08-29-2018, 02:53 PM | #1 |
Rep 6
Scarring found in cyclinder walls
Please help with advice: purchased 2012 e93 with inspection... started getting increased emission code, had dealer check, and found the actuators were going bad, o2 sensor bad, and secondary air pump bad. Repaired all, error kept returning. Pulled a few plugs and noticed 2 looked pretty bad (6&7)... decided to look in cylinder and bad scars. I have had the car 2 months, either rebuild, replace engine or sell. What in the world to do ...
M3 Dreams Crushed |
08-29-2018, 04:38 PM | #3 |
567
Rep 801
Carmax is your friend here.
2011.75 E90 M3 | 2006 GMC Sierra LBZ | 2004 X5 3.0i 6MT | 1995 M3 S50B32 | 1990 325is | 1989 M3 S54B32
Hers: 1996 911 Turbo | 1989 325iX |
08-29-2018, 04:54 PM | #4 |
Stop the hate, get a V8
3851
Rep 8,625
How bad is the scoring? Have you performed compression and leakdown tests?
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
08-29-2018, 07:16 PM | #5 |
4452
Rep 4,014
Rebuild and replace are probably not options as those will cost half of what your E93 is worth. Selling and not disclosing would be bad mojo (not suggesting that was your intention). Perhaps go back to seller and see if they are willing to help.
08-29-2018, 08:49 PM | #6 |
1688
Rep 3,140
Drives: 2014 M5 6MT
Scoring is most likely caused by a failed injector. Fuel washed the cylinder causing a lack of lubrication. Previous owner probably got scared of the repair bill and dumped it.
You're better off replacing the engine as thats the cheapest route.
2014 M5 6MT
08-29-2018, 09:42 PM | #8 | |
1688
Rep 3,140
Drives: 2014 M5 6MT
Now the OP has to deal with it.
2014 M5 6MT
08-29-2018, 10:33 PM | #9 |
262
Rep 769
When i was changing my plugs, two of them looked really bad... And they were also 6&7 cylinders. The whole plug was pure black and even the coil was dark brown. Would you think that i have similar thing happening here as well?
08-29-2018, 10:56 PM | #10 | |
1688
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
08-30-2018, 12:59 PM | #11 |
BimmerPost Supporting Vendor
3757
Rep 2,908
Drives: 2011 E93 M3
Scored walls happen. How many miles on the car? Cheapest route would be to find a used engine on the lower end of the cost spectrum and have it installed.
08-30-2018, 08:33 PM | #12 | ||
262
Rep 769
ronniem348.00 |
08-30-2018, 08:44 PM | #13 |
1688
Rep 3,140
Drives: 2014 M5 6MT
You'd have more issues if you had scoring in the cylinders. Those two cylinders are burning oil.
2014 M5 6MT
deansbimmer3756.50 |
09-08-2018, 11:41 AM | #14 |
Rep 6
Fubar_ M3 it is buring oil, however no smoke out the tail pipe, or no burning oil smell. I went into limp mode a few days, and took it to the dealer they had to replace plugs 6 and 7... drove great. He mentioned I can periodically swamp those plugs with others to clean them up...
where is this excessive oil going... |
09-08-2018, 12:00 PM | #15 |
3757
Rep 2,908
Drives: 2011 E93 M3
BMW states any consumption up to 2qts per 1000 miles is acceptable and chalks it up to engine use variables. You don't say how much yours is consuming. You already said you observed scoring in the cylinders. That's what's would cause excessive oil consumption. Piston rings control oil on the cylinder walls. If the walls are scored the rings cannot wipe the oil off as well so you're going use more oil.
You won't smell or see that consumption. The combustion process burns most of it and the catalysts in the exhaust help burn off the rest. |
