XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      08-08-2018, 11:17 AM   #1
lilysdad
7x BMW owner
Drives: 2012 X3 F25 xDrive35i
Lighting / bulb questions for X1 with halogens. LED parking lights?
Hi,
I'm a new owner trying to get rid of my yellow halogens and have a few questions.
1. Is there any consensus on the best H7 bulbs that are white but don't burn out quickly? I'm leaning towards the Osram Nightbreakers but I'm wondering if they are white enough.
2. Best white H8 fog replacement bulb as the options seem more limited in terms of H8 selection.
3. Will an LED wedge bulb (194/168) cause any error codes or issues (for the parking light above the high beam bulb)? If so, will a "canbus approved" LED bulb work? Anyone have an LED bulbs they can recommend that you've used?
Thanks for any feedback.
Brian
Present: 2012 F25 X3 Xdrive35i - Sparkling Bronze with Nevada Red-Brown Leather
Past: 15 E84 X1 xDrive28i Sportline, 07 E90 335i, 06 E90 330i, 01 E46 330i vert, 99 E46 328i
      08-09-2018, 12:25 PM   #2
lilysdad
7x BMW owner
Hmmm, pretty dead in here. Maybe I need to post in the E90 forum.
      08-09-2018, 02:20 PM   #3
kiloTHREE
76
Drives: '13 xDrive28i
Most of us have HID's.
I honestly didn't know the X1 came without them in the states.
Originally Posted by PrematureApex View Post
What a jackass...
      08-10-2018, 08:37 AM   #4
lilysdad
7x BMW owner
My first BMW without HIDs.
Xdrive28is with HIDs are surprisingly hard to find in the Southeast.
      08-10-2018, 10:05 AM   #5
MVested
Drives: 2008 335xic AT, 2004 996tt x50
Same! The halogens are surprisingly effective. I just picked up a CPO 2015 28xdrive on Monday and am currently researching my HID retrofit options. If there are any recommendations, they'd be greatly appreciated!
      08-10-2018, 12:21 PM   #6
jd__m4
jd__m4's Avatar
415
Drives: AY M4
Same here in the Northeast- when I was looking, plenty of 28's, very few 35's. Seems like 28's rarely have the HID's, while 35's they're much more common.
I've found quite the opposite- the factory halogens are pretty poor IMO.
Regarding retrofits, there's a thread going a few posts down. We're pretty limited in terms of what's available on the aftermarket scene.
      08-10-2018, 02:30 PM   #7
MVested
Reading through the retrofit you mentioned.
Has anyone done an oem retrofit?
      08-10-2018, 02:40 PM   #8
jd__m4
jd__m4's Avatar
415
Drives: AY M4
I'm in the process of doing so, just waiting for the LED modules to come in (you can see my posts in that thread regarding it). It requires some re-wiring, which can be done insight the headlamp housing, and some coding. It's not too difficult.
      08-13-2018, 07:44 AM   #9
Vidgamer
Vidgamer's Avatar
Drives: BMW X1 e84
Hi,
I put Philips Xtreme Power (Xtreme Vision might be an equivalent) in a couple of cars. The replacements were brighter and slightly whiter, but still look like yellow-ish halogen. This is probably the best replacement if you just want "better light" and not "whiter light".
Philips makes a blue-tinted bulb that will give a whiter light, but the output will be reduced.
Use of a non-halogen bulb will probably not be "street legal". Whether that matters depends on your locality. Using a simple kit to substitute a different type of bulb will have a different throw-pattern to the light, and may not work well.
I saw that Philips offers an LED fog option. I guess the regulations are different for the fog/driving lights? I would be tempted to go this route, but don't know if it would clash with the main headlights, even if you used blue-tinted ones.
Brian
The only interior light I replaced was the trunk light. The description said it was canbus-safe, and it has worked fine. Very bright LEDs.
Unfortunately, my car seems to be missing harnesses for some of the interior lighting that is available in upgraded models (footwell lighting, puddle lights..), so I dunno if I want to do anything else.
xbimmers
