suggest I remove my OEM M3 spoiler? And when I do, how do I remove the remaining residue on my trunk? Thank you for you suggestions and tips. I will post pictures during the process. I estimate my lip spoiler should be arriving sometime this week. Anthony
2020 X6M Competition // Donington Grey // Executive Package// Bower and Wilkins Sound System // Driver Assistance Package // CF Trim
06-29-2008, 10:31 PM | #2 |
36
Rep 129
It’s been a few years but what worked well with my E46, as I recall, was slowly working fishing line between the spoiler and the trunk lid to separate them and then Goo-Gone to remove the residue of the 3M double-sided tape.
06-29-2008, 11:57 PM | #3 |
152
Rep 5,124
This could work...some people use dental floss, but that might not be strong enough. Also would recommend a hair dryer. Be careful with the goo-gone, you might want to dilute it because it could damage the clear coat.
06-30-2008, 02:40 PM | #6 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
Is the OEM lip spoiler held on by 3m double sided tape too?
06-30-2008, 02:48 PM | #8 |
152
Rep 5,124
06-30-2008, 03:50 PM | #9 |
100
Rep 1,035
If it's impossible to remove with goo gone, goof off, or any of those other adhesive removers, sometimes you have to use what's called an eraser pad. This is what professional shops use and I'm sure if you don't want to buy the pad itself, you can go to a body shop and they will make quick work of your tape for next to nothing. Sometimes that stuff is really hard to remove so that's why you use these pads. They are safe and you can buy pads that will fit your drill.
09-03-2013, 06:42 PM | #11 |
John
75
Rep 885
I see you're interested in the CF spoilers lol.
I used heat gun, then fishing line and it popped right off. The hard part is removing the existing tape. Used goo-gone and a lot of fingernails lol. Finished up with a polish then alcohol wipe down to ensure proper adhesion. I used the OEM bmw betalink for the new CF spoiler. It's alot of work lol but I know for sure it will stay on.
Current - 2012 AW/FR E92 M3 | 2014 AW X5 | 2015 MB S550 | 2016 RR V8 (White FTW) Mods - BPMTune Stg1/Servo, Euro Visors & Side Mirror, IND Gloss Blk Pkg, OEM Perf. CF Trim/Spoiler, Grills, Lights, Pedals, Umnitza V4 AE, ModeCarbon GTS V1, 19" HRE P40 Sold - 2008 BSM/Black E92 335i |
09-03-2013, 10:33 PM | #13 | |
72
Rep 604
So it's definitely something simple you can do yourself rather than paying the body shop to do it? So maybe an hour? I suppose my spoiler should be a bit easier since it is less than 4 months old?
/// M3 + 6MT + ZCP + ///MPE = A Healthy Addiction /// |
09-03-2013, 10:34 PM | #14 |
72
Rep 604
Thanks for your tip. Plastic razor on the paint? Should I apply express wax before using the razor (as in claying?)
09-04-2013, 05:27 AM | #15 | |
103
Rep 893
Give this a look: http://www.autobodytoolmart.com/plas...FVNo7AodGGEA7g |
09-04-2013, 01:18 PM | #16 | |
John
75
Rep 885
As for installation, some people swear by 3m tape so that could be an option. I stuck with oem beta link
09-04-2013, 01:29 PM | #17 | |
7491
Rep 12,310
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
09-04-2013, 06:34 PM | #18 |
84
Rep 2,792
It's possible too cut the paint with fishing line if you get carried away with the sawing motion. I use(d) a t-shirt and heat. As you heat, pull one layer of the shirt under the spoiler with a slight sawing motion. This puts some upward pressure on the spoiler as well.
I don't like to put Goo Gone on the paint so I use a 3M Eraser wheel.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
09-06-2013, 12:50 AM | #19 | |
569
Rep 3,742
Also, how are people lining up the new spoiler to make sure it goes on properly? I envision myself putting it on all wrong. I was thinking maybe a grease pencil to mark where the edge should go? |
09-06-2013, 02:04 AM | #20 | |
No 55mph
1621
Rep 8,476
For those that us BetaLink - hopefully you will never have to remove the spoiler to repaint - because removing parts adhered with BetaLink will damage the paint underneath You can get the 3M Eraser Wheel here (but these are mainly used for pin stripe removal not adhesive residue): http://www.amazon.com/3M-7498-STRIPE...m+eraser+wheel 3M also makes an aerosol adhesive residue remover that does not harm paint found here: http://www.amazon.com/3M-03618-Adhes..._bxgy_hi_img_z I have always just used fishing line & Goo Gone with absolutely no problems or damage...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
09-06-2013, 07:49 AM | #21 |
76
Rep 422
Mine come in today from IND, will most likely use the heat gun, fishing line technique. I have also always used goo b gone with no issues but may try the #M adhesive remover to see how that works. I am going to use 3M tape instead of the betalink.
2011 M3 Sedan
2001 M Coupe 2020 Macan Turbo 2018 GT3 |
09-06-2013, 03:30 PM | #22 |
84
Rep 2,792
I got mine on eBay. It's not that hard to line up. It's obvious where it should be on the trunk. The only part you need to worry about is making sure that it's even side to side. The performance spoiler is a touch shorter than the trunk so you just need to make sure the same amount of trunk is showing on each end.
