06-17-2008, 08:02 AM | #1 |
261
Rep 1,238
Drives: 2020 X6M Competition DG
RPM sweet spots on 6MT
OK folks, I hope I don't get any heat from this question.
I've driven manual in the past but it's been awhile so I'm some what relearning my techniques. At what RPM's are you guys shifting to get the most power of our cars? Launching techniques? Thanks Anthony |
06-17-2008, 11:15 AM | #3 |
156
Rep 1,429
4k seems too high for a launch. I launched at 3k and it just burned the tires. And I've actually found that shifting is a little smoother ~7500 than redline.
06-17-2008, 11:30 AM | #4 | |
837
Rep 46,029
i find dumping at 3500 is good for slow/normal driving to get a smooth shift i shift at 3k. for a bit more than normal 4-5k shifts are nice. what matters to me is when i get into a higher gear i want to be over 3k rpm to feel some torque. any shifts that make ur RPMs go below 3k make u feel the car is hella slow. just no torque (that's acceptable by me anyway) the problem with shifting at 5k is once i get there i cant stop so i go to redline |
06-17-2008, 12:42 PM | #5 | |
523
Rep 5,483
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
06-17-2008, 12:52 PM | #6 |
1120
Rep 8,017
Controlling wheel spin is an art which few people ever master. The M3 may be similar to the TVR's of old which you basically part throttled through first until about 5500rpm before giving full throttle. I too reckon a launch of 3000rpm would be best unless the surface was super sticky.
06-17-2008, 12:54 PM | #7 |
837
Rep 46,029
^^ slipping vs. dumping the clutch?
edit: u mean go partial throttle, rev to 5k then dump clutch and go full throttle? if that's what u mean the M3 will spin like crazy |
06-17-2008, 01:06 PM | #8 |
1120
Rep 8,017
No I mean maintain partial throttle up to 5k after you have dropped the clutch, though remember that this was what we done on a TVR which had similar amounts of torque and weighed only 1100kgs. The whole objective is to stop wheel slip without bogging the engine down, part throttle might mean almost 7/10th in an M3.
06-17-2008, 01:08 PM | #9 | |
837
Rep 46,029
06-17-2008, 09:15 PM | #14 |
21
Rep 362
I've seen a few posts about wheel spin here. I haven't tried a drop clutch launch on the M3 yet. But, coming from a high RPM car, some wheel spin is desired at times. To launch my no torque S2K you actually need drop with enough RPM so that when the tires do hook up, you are in the middle of the power band. Now the M3 has a lot better torque/weight ratio, a better clutch and a flatter torque curve. Are people seeing that they are sitting still and just spinning the tires in the M3 or are you getting forward motion and then pulling hard once the tires hook up around the in the middle of the torque curve? The latter may be faster. I think R&T hit their 12.5 qtr with a 3500-4000 clutch drop.
