06-04-2018, 09:37 AM | #1 |
457
Rep 539
Snapped off wheel lug bolt in hub
Hi guys, over the weekend I was washing my car and I noticed that I was missing a lug bolt on the front passengers side of the car! After carefully getting the car home I noticed that he bolt had snapped off inside the hub and I am nervous that additional bolts will do the same. I'm running a 12mm spacer up front but have asked the shop to remove all spacers around the car and bring it back to stock.
Anyone had this happen before? Is it possible to drill out the remaining part of the bolt inside the hub and without damaging the hub??
CP-E DP's / Remus Race / ETS 7" FMIC / AFE DCI / Cobb V3 / ETS CP / HKS BOV
06-04-2018, 09:42 AM | #2 |
BimmerPost Supporting Vendor
3752
Rep 2,907
Drives: 2011 E93 M3
No big deal. Drill and remove it. You can do it yourself in a few minutes with a tool like this, which any shop should have on hand. FYI your wheel isn't going to fall off just because one lug is missing.
https://www.amazon.com/Neiko-01925A-...xtractor&psc=1 |
06-04-2018, 09:45 AM | #3 | |
457
Rep 539
06-04-2018, 09:49 AM | #4 |
Stop the hate, get a V8
3851
Rep 8,625
Are you using OEM parts, or is this an aftermarket wheel/bolt setup?
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
06-04-2018, 09:55 AM | #5 |
457
Rep 539
Stock zcp wheels with MS spacers and bolts, nothing fancy and out of the ordinary
06-04-2018, 10:05 AM | #6 |
3851
Rep 8,625
I would talk to MS about those bolts. Might be a bad batch or something.
06-04-2018, 10:35 AM | #7 |
404
Rep 1,171
Just curious about the lug bolts strength. Are they stamped 10.9 on the bold head? I always buy H$R spacers and bolts because they are 10.9 and made in Germany.
06-04-2018, 10:37 AM | #8 |
92
Rep 393
Drives: ///M3
What torque setting are you using when tightening your wheel bolts?
2009 BMW E93 6MT///M3 - SG/FR
2011 BMW E90 DCT///M3 - JB/FR (Sold) |
06-04-2018, 03:29 PM | #10 |
457
Rep 539
I torqued them down to roughly 35ftlbs so I don't think over tightening them was the issue. Shop said they can't repair the hub and have to replace it.. not good at all!
06-04-2018, 03:33 PM | #11 |
404
Rep 1,171
06-04-2018, 04:15 PM | #13 | |
e90noob
1588
Rep 1,862
for wheel bolts (as well as wheel lugs for the studs), they should be torqued at 88 ft/lb
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22 |
06-04-2018, 04:32 PM | #14 |
8247
Rep 18,837
Drives: BMW
Or driving on lugs that are not properly torqued/loose. Replace if unsure to be on the safe side.
06-05-2018, 08:28 AM | #15 |
336
Rep 724
Under torquing fasteners leads to fatigue failures.
https://www.asminternational.org/doc...mp17208p18.pdf You likely need to replace all of your lug nuts, even the ones that did not fail (yet). If you can post a picture of a failed surface, this mode of failure can be verified. I suspect there will be a large area that is flatter (indication of fatigue). |
06-05-2018, 09:20 AM | #16 |
457
Rep 539
Hi all, I had to replace the entire hub it was unrepairable. We were unable to successfully drill out the old stud, it came downs to the studs being a few years old and they just failed. All are replaced now, spacers removed and back to stock. I mislead you on the torque I put onto the bolts, they were all at ~80ftlbs so torque was not an issue
06-05-2018, 10:03 AM | #17 | |
92
Rep 393
Drives: ///M3
Not sure where you're getting this information from.
06-05-2018, 10:10 AM | #18 | |
1341
Rep 1,881
On a daily driver its recommended to change every 2-3 years, on a track car probably more often depending on use. |
06-05-2018, 10:13 AM | #19 | |
92
Rep 393
Drives: ///M3
If you are tracking your car then I agree you should be replacing or upgrading your wheel studs/bolts due to the extra stress.
2011 BMW E90 DCT///M3 - JB/FR (Sold) Last edited by JDM_CL9; 06-05-2018 at 10:27 AM.. |
06-05-2018, 10:21 AM | #20 | |
404
Rep 1,171
06-05-2018, 12:16 PM | #21 | |
3851
Rep 8,625
I have only seen that from overtorquing, often from morons at wheel/tire shops not checking the spec on their wrench or just using an impact gun and smashing them down to 200.
06-05-2018, 01:23 PM | #22 | |
2631
Rep 2,141
Drives: 2011 E92 M3
If you have other information, please share with the community. Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... |
