04-14-2018, 09:16 PM | #1 |
115
Rep 288
replacing just one tire in the rear?
so I had a nail in one of my rear tire, and since I still had tirerack road hazard coverage, I was able to get a new replacement tire. Now the problem is, the other rear tire tread depth is about 7/32".(lower than I was expecting) since this is for the rear, I'm worried about running tires with two different tread depth. Any suggestions?
04-14-2018, 09:44 PM | #2 |
2383
Rep 3,736
Drives: 2018 M2
You Can get the new one shaved
Cameronc08363.00 |
04-14-2018, 09:55 PM | #3 |
11586
Rep 12,728
I know it might be slightly wasteful, but if I have a tire that is getting close to the wear bars, I just replace both. Some tires tend to get harder as they age and/or wear down. So that, coupled with being in the same axle as the newer and slightly larger (because it's new) tire will prompt me to not want to pair it.
Instagram; @roastbeefmike
04-14-2018, 10:09 PM | #4 |
4452
Rep 4,014
04-14-2018, 10:13 PM | #5 |
11586
Rep 12,728
i would suggest against shaving a street tire... spend money for a second new tire and have two new tires good for many more miles, or spend money to have a new tire shaved and take thousands of miles off of it just to have to replace it with another tire sooner? doesn't make sense.
also, by just replacing one tire, you are setting yourself up for always having one rear tire more worn than the other.
MachinesWithSouls4835.50 |
04-14-2018, 10:21 PM | #6 | |
2383
Rep 3,736
Drives: 2018 M2
04-14-2018, 10:21 PM | #7 |
2383
Rep 3,736
Drives: 2018 M2
04-14-2018, 10:24 PM | #8 |
115
Rep 288
I'm actually considering shaving mainly because I'm not a fan of current tires (Conti) and just want to finish using up the current set and move on to something else. Spending another $300 for tire I don't particularly like isn't appealing though shaving a new tire seems wasteful. Another option is to just repair the nail puncture and return the tire... silly first world problem I have...
anyway, my main question is what is an acceptable tread depth difference between the rear tires that is considered safe in the drivetrain? |
04-14-2018, 10:26 PM | #9 | |
2383
Rep 3,736
Drives: 2018 M2
BOOF-M34451.50 |
04-14-2018, 11:16 PM | #10 |
11586
Rep 12,728
might be worth a shot to call them and see if you can put the reimbursement amount towards a new set of tires if you order through them... you don't get what you don't ask for.
04-15-2018, 12:53 AM | #11 |
2631
Rep 2,141
Drives: 2011 E92 M3
If it just a nail, why not just a patch plug?
Cheers, |
04-15-2018, 07:37 AM | #13 |
11586
Rep 12,728
"Hello, tirerack, you're never going to believe this, but I ran over TWO nails. One on each rear. I KNOW, right? Can you believe it?"
04-15-2018, 08:28 AM | #14 | |
115
Rep 288
I got a new tire because the hazard insurance covered it. Apparently BMW and Continental advises against patching which means tirerack is on the hook for complete replacement. Also because I was considering tracking this year. |
04-15-2018, 08:42 AM | #16 | |
493
Rep 1,003
Drives: 2008 E90 M3 DCT Silverstone II
If you live in an area with a lot of construction, stuff happens.
Current: 08 E90 M3 DCT SSII w/ BE RB Swap, H8 Lux 180s, MS Drop-in AF, CF spoiler, CF diffuser, OEM CF leather trim, CF DCT paddles, Custom DCT flatbottom wheel, MirrorTap 9500ix, RockAuto rotors, Hawk HPS pads, AMS ECU 93 Oct Map Tune, GTS DCT update, Slambo custom undertray
04-15-2018, 08:48 AM | #17 |
4477
Rep 7,119
04-15-2018, 09:19 AM | #18 |
2383
Rep 3,736
Drives: 2018 M2
Thieves are a “road hazard” sell the tires and say they were stolen right off the wheels in the middle of the night
