07-08-2018, 05:03 PM | #1 |
205
Rep 330
Front Strut Foam Piece?
I know little about suspension components. What is this foam piece that is deteriorating on the top of the front strut? Bumpstop? I have EDC if that matters. 65k miles.
Can these be left alone in current state? Last edited by delirium330; 07-08-2018 at 05:19 PM.. |
07-08-2018, 05:08 PM | #2 |
567
Rep 1,368
These are the bump stops.
Fairly easy to replace |
07-08-2018, 05:09 PM | #3 |
205
Rep 330
Thanks, just drop the strut down from the tower and slide new ones on?
Looks like part # 31302283444. https://www.ecstuning.com/b-genuine-...r/31302283444/ https://www.realoem.com/bmw/enUS/sho...diagId=31_0805 #8? Last edited by delirium330; 07-08-2018 at 05:16 PM.. |
07-08-2018, 05:43 PM | #4 |
567
Rep 1,368
Yeah, I'd review a DIY for installing springs for more detail.
07-08-2018, 05:56 PM | #5 |
205
Rep 330
07-14-2018, 01:31 PM | #6 |
205
Rep 330
Just checked my rears as well. Should I replace these also? Looks like some deterioration just starting. Looks like part #33532283445.
https://www.ecstuning.com/b-genuine-...r/33532283445/ |
07-14-2018, 02:07 PM | #7 |
4452
Rep 4,014
Not an easy DIY for a first timer by yourself. I would say it's a 7.5 on a scale of 1 to 10. And quite honestly I don't know how important it is to replace just the bump stops. Haven't read yet where any member has said it is pertinent to change them out.
07-14-2018, 02:45 PM | #8 |
2383
Rep 3,736
Drives: 2018 M2
Don’t people usually swap them out for E46 bump stops
07-14-2018, 03:39 PM | #9 |
205
Rep 330
Front, Rear or both are 7.5/10? Have done a ton of DIY under the hood, but pretty limited on anything suspension related. Brake and rotor replacement closest I have gotten.
07-14-2018, 04:10 PM | #10 | |
4452
Rep 4,014
For the fronts access is fairly easy but there is quite a bit going on. Takes me about 45min or less to change out a front strut now. Find a diy and go for it. |
07-14-2018, 08:17 PM | #11 | |
205
Rep 330
07-15-2018, 12:51 PM | #12 | ||
4452
Rep 4,014
Not sure if this will do the trick. Has your bump stops also. |
08-06-2018, 05:05 PM | #13 |
205
Rep 330
Just getting back to this to decide if I should tackle this work. Can anyone weigh in on if I actually need to address those bump stops? FWIW I got a $600 quote from a local indy.
08-06-2018, 05:07 PM | #14 | |
Stop the hate, get a V8
3851
Rep 8,625
It doesn't look terrible, so I'm not really sure it's a pressing issue that needs your immediate attention. Keep an eye on it. You might be able to go another year, for all we know.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
08-09-2018, 11:05 AM | #15 | |
205
Rep 330
What symptoms would appear if they start to deteriorate too much? |
08-09-2018, 01:18 PM | #16 | |
229
Rep 415
Glorified dust cover. You won't see any issues with the drive - it's just there to keep the insides clean. If they are front struts then you can't just swap them - you need to compress the spring to get it out, too much work for a simple dust cover. Don't worry about it. |
08-09-2018, 07:45 PM | #17 | ||
1688
Rep 3,140
Drives: 2014 M5 6MT
OP They are there to prevent/ reduce the chances of bottoming out the strut. which can destroy it. They are important, and it needs to be addressed.
2014 M5 6MT
08-10-2018, 12:12 PM | #18 | |
229
Rep 415
The orange portion is the bump stop which looks pretty intact. Correct me if I am wrong. |
08-10-2018, 12:15 PM | #19 | ||
1688
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
08-10-2018, 12:28 PM | #20 |
229
Rep 415
08-10-2018, 03:19 PM | #21 |
BimmerPost Supporting Vendor
3755
Rep 2,907
Drives: 2011 E93 M3
There is a grey plastic sleeve that is supposed to fit over rear the foam bump stop. It's there to keep the shock shaft clean which prolongs the shaft seal life. It's still on the OP's car from his pics. When the bump stop deteriorates that grey dust cover sleeve falls down onto the shock body and stops protecting the shaft. That happens when the bumpstop gets really bad.
The bump stops keep the shock from bottoming out which damages its internals. How much your bump stops are needed depends on your roads and driving styles. If you never bottom out then the bump stops aren't really doing much anyways. |
