XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      08-08-2018, 09:00 PM   #1
BeeHemDoubleU IksWane
BeeHemDoubleU IksWane's Avatar
16
Drives: BMW X1
Xdrive Staggered setup
Problem
After seeing style 219m wheels on a X1 on this forum I was hooked.
I bought some and wrapped them in COntinental ExtremeContact DWS
245/40/18 front= 808 revs per mile
275/35/18 back = 811
So 3 revs per mile difference...
Heres the problem.. The car stutters when accelerating from a dead stop. Around 10-20 km/h. After those speeds all is normal. Doesn't stutters at highway speeds, smooth as butter.
With those tire size I'm more than in the acceptable range of xDrive. Anyone have an idea what could cause that?
You talk about German technocracy and you get automobiles.
      08-09-2018, 12:41 AM   #2
lmbxcfls
Drives: 2015 X1 35i white Motorsport
My X1 came with the factory staggered 19's (which I swapped for a square set-up -- 18x9's with 255/40's all around. BIG win, all around). In the course of considering options, I noticed that the diameter of the stock fronts was slightly smaller than the rears. But, your set-up is the opposite -- the diameter of the fronts is slightly larger than the rears. Perhaps this is the cause of your problem, even though the actual differences are minor. My BMW mechanic (with whom I've worked over the past ~15 years) tells me that the X-drive system is VERY sensitive to different sidewalls (even very slight differences).
      08-09-2018, 05:44 AM   #3
16
Drives: BMW X1
Thanks for your input.
      08-09-2018, 12:12 PM   #4
mreric
13
Drives: 2015 BMW X1
mine did it a bit too. stock set up.
after i did a diff oil change it went away. so mine was maintenance related.
if you have not changed your diff oil start there
      08-09-2018, 03:53 PM   #5
16
Drives: BMW X1
If I go back to my winter setup it stops doing it. If it was maintenance related I guess it would do it whatever the tires that are on, no?
      08-10-2018, 05:38 AM   #6
0w40X1
34
Drives: 2014 BMW X1 s28i M Sport
I can't imagine diff fluid had anything to do to fix it, but the guy that drove piss outta it during inspection scrubbed the tires in.
      08-10-2018, 11:32 PM   #7
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
Have you tried running that way with the traction control totally off? Does it still stutter
      08-11-2018, 03:23 PM   #8
16
Drives: BMW X1
I Will try that, sounds logic To me but never tried. Will answer back
Thanks
      08-12-2018, 07:01 PM   #9
16
Drives: BMW X1
I tried and it still stutters.
Sometimes it doesnt and sometimes you feel it hard. Not consistent at all
      08-14-2018, 11:48 PM   #10
sayemthree
sayemthree's Avatar
597
Had a stutter in a couple older e84 x3’s. Not on take of normally. More during slight Accel in higher gears. One turned out being a small part in the center diff. On the other when I replaced cheap worn khumos with some quality name tires it went away.
      08-15-2018, 12:42 AM   #11
16
Drives: BMW X1
I have brand new Continental DW. Not what I would call a cheap tire. Maybe the system doesn't like the thread pattern or something..
      08-15-2018, 07:39 AM   #12
kiloTHREE
76
Drives: '13 xDrive28i
Did you register the tire in the ECU? Sometimes the IR sensors can't read your tire tread pattern and you have to manually draw the tire in mspaint and send it to bmw to upload it do your car.
Originally Posted by PrematureApex View Post
What a jackass...
Appreciate 2
KWX125.00
      08-16-2018, 12:09 AM   #13
16
Drives: BMW X1
BMW Canada themselves told me that so laugh all you want....
Do you have a better theory? I'm way below the 1%, the tire pressure is fine, it doesnt do it when I change back To my square winter setup...
      08-16-2018, 07:42 AM   #14
kiloTHREE
76
And you believed them.
I would stop going to that dealership asap and find an indy shop that can do actual troubleshooting instead of a smoke and mirrors show.
What a jackass...
      08-18-2018, 02:40 PM   #15
16
Drives: BMW X1
Again, what is YOUR theory? My setup should be more than fine. It doesnt stutters when I switch back To my square setup. Also, BMW Canada isn't a dealership... Canada as in the Country you know?
If you have nothing else to offer but shit talk you can just ignore the thread you know.
I made it because I'm out of ideas on what could be wrong. The indy shop already looked at it and found nothing wrong. the wheels are balanced, the tire all have the right pressure in them..
I created this thread with hopes that someone else had that problem and fixed it and would share his story.
Again, if you doesn't have anything to offer but being smug then I could do without your replies.
Thanks
PS: looks like I'm not the only one who was told that, eh?
Originally Posted by jdubbsf30 View Post
What type of tire are you running?
Some mechanics at BMW told me that the xDrive system is so picky, that sometimes you have to try multiple types of tires before you find a tread pattern that agrees...
      08-18-2018, 07:16 PM   #16
sayemthree
sayemthree's Avatar
597
Are these wheels the offset as the factory 19?
      08-18-2018, 09:48 PM   #17
16
Drives: BMW X1
I have no idea what is the offset of the factory 19s but the style 219m are
Front et29
Rear et23
EDIT: seems like the factory 19s for the e84 are style 324
Front et30
Rear et41
      08-19-2018, 02:48 AM   #18
0w40X1
34
Ok, now I can see a few things going on.
I have the same offset on 8x18 30et and 9 x18 41 et on s28i
Front is already 1.1 inch narrower factory, and at 120 mph car would sway riithmically to nearly change lanes..
I think traction on rears was grab and throwing power to opposite wheel.
I put 12 mm spacers on front, and stopped it.
I also put less grabby cerammic pads on rear.
Your new rear offset has moved wheels out 15 mm more compared to fronts.
Put some 12 or 15 mm spacers on fronts and none on rear.
Also, those tires are too wide for 8 X18 and 9 x 18, but will maybe work it you try spacers on front first.
Perfect size is 225/40x18 and 255/35r18 or use 8.5 and 9.5.
      08-19-2018, 03:14 AM   #19
0w40X1
34
I ordered x1 to put on those 225/40 and 255/35 which comes soon with michelin sport 4s
That gears down for approx. 4% more power.
      08-19-2018, 10:14 AM   #20
16
Drives: BMW X1
First thank you for your answer.
I was thinking about putting some spacers in the front honestly. Mostly for the looks because I didnt think it could be a solution for my problem.
Second, my wheels are style 219m from the E90 M3 so they are 8.5 front and 9.5 Rear and not 8 and 9
Cheers
      08-19-2018, 11:44 AM   #21
0w40X1
34
Yeah, I looked up wheel numbers, aNd it's a very good look.
Just for fun, why don't you measure width of both axles outside tire to outside tire down near pavement ?
      08-19-2018, 02:27 PM   #22
16
Drives: BMW X1
Honestly ? Because I don't see how that could affect the xdrive system. AFAIK offset doesnt affect xdrive, right? It's all about total circumference, no?
xbimmers
