04-21-2018, 09:09 PM | #1 |
345
Rep 791
ESS manifold keeps on lifting!!!
I have a 625 kit that keeps on lifting off the intake boots. To rule that out I ordered a new set of 8 and they should be here next week. In the mean time is there anything else that someone can suggest to keep the manifold from lifting?
Granted there are many 625 kits with no issue , even with my old 550 kit it was fine. I think the new intake boots should be a good start. Thanks in advance. |
04-21-2018, 09:52 PM | #3 |
345
Rep 791
Yes you are correct.
I installed the kit in the middle of winter where it is a nice and toasty 30 degrees in the garage. During this process I read that a touch of oil would help get the manifold to fully seat. I think the oil messed up the intake boot and allowed it to blow off at ~ 7psi according to my p3 gauge. I tried to clean the existing boots to remove any oil and I am still getting the manifold to lift. I'm going to give it one more deep cleaning on the boots but considering that they are just $4 a piece new why not. |
04-21-2018, 10:23 PM | #4 |
448
Rep 1,263
How are you seating the manifold on top? It's high up and at a awkward angle to apply downward force.
I carefully climbed up on the car and sat on the manifold to seat it. Seriously. Then use a LED flashlight and inspect how each boot is seated. Last edited by JsL; 04-21-2018 at 10:40 PM.. |
04-22-2018, 12:23 AM | #5 |
420
Rep 656
I had a similar issue recently. I replaced all boots and all clamps with OEM parts. Fixed the issue.
I recently bumped an old thread since it helped me and I added my 2 cents. It has some decent pictures and info as well. Worth a read. http://www.m3post.com/forums/showthread.php?t=1309465 |
04-23-2018, 08:36 AM | #6 |
802
Rep 1,566
I also had to replace my throttle body boots but did not have any lifting issues, mine were just deformed. It should not take much force to seat the manifold at all. One good push and it should snap into place. Absolutely no need for oil in the boots or to sit on the manifold, lol. Just make sure the clamps are COMPLETELY loose before you try to install it.
If you continue to have issues, ESS has manifold tie downs which they use for 650 kits. Maybe they will sell them separately for your 625.
04-23-2018, 10:29 AM | #7 | |
345
Rep 791
I never knew about the manifold tie downs. Thanks for that!
04-24-2018, 08:58 AM | #9 |
35
Rep 146
I just installed these manifold tie downs on my car as I upgraded to the 650 kit. PITA to install and I actually had to modify the tie downs by grinding the bracket down slightly as they were a bit too tall to allow my manifold to be seated 100%.
If I had the 625 kit, I would rather get new intake boots and see if that worked first as it will always be a pain to remove the intake manifold with the new tie down brackets in place. |
04-24-2018, 09:11 AM | #10 | |
802
Rep 1,566
Just out of curiosity, can you post some pics of your brackets?
04-24-2018, 09:29 AM | #11 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
04-24-2018, 10:50 AM | #12 |
420
Rep 656
Yea exactly what I was thinking and why I linked the intake boot thread.
04-24-2018, 01:21 PM | #13 |
612
Rep 1,326
i replaced 3-4 of my boots prior to installing the kit and i have no issues with lifting at 8psi.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
04-24-2018, 03:25 PM | #15 |
BimmerPost Supporting Vendor
8249
Rep 18,839
Drives: BMW
Couplers dry out/get distorted from numerous heat cycles/uninstalling/installing. New set of OEM boots and clamps will do the trick.
Patrón544.50 |
04-24-2018, 06:18 PM | #16 |
345
Rep 791
