XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      08-10-2018, 11:09 AM   #1
jereisluke
jereisluke's Avatar
Drives: 2014 X1 sDrive28i
Maintenance Schedule beyond Factory Maintenance
My 2014 E84 28i ran out of factory warranty and maintenance recently and I'm trying to put together a master schedule for maintenance so I know when to replace what and don't have to worry too much about it. I've got the basics covered based on the manual (oil, cabin/air filters, spark plugs, brake pads/fluid) but wanted to get input on some items not discussed in the manual.
At what mileage do you think these things below should be replaced? I'm using mileage instead of years/time since mine is a daily driver and mileage just seems to make more sense. I looked at Bavarian Autosport’s E91 schedule (https://www.bavauto.com/media/import...ages/e91mc.pdf) as a starting point, but they have a very conservative schedule (more $ for them from people buying parts). I can share the master schedule when it's finished too if anyone is interested.
  • Fuel filter? 60K? (Manual doesn’t even mention this for some reason, does BMW not think this needs to be replaced?)
  • Automatic transmission fluid and filter? 75K? BMW says this is a lifetime fluid, but I don’t buy it.
  • Differential fluid? 75K? BMW says this is a lifetime fluid, but I don’t buy it.
  • Coolant? 50K? BMW says this is a lifetime fluid, but I don’t buy it.
  • Shocks/struts & other suspension parts? 60K or just replace when worn?
  • Timing chain? 100K? Or does it need to be replaced at all if chain/guides have been upgraded from old failure prone version?
  • Drive belts? 60K or just replace when worn?
      08-10-2018, 11:57 AM   #2
mreric
13
Drives: 2015 BMW X1
I have attached the ZF transmission instruction from the manufacturer
according to the manufacturer the tranny fluid should be done at no more than 75K
as for the other stuff... i am not sure..
      08-20-2018, 10:55 AM   #3
thestimp
975
Drives: 22 X3MC MBB - C-17 Globemaster
2022 X3mC  [10.00]
2016 BMW M3  [0.00]
I'm at 80k miles and I'm doing all these things this fall. From what I've read people either say "if you can afford it do it" or, "Its lifetime dont worry". Just pulling the trigger since I plan on having the car another year or 2.
      08-20-2018, 01:31 PM   #4
Chicone
28
Drives: 2015 X1 X35i M-SPORT
As part of this I'm curious how many years factory batteries are lasting before needing replacement. I suppose there are a lot of variables, hotter climates, how long it sat on the lot etc.
Usually at 5 years I start to worry, for me that means next year, but I have not seen any issues yet, but have only had the car a couple months.
-Steve
2015 X1 XDrive MSport //BMS Intake
      08-20-2018, 05:46 PM   #5
Turbod
Turbod's Avatar
396
Drives: 2014 E84 X1 35i M Sport
My BMW dealer said "lifetime fluid" is rated at 100,000 miles. My battery went out on my 335i six years after the build date. I would do your diff when you do the transmission. I would do your coolant when you replace the water pump and thermostat. Suspension is completely up to the driver. I would look to do the timing chain between 100,000 and 120,000. As for the belt system I have heard horror stories about the N55 eating the belt through the crank seal. I don't know if that is an issue for the N20 though. Most N55's are replacing them between 60,000 and 80,000 miles.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      08-20-2018, 07:55 PM   #6
mcdanielvzw
mcdanielvzw's Avatar
144
Drives: 2021 X3 M40i (times 2)
-Steve
5 years for any battery is a lot of time, however I believe companies like tesla went from a 5 to 7 year warranty because they only use 80% of the total capacity, hence they last longer. You still lose range, but it's far less than doing a 0-100 charge every time.
If you mean car batteries, before BMW I looked for replacements every 3-4 years (battery in engine bay with my Mazda 6). I've had good dealing with BMW batteries being in the trunk so far, but haven't had the opportunity to pass the 3-4 year mark as of yet with a single battery. AGMs should last longer of course.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights
Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH
About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake
Sold - 2009 328i - Stock, 195,000 running strong.
      08-20-2018, 11:35 PM   #7
jereisluke
jereisluke's Avatar
Thanks all for the input so far. That's interesting that the BMW dealer basically told you that lifetime fluid doesn't really mean lifetime fluid.
      08-21-2018, 12:00 AM   #8
Turbod
Turbod's Avatar
396
Because only a company would tell you it is. Anyone with any knowledge knows there is no such thing as lifetime fluid. Glad I could help.
2023 G80 M3 xDrive
      08-21-2018, 07:29 AM   #9
bvanlieu
57
Drives: Alpine 335d
Dealers with a clue are aware of this fact. Most US customers never drive their cars this far, so from a point of view it is a life time. BMW lifetime is semantically 100K miles.
All that being said, good plan to do the fluids 60-75K range. IMHO transmission is the biggest one to do: ZF makes a good transmission, and I trust them a bit more then BMW on the maint interval. Most kits come with the Mechatronic sleeve but to me if that is dry leave it be no need to replace. No affiliation, I used https://www.thectsc.com/ for their kit on the 335d. ZF fluid is more but I am fine with that, if not there are a few other fluids that carry the same spec.
While its up in the air, do not forget the transfer case fluid. Its not a lot of fluid, but it is a PITA to get to on the X Drives.
Our N55 just crossed 62K and I plan on doing the driveline fluid change within a year.
- b
      08-21-2018, 12:24 PM   #10
Gamb1t
Gamb1t's Avatar
598
Drives: 330i,X1,Z4,Solstice GXP, RX-8
Pretty sure there is a thread topic on maintenance here. If not check the F30 section.
As for the tranny fluid, I noticed that my local BMW dealership sells fluid and filter kits for our ZF8 despite the whole "lifetime fluid". Interestingly the service dept. refuses to perform the change unless there's something wrong with the tranny.
My car is at about 77k km and I've done all fluid changes except tranny. Will tackle that at 100k km. Or sooner. So far the only tricky one I've experienced is the xfer case fluid. There is a thread about it that I have appended my thoughts and tips.
Modern BMWs come with AGM batteries. They are more advanced than the regular lead ones and are able to cope with the electronic stress associated with modern European cars. That said one of the SA I spoke with told me that weak battery can lead to faulty/false alarm sensor codes. It is a good idea to keep a batter tender and charge the AGM battery every so often to keep it healthy.
      08-21-2018, 06:40 PM   #11
Chicone
28
Originally Posted by Gamb1t View Post
Modern BMWs come with AGM batteries. They are more advanced than the regular lead ones and are able to cope with the electronic stress associated with modern European cars. e the AGM battery every so often to keep it healthy.
Thanks! I had no idea, having driven my last car for 19 years, and a new BMW owner I was unaware of this innovation. Was a bit shocking when I googled it and saw the battery prices.
-Steve
2015 BMW X! 35i MSport // BMS Intake
      08-23-2018, 12:25 AM   #12
Gamb1t
Gamb1t's Avatar
598
-Steve
Yes AGM batteries are about twice the price of a regular ones. It also costs more with BMW requiring an ECU adaptation values to be reset whenever you change a new battery. Reason is so that the ECU will not tell the alternator to over-compensate for your old battery. It's cha-ching for the dealership. More reason to keep your current AGM battery healthy. I've seen some AGMs lasting 10 years with proper conditioning.
BTW that ECU reset can be done through the iCarly app.
xbimmers
