KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
06-22-2008, 09:14 PM | #1 |
108
Rep 1,161
Pilot Sport Cup,
Anyone planning on getting a set of these- They look sweet.
http://www.tirerack.com/tires/tires....=(Y)&minLoad=S ilot Sport Cup Track & Competition DOT radials benefit from the same attention to detail that has earned Michelin repeated successes at major endurance races like the 24 Hours of Le Mans, 12 Hours of Sebring and Petit Le Mans at Road Atlanta. The Pilot Sport Cup was developed for competitors who participate in autocross and track events, as well as for serious drivers on the road. Used as Original Equipment (O.E.) on several prestigious vehicles, like the E92 BMW M3 and Porsche Turbo and GT2, Pilot Sport Cup tires meet all the requirements for road use as well. The Pilot Sport Cup features a dual zone, side-by-side tread compound with the outboard compound optimized for dry traction and handling while the inboard compound is focused on wet traction. These tread compounds are molded into a 6/32” deep asymmetric tread design that features a massive outer shoulder rib to further enhance steering response and cornering stability while circumferential grooves and independent tread blocks on the tread design’s inboard portion enhance wet traction. While Pilot Sport Cup tires do not require being shaved for track use, their lap time performance will improve slightly if shaved to between 3/32” and 4/32” deep tread, however this will sacrifice significant tread life. The tire’s internal structure includes two full-width, steel belts reinforced with Michelin’s Banded At Zero (BAZ) technology to stiffen the tread area and help prevent contact area distortion during aggressive acceleration, cornering, braking and high speed use. The Pilot Sport Cup radial’s basic sidewall materials and architecture have evolved from Michelin’s Max Performance Summer tires. The dimensions of traditional front and rear companion sizes were developed to avoid diameter differences that can adversely affect electronic driver’s aids and all-wheel-drive systems. Original Equipment Pilot Sport Cup + (Plus) tires for BMW and N-Spec tires for Porsche applications feature a slightly different tread design with a thin circumferential groove around the outboard shoulder. |
06-23-2008, 02:43 AM | #3 |
597
Rep 5,448
the PSC'c will only last on a heavy car like the M3 if you have added neg camber in the front. better to run 265 in the front and rear too.
I think the next track tire I try will be the BFG R1 tire - BFG is owned by Michilin too! Its rated high in all the tests I have seen.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
06-23-2008, 11:12 AM | #4 |
1118
Rep 8,016
If you are intending to drive to the track and home again on the same tyres then PSC will be one of the best options but if you want another rim/tyre combination for trackdays then go for a proper race tyre. Though getting enough heat into them would be their biggest downfall.
06-23-2008, 11:21 AM | #5 |
597
Rep 5,448
footie - do you get the PSC with the 19 option over there? we get the PS2 with the 19 in the USA.
I normally drive to and from the track on my track tires.
06-23-2008, 12:45 PM | #6 | |
1118
Rep 8,016
As an example I got to drive an AW manual M3 a month ago which was fitted with Cup+ and it was damp (not soaking), well the car had 900miles on it and even on part throttle to stop myself from shotting over the 5500rpm mark the tail was dancing all over the place. Grip was decidedly thin on the ground that day. |
06-23-2008, 01:09 PM | #7 |
597
Rep 5,448
i've driven on the PSC in rain at 80mph no problem - but I wouldnt want them as every day drivers - in any case we get the 19 " PS2 here.
06-23-2008, 03:56 PM | #8 | |
1118
Rep 8,016
Though until I get to try the PS2s I will not know how much better in this situation they will be. |
06-23-2008, 11:49 PM | #9 |
597
Rep 5,448
I have found DOT track tires to have pretty decent mechanical grip in the wet - as long as its not deep enough that the lack of treads can not evacuate the water. they are also worse over rubber build up and oil when wet.
06-24-2008, 09:13 AM | #10 |
M3Post Supporting Vendor
87
Rep 964
The sport cup is a great tire for really hardcore street performance (but keep in mind that hydroplaning resistance is limited), or for moderate track use. It will not be competitive against slicks, but for drivers who do lapping days, driving schools or other fun-oriented track events they offer excellent grip and handling, and surprisingly good wear for a track tire.
_______________________________________________
I have accepted a new position at Tire Rack and am no longer in the sales department. gary@tirerack.com is available to assist with M3 questions. |
06-24-2008, 09:40 AM | #11 | |
Moderator / European Editor
1512
Rep 6,754
Best regards, south
06-24-2008, 10:58 AM | #12 | |
1118
Rep 8,016
It's a little bit surprising to find the in Europe they are standard on 19" and not an option for someone to tick with full knowledge of what they are getting. |
06-24-2008, 11:49 AM | #13 |
597
Rep 5,448
agree the are great tires - but a stock e46 heavy M3 will destroy the fronts very quick (especiually in stock 225 size) with stock camber. I went to 265 all around and that was better.
06-26-2008, 09:54 AM | #14 |
Ground Pilot
41
Rep 548
Drives: e92 BMW M3
How much worse is the treadwear on the Cups over the PS2s?
"The laws of physics cannot be repealed, even with DSC." - BMW Owner's Manual
06-27-2008, 12:35 AM | #15 |
597
Rep 5,448
i think its like 80 vs like 180?
or check tire rack.
06-27-2008, 08:48 AM | #17 |
Ground Pilot
41
Rep 548
Drives: e92 BMW M3
Wow, that will get expensive running those everyday.
My friend runs them on his 997 GT3 without having to replace them all the time, but he doesn't run it everyday. If it rains or he has to take the kids somewhere, he runs the M5.
06-27-2008, 11:24 PM | #18 |
48
Rep 1,664
I wish PSC came stock with the 18's here, that would make the perfect track setup...
2008 E92 M3 Jerez Black,DCT,Fox Red ext,Prem,Tech,19", ipod/usb, CF roof and trim
2010 E91 328i Space Gray,Black int, M sport, most options 2007 Montego Blue 335i (retired) |
07-03-2008, 06:02 AM | #19 |
24
Rep 56
My car in Germany came with PSC+. They are standard with 19in wheels here.
They are brilliant as long as it is not wet. 3 weeks ago I was driving from Dresden to Frankfurt in a storm. Up to 110 kmh it was just fine. Anything above that and the tail was dancing.... dancing in a scary way if you know what I mean. No grip whatsoever. Bit of a silent murderer..... I think that for the peace of mind I will go with regular PS2 next time. |
07-03-2008, 03:12 PM | #21 | |
1118
Rep 8,016
