05-01-2018, 11:03 PM | #1 |
59
Rep 192
Is the M3 Differential Reliable?
I'm reading that some of you power users (above stock horsepower) are experiencing issues with differentials lasting 2 years. Others are saying the clutch discs need to be upgraded. How reliable is the M3 diff if you're pushing above the stock ~350 whp?
'̶9̶2̶ ̶3̶1̶8̶i̶ ̶E̶3̶6̶
'̶0̶8̶ ̶3̶2̶8̶i̶ ̶E̶9̶0̶ '08 335i E90 |
05-01-2018, 11:57 PM | #2 |
11586
Rep 12,728
yes it is reliable. how many miles are on your car?
ecs sells a reasonably priced service kit. i used this same kit. i was researching fluids and a guy on here that rebuilds a ton of differentials recommended this exact fluid, so i stuck with it. my mechanic said my oil was pretty bad after about 56k. https://www.ecstuning.com/b-assemble...3117525064kt1/
Instagram; @roastbeefmike
05-02-2018, 08:50 AM | #4 |
///M
237
Rep 703
M3 diff isn't reliable? First I am hearing about this. I have heard of diff bolts snapping but I plan on getting solid diff & subframe bushings anyway to combat that.
Follow me on IG: dre.pt
05-02-2018, 09:01 AM | #5 | |
Stop the hate, get a V8
3851
Rep 8,625
Yes, it is reliable. I can't even remember the last time I saw a thread on here about blown differentials. IIRC, it's the same basic differential as the E46 M3.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
SYT_Shadow11498.50 |
05-02-2018, 09:57 PM | #6 |
2631
Rep 2,141
Drives: 2011 E92 M3
It is a substantial pumpkin and all of the parts seem to be made of very sturdy stuff. It is also very easy to swap as no special tools are needed. Why can't all diffs just use flanges...
Not sure how the factory LSD guts will stand up to hard track use year after year. Given they are clutch based, it would make sense to say that the harder you drive it, the faster the clutch packs will wear. This wear will not grenade the diff, just causes some clunking and poor LSD performance. Cheers,
2011 E92 M3 - 6MT, ZCP, ZF LSD, ESS G1, Some other goodies... Last edited by Scharbag; 05-02-2018 at 10:06 PM.. |
05-03-2018, 03:45 PM | #8 | |
469
Rep 280
Drives: M2 F87, M3 E92 & E46, C63, 911
Garage List 2018 BMW M2 F87 [0.00]
2008 BMW M3 E92 [0.00] 2003 BMW M3 E46 [0.00] 2012 BMW M3 E92 [0.00] 2011 Merc C63 AMG [9.00] |
the lsd internals wear over time and assembly clearence increases. you can feel/hear a clonking noise when you hit/lift the throttle. but if you do not mind you can still drive it without a risk of messing it up. if you have a grinding noise when cornering replace the oil. ... and if you want to drive the car as it is intended to be driven you need to replace the lsd and switch to a conventional clutch type unit anyway as the oe unit is really really slow performing one. |
