KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
04-20-2018, 10:59 PM | #1 |
207
Rep 442
Which tire brand has the best "sidewall bulge" for OEM tire sizes?
What I mean is if you imagine the tire coming up from the edge of the rim it stays relatively vertical then meets the contact patch of the tire. My current tires aren't that "meaty" and from the edge of the rim they begin curving in towards the contact patch of the tire. Basically, not my car, but my tire sidewall curves in like this: But I want it do get as close to this as I can without mods: I know with lets say a 265 wide tire, that between brands the tire width can actually vary. Which brand has the widest tire that can get me close to what I want? |
04-20-2018, 11:06 PM | #2 |
187
Rep 714
My michelin PSS setup was pretty meaty, a lot more than my previous setup of PS2s. My 305 tires were so close to my fenders, and if I had passengers in the rear I would rub if I went over bumps super fast
2008 Alpineweiss III E92 M3
Amuse/Varis/CAE/BBS/BRIDE IG: Integraxtr |
04-21-2018, 05:55 PM | #4 |
130
Rep 364
+1 i just got a new set of P Zeros and that was my first reaction
2011.75 E90 M3 ZCP, 6sp, Interlagos Blue
2008 E93 M3, DCT, Melbourne Red 2007 E91 328xi Touring Wagon, Jet Black 2007 Audi B7 S4, 6sp, Sprint Blue Sold: E70 X5M, E46 M3 6sp cabriolet, E46 M3 SMG |
04-21-2018, 09:40 PM | #6 |
207
Rep 442
04-22-2018, 08:46 AM | #8 |
11818
Rep 23,187
Chuck's M3162.00 |
04-24-2018, 09:46 PM | #11 |
134
Rep 248
04-24-2018, 11:14 PM | #12 |
207
Rep 442
04-25-2018, 08:21 AM | #13 | |
Stop the hate, get a V8
3851
Rep 8,625
The easiest way to tell is to look at the Tire Rack specifications for a tire of your exact size. There are two measurements: section width and tread width. Section width refers to the overall width of the tire from one sidewall to the other; tread width is basically the size of the contact patch. If you want the more squared-off look, you want a tire whose section width and tread width are very close together. Bear in mind that more squared off tires will have a bit more ultimate dry grip but the handling at the limit ("breakaway") will be less predictable. You see this most on the OEM-specific fitments of a certain tire brand because they want a specific handling behavior for the car's weight, suspension, electronics, etc. Anecdotally, I have noticed that the OEM fitments tend to have more rounded sidewalls, likely so that the handling is more predictable as it nears the limit. They're probably willing to sacrifice a tiny bit of ultimate grip to make the car easier to control as you push it harder. If you are not taking the car to the track or whatever, this is probably irrelevant for you. Example using the rear 275/35R19 size: The Yokohama AD08R has a section width of 10.9 and tread width of 10.3. The Continental ExtremeContact Sport also has a section width of 10.9, but the tread width is 9.6.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 04-25-2018 at 08:28 AM.. |
0_to_6081.00 |
04-25-2018, 09:10 AM | #14 | |
207
Rep 442
04-25-2018, 11:02 AM | #17 |
3851
Rep 8,625
Honestly, it's going to depend on the tire size you plan to run, budget, etc. As I mentioned in my post, look on the Tire Rack specification pages and compare the section and tread widths to see what would give that kind of look.
Past: 2011.5 M3 sedan ZCP |
05-17-2018, 11:35 AM | #20 |
11
Rep 28
Nitto NT05 in 275/35R19 match your description. However, I only got 4,000 miles out of the rears and I never turn traction control off. They are one of the best looking tires though...
'13 JZB E92 ZCP
05-18-2018, 01:55 PM | #21 |
3851
Rep 8,625
4,000 miles?! Jesus, even my Cup 2s did better than that with heavy track use.
