10-12-2014, 08:18 PM | #1 |
Rep 33
Storing in winter - suggestions?
I'm looking into stroing the car in the winter in my garage for 4-5 months. I've done a lot of research and talked to several people and EVERYBODY seems to have different opinions on this. Assuming I have a trickle chrager hooked up and cover over the car, will that be sufficient?
Will the tires develop a flat spot? (some people said YES, some said NO). Should I keep a full tank or very little gas? (I understand the moisture thing with a little gas in the tank but then a full tank goes bad - I've heard adding 100 percent octane when ready to go in the spring should be fine??). Most of all - should I start it every 2-3 weeks or let it rest (I know the most damage is done when you start a car but going 4-5 months without ANY engine lubrication, can that be OK?? Thanks- |
10-13-2014, 03:16 PM | #3 |
11
Rep 46
I've stored my Boxster since 2001 ...
I do the following:
Inflate tires to 50-60- lbs. Never had a flat spot problem. One year I put plywood underneath the tires. Don't think that made a difference. Fill up the tank, put in some Stabil, and drive it a few miles. I use a trickle charger plugged into my cigarette lighter. I shove a rag in the exhaust pipe just to keep critters from making a nest. Put the car in gear, but don't engage the parking brake. Manual tranny. Finally, cover her with a nice fitted cover. Have done it this way for the last 12 years without any problems. Last edited by jmr986; 10-13-2014 at 11:03 PM.. |
10-13-2014, 03:27 PM | #4 |
26
Rep 38
The M4 Owner's Manual states on page 139, "Do not connect battery chargers to the factory-installed 12 volt sockets in the vehicle as this may damage the vehicle battery due to an increased power consumption."
Does this make any sense at all??? |
10-13-2014, 05:11 PM | #5 | |
46
Rep 102
Drives: 2006 M3 ZCP IB/IR
10-13-2014, 07:42 PM | #6 |
386
Rep 2,989
Jmr986 pretty much covered everything. The only thing that I might add is that I would fill the tires to the max psi, whatever that might be, printed on the sidewall.
Also, in addition to plugging the exhaust pipes (use steel wool vs rags), I would put some moth balls on a dish or a piece of foil in each of the wheel barrels. |
10-13-2014, 07:49 PM | #7 |
2942
Rep 4,088
Hmm... winter tires, window scrapper and De-Icer
dreventador102.00 enginediver64.50 |
10-13-2014, 11:05 PM | #8 | |
11
Rep 46
Oh and make sure your tailpipe is cooled off before you cover it. Melted some fabric to the pipe! |
10-14-2014, 06:19 AM | #9 |
386
Rep 2,989
Some porsche guys have found wiring damage and rodent "deposits" all over the interiors of their cars. But they can't jump all that well, so putting moth balls in the wheel wells should prevent them from getting in. I would try to avoid putting them inside the car though as the smell might be hard to get rid of
10-14-2014, 09:20 AM | #11 |
142
Rep 555
I have no experience with storing a car and am worried about hooking up a battery charger. How long would you guys go between start-ups and short drives in the winter instead of storage?
thanks |
10-14-2014, 09:51 AM | #12 | |
71
Rep 148
I could see where there could be a possibility of putting too much amperage through the 12 volt "socket" circuit. This is probably one of those issues where 99 times of 100 you wouldn't have a problem. But no. 1 of 100 hooks up an industrial battery charger and fries half the electrical system. |
10-14-2014, 01:13 PM | #14 |
24
Rep 206
Drives: 2000 Z3, 2015 M4
I'm in the Charlotte NC area so no issues here driving the car in the winer for the most part.
2000 Z3 2.3 2011 328 |
10-14-2014, 01:43 PM | #16 |
54
Rep 121
Drives: 2015 M3
Aren't the 12V sockets all switched power? What good does attaching a trickle charger to a switched off outlet do?
10-14-2014, 01:51 PM | #17 |
230
Rep 3,899
What trickle chargers are people using? I've got a charger I used previously but apparantly this cannot be used with the new lithium battery ?
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold 2010 JZB E90 M3 DCT - Sold 2009 6MT E90 LCI 335i M -Sport - Sold |
10-14-2014, 02:01 PM | #18 |
21121
Rep 20,741
Drives: 2021 911 turbo
I interpret this warning the other way around. If you charge the batteries of external devices using the 12V outlet, you will drain the car's battery.
10-14-2014, 02:52 PM | #19 |
70
Rep 291
Hear, hear!
F80 6MT. In full color.
10-14-2014, 03:19 PM | #22 |
2942
Rep 4,088
On the plus side, this may help with the charger issues.
http://f80.bimmerpost.com/forums/sho...d.php?t=964593 |
