05-31-2018, 05:33 PM | #1 |
53
Rep 450
Just purchase a 13 35d...can you rec a transmission kit?
Just bought (and am loving) a 13 35d with 90k.
Looked quite a while to find one that drives this nice with the multicontour seats and no sports package. I'm going to start preventative maintenance and would like to have recommendations for a transmission filter/fluid kit for my 6spd. I'm also going to change diff fluids while I'm at it, so if you have any recommendations there, please share. Thanks for any help!
06 330i 6mt Spt- Eibach Springs, BMW Perf Susp, Supersprint Exhaust, BSW Audio
RIP-94 325i 5mt 4d- M3 springs/susp, Z3 wheels, Chipped, Intake, Exhaust= FUN! |
05-31-2018, 08:48 PM | #2 |
56
Rep 415
06-01-2018, 01:07 AM | #3 |
211
Rep 433
Any idea why this kit is more than the second link?
https://www.fcpeuro.com/products/bmw...27kit2#reviews http://www.thectsc.com/products/oil-...ce-186-61.html |
06-01-2018, 05:03 AM | #4 | |
245
Rep 561
Drives: 2018 M5 / 2011 X5 35d
- FCP offers a lifetime warranty on all their parts so naturally they will be priced higher - The FCP kit comes with 7 liters of ZF trans fluid (each liter cost $25-30) the CTSC kit only comes with 6, if you are dropping the valve body to replace the seals (highly recommended) you may require up to 7L of fluid - The FCP kit comes with a full set of screws and the CTSC only comes with 5 or 6 I believe.. this is not that big of a deal. |
06-01-2018, 07:06 AM | #5 | |
245
Rep 561
06-01-2018, 10:57 AM | #6 | |
211
Rep 433
06-01-2018, 12:29 PM | #8 | |
53
Rep 450
There was a mileage-maintenance chart available for the e90 that was a great guide as to what to replace and when. Has anyone made a similar list for the 35d? I plan on keeping this car to at least 175k and I'd like to get all the preventative taken care of.
06-01-2018, 12:49 PM | #9 | |
211
Rep 433
Keep an eye on the thermostat temp, water pump for leaks. harmonic balancer, sunroof drains, change the engine partition cowls if broken (water will drip down onto injector 5 & 6) I even removed the yellow sound deadening foam and the crankshaft pulley That's all I can think of right now. I just the the dpf, scr, egr, and urea tank delete and running a JR stage 2.8 tune
2012 X5d | Deleted & BRR Tuned | DWR TCU Tune | 10.25" Android 8.1 Screen
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 Last edited by sunny_j; 06-01-2018 at 02:39 PM.. |
06-01-2018, 02:36 PM | #10 |
245
Rep 561
I would 100% recomend you do the seals, if you are dropping that pan you might as well take an extra 30-45 minutes and do the seals.. I was at 121k and my seals were already shot, you can tell because they were sitting flush with the valve body.. they should stick out a little bit to make the proper seal. My shifting was jerky between 2nd and 3rd.. after everything was serviced the transmission is buttery smooth.
06-01-2018, 02:39 PM | #11 | |
245
Rep 561
06-01-2018, 03:48 PM | #12 | |
53
Rep 450
Did you keep the dpf stock?
06-01-2018, 03:50 PM | #13 |
211
Rep 433
no, the new Buzzken down pipe with DOC replaced the factory dpf
Build Thread https://www.xbimmers.com/forums/show....php?t=1529213 |
06-03-2018, 05:30 AM | #14 |
53
Rep 450
Here's what I'm planning on getting. Figured I'd get enough bolts to do them all while I'm at it.
Anything else you guys recommend? Last edited by thecadman99; 06-03-2018 at 05:44 AM.. |
06-03-2018, 07:28 AM | #15 | |
245
Rep 561
Also make sure you got some long angled needle nose pliers like these (YaeTek 4-Piece Needle Nose Pliers Set, 4-Piece (16inch) https://www.amazon.com/dp/B01KV261HM/ref=cm_sw_r_cp_api_i_YR9eBbDBGRER4) so you can remove the old sleeve, that was a PITA. Make sure you watch this video 2-3 times before you do anything.. specially the part (26:00) where he had to drop the pan again because he forgot to make sure the gear indicator was in place correctly.. I almost made that mistake. https://youtu.be/dCvmdo1bLLw |
06-03-2018, 07:30 AM | #16 |
389
Rep 1,623
06-03-2018, 08:41 AM | #18 | |
53
Rep 450
06-03-2018, 05:14 PM | #20 |
53
Rep 450
Wow, I don't think we could be much father apart and still be in Virginia
06-04-2018, 05:43 PM | #21 |
346
Rep 728
Good luck with this...I knocked it out a month ago and was pretty straight forward if you follow the video. The only trouble I had was from inexperience. I filled the tranny with 3 liters until it leaked out of the fill hole (just like in the video) then sealed it up and tried to shift through the gears. It didn't shift. I thought I messed something up so I tore it apart again. Turned out I just didn't have enough fluid in it once it warmed up. I had to wait and add more then shift through the gears. Make sure you point your fill hose toward the front of the vehicle so it can get all the way in. It was a nice $230 mistake ($180 of fluid, $50 new mech sleeve at the dealer). Also, be careful when reinstalling the mech sleeve, you can bend the prongs on the mech unit if you're not careful.
2020 G01 X3 30e CURRENT M Sport Package 2019 Ford Raptor SuperCrew CURRENT 802A, KN Drop-in, RB Flaps, Husky Well Liners 2012 E70 X5M SOLD Stg 1+ Turbos, DPs, Velos Stg 2+, JB4, Race Cats, Bavauto Coils 2003 E46 M3 SOLD aFe CAI, AP Axleback, SSK, H&R Springs, TMS CMBR Arms, PF RTABs |
06-04-2018, 06:21 PM | #22 | |
245
Rep 561
jandref321346.00 |
