06-23-2008, 08:06 PM | #1 |
11
Rep 144
Drives: 2015 SS M5
Lets talk DCT in reverse gear
I think I put the old SMG in the automatic mode twice in 5 1/2 years. The DCT seems to always behave like an auto in R, meaning it starts to roll without any gas. This is different than the SMG. I would prefer the car not do this. Any thoughts.
Also quickly, how do I get the key to remember to stay in S4 not S3?
2015 M5 Silverstone, black full leather, 20s.
2008 M3 Sparkling Graphite, black extended (gone) Everything else but the 19s and HD radio. 2003 M3 Titanium Silver (gone) |
06-23-2008, 10:50 PM | #2 |
37
Rep 1,413
06-23-2008, 10:53 PM | #3 |
152
Rep 5,124
06-23-2008, 10:56 PM | #4 |
37
Rep 1,413
06-23-2008, 11:48 PM | #5 | |
127
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
Example, my driveway has a very slight incline from the house to the street. If my car is in the driveway and I go to back out, I can put it in reverse and if I don't touch the accelerator it will roll toward the street the same as if I had left the car in neutral. However with the car in reverse and I touch the accelerator briefly (a small quick tap), it will back toward the street slightly faster as the low speed assist slips the clutch in reverse and powers the car backward.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
06-24-2008, 12:01 AM | #6 |
611
Rep 10,407
This topic has been discussed quite a few times. The car always defaults to S3 then when you switch to D is remembers your last used D setting. As far as memory goes some things are stored on the key others not.
Power (Throttle map) EDC Shift lights Are stored on the key Drivelogic mode D or S DSC Servotronic (steering boost) Are not stored on the key It sucks, poor decision. A nice workaround would have been making the M button toggle through 3 different settings and have all M functions stored to the key as well. |
06-24-2008, 12:03 AM | #7 |
Moderator
7515
Rep 19,368
I don't think so.
It seems as though only the settings that are available on the center console buttons are assignable to the key, minus DSC for safety reasons. That is to say, just Power and EDC. M-DCT and Steering (and DSC) must be set via M-Drive. In fact, I am not even sure that Sport-Plus Power can be set to the key, it might just be Sport or Normal only. This makes some bit of sense. It means that the key-assignable settings are completely independent from whether the car is equipped with MDrive (ZTP), thus making things easier to develop and test. This is, of course, all just software and could be fixed or changed at a later date. In fact, theoretically, it seems that both MDrive and non-MDrive cars alike could be given complete customizability of all adjustable settings via this interface. Though this would probably diminish the value (be it perceived or otherwise) or the MDrive system. After all, many (if not most) people seem to hit their M Button each time they get in the car. But, if those settings were able to be programmed to the key, then the M Button's use suddenly becomes much less frequent and thus its presence a bit more superfluous. And then perhaps fewer people would equip ZTP. Of course, it would still be nice to have the M Button if for no other reason then to go from S5 and MDM into S6 and DSC-off mode for using LC or track use. |
06-24-2008, 12:27 AM | #8 |
73
Rep 1,603
Drives: F80 M3
A small software tweak would be nice here... c'mon BMW.
2015 SO/SO MT M3 :: Exec : Lighting : Adaptive : HK : CF trim : Full leather : DAP : Black 19's : sunshade
Crystalline tint 40%/70% on windshield : M performance mirrors, spoiler, splitters : Status Gruppe CF lip : RKP diffuser : Fully dechromed Bavsound Stage 1 : V1 Savvy hardwired : Self-coded |
06-24-2008, 08:51 AM | #9 |
127
Rep 3,071
I've used my M button maybe 8 times in the 2 months I've owned the car.
06-24-2008, 01:27 PM | #10 |
11
Rep 144
Drives: 2015 SS M5
I think it was the assist. I must have been on a down slope and barely touched the gas, which got the car rolling. The car gets going much more easily in R than in 1st.
Regarding the memory, the old car stayed in the last shift speed setting. May have to speak with the dealer about this. Also have to read the book, but have been working too much.
06-24-2008, 01:49 PM | #11 | |
108
Rep 1,161
If you don't want the car to go in reverse, than don't put it in reverse. Either that or use the brake pedal. I don't see this as an issue whatsoever |
06-24-2008, 05:43 PM | #12 | |
11
Rep 144
Drives: 2015 SS M5
Regarding your statement "If you don't want the car to go in reverse, than don't put it in reverse" , you are stupid. It should read "thEn don't put it in reverse. See the difference, d-bag.
06-24-2008, 06:21 PM | #13 |
Rep 436
Mine seems to act more like a manual in that it won't start moving backwards in reverse unless you press the gas. A light tap will put it into creep mode in reverse (until you come to a dead stop, similar to 1st gear).
Does the DCT have hill assist like the manual tranny? |
06-24-2008, 06:22 PM | #14 | |
837
Rep 46,029
06-24-2008, 06:31 PM | #15 |
11
Rep 144
Drives: 2015 SS M5
I probably only have about 50 miles on the car, but the DCT is really great. I took someone for a ride today and tried D mode. The shifts were imperceptible but I still probably will not ever use D. I don't think I can ever go back to using a clutch pedal.
06-24-2008, 06:42 PM | #16 | |
837
Rep 46,029
yah they did an awesome job with SMG making it "feel" like a manual car that anything that comes on M3 is expected to have at least some characteristics of a manual car. treat it as DCT, not as an improvement from SMG |
06-24-2008, 07:37 PM | #17 | |
108
Rep 1,161
You are missing the point. The DCT is an automated manual and as a result, some of it characteristics are meant to resemble a manual, if you prefer it no do this then get the 6mt. As for the default S4 vs S3, a simple would have found the answer. |
