04-12-2018, 10:36 PM | #1 |
JB4 Fan
29
Rep 191
Starter failed during walnut blast..HELP
Hello all,
So today I used the Bavauto walnut blasting kit and a remote starter trigger from Amazon to clean my intake runners. I believe it's possible some media may have entered cyl.2, attempted vaccuming out via spark plug hole, bumped starter and no problems. Continued to 3. After finishing 3, bumped starter and it worked for a second, valves started lifting etc, and then the starter just made a CLACK noise and stopped working completely. We rolled the car in 6th, dumped clutch and everything mechanically seems sound, valves move pistons move etc, no mechanical seizure. Is this probably the starter motor? Is there some kind of switch that disables the starter for a certain amount of time if triggered to often? I do not have access to the crank bolt. Thinking of having the car towed to Helix and ordering a new starter. Thanks for your help!
2016 F83 M4 6MT - Silverstone / Marino | BootMod3 Stage 1
04-13-2018, 11:44 AM | #2 |
502
Rep 647
Checked fuses? Charged the battery?
A remote starter trigger seems like a bad idea with how advanced the electronics are. I wouldn't be surprised if the car is freaking out about the starter firing by itself, but I'm not sure. |
04-17-2018, 04:16 PM | #3 |
73
Rep 341
charge the battery, possible the starter don't have enough juice...
Metallic Black on Black 2009 135i, new waterpump, OFHGs, and VC gasket...RB turbo PCV valve (ooo), NGK performance plugs...V3Cobb access port stage 2+FMIC, Injen intake, Mishimoto clone FMIC, ARM charge pipe, ARM downpipes, Whiteline subframe bushings
04-18-2018, 01:55 PM | #4 | ||
JB4 Fan
29
Rep 191
If your starter makes a loud CLACK noise and stops, it's likely your remote starter has caused the part to fail.
