06-01-2018, 09:15 AM | #1 |
Rep 3
Cold start issues
Hello, I drive a 2014 X1 x28i
I am experiencing issues on cold starts where the vehicle is loud and feels like it will stall(see video links below)Any starts after the 1 st start is fine and runs normally. I have uploaded videos to: Vimeo.com/272041314 Vimeo.com/272104272 I have taken it to the dealership and they have scanned it with no issues/errors and their only solution is to update the software and even implying that this is normal for BMW x1. I have also checked the battery and is has a good charge and not an issue Any help is appreciated ! |
08-20-2018, 08:19 AM | #2 |
975
Rep 1,701
Drives: 22 X3MC MBB - C-17 Globemaster
Battery or fuel pump. I know you said battery is fine, but that hesitation while the starter cranks is usually a sign of low starting amps, yes it probably hits 14.xx but the cranking means its loosing its initial push. The weird starting is usually a sign of a failing fuel pump because it cant prep the lines fast enough on a cold start.
I just went thru the above scenario, I could be wrong, but thats what fixed it for me. I did new plugs, pump and battery. All better now. |
11-04-2018, 08:21 PM | #3 |
Rep 10
Could also be the Vanos solenoid. It is a common failure of the e84's and can affect idling during cold start.
01-29-2019, 08:33 PM | #5 | |
Rep 5
01-29-2019, 08:35 PM | #6 | |
Rep 5
03-24-2019, 05:27 PM | #7 |
I /// M FAN
424
Rep 427
Did you connect Ista-D to check any code errors? When mu X1 28i did that I had a misfire error from the cylinder #2, I replaced the spark plug and the trouble was gone. The car had 58 000 km and was the original set of spark plug
03-25-2019, 01:23 AM | #8 | ||
2709
Rep 2,350
Anyway, Went to the dealership several times for the problem. Nothing found. After several similar complaints form other clients my mechanic found the problem: the gasoline. I always buy the 91 Shell. He suggested the higher 94 octane from other providers like PetroCanada and Esso (Shell doesn’t have it). He was right. As soon as I put 94 the issue was gone. All the customers that complained with this problem -including M vehicles- solved the issue with a higher octane. All of them complained about the same behaviour in cold. Hope it helps! |
03-25-2019, 04:24 PM | #9 | |
I /// M FAN
424
Rep 427
