04-05-2018, 01:40 PM | #1 |
Rep 29
Clarification on PROFLEX Commander FlexFuel Kit
Hey everyone. I am just trying to get some help with my research on the FlexFuel kit for my E92.
Everywhere I see online the kit says it is plug and play, therefore no need for a tune. Does this mean that I would need to get a tune still for 91/93 in order to get those pump gas gains and then the E85 gains would work in tandem with that tune? Or do I not need to worry about getting a pump gas tune for the most gains? I would still like to have power gains on 91 while I am running it over stock tune. Thanks in advance for all the help! |
04-05-2018, 01:49 PM | #2 |
935
Rep 1,930
You still need a E85 tune for E85. If you have other mods you might want another 91/93 tune as well.
If you are not FBO, I don't see a reason to get E85 on stock. |
04-05-2018, 02:14 PM | #3 |
612
Rep 1,326
You don't need a tune to run the AFD proflex commander flex fuel kit. It's optional if you want to get a 91/93 tune. AFD kit $1200 + tune $1000 and you're already at $2200. You'll need to decide what's the best $/HP for you.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
04-05-2018, 04:15 PM | #4 | |
258
Rep 564
How are you optimizing the ability to run E85 without a tune? I thought the AFD was just to be able to pump and go (essentially giving you the ability to use whatever fuel you have without needing to flash the DME) whatever you want? A stock car would run like crap on E85?
2009 E90 M3 DCT IB Slick Top | 2017 911 Carrera White 7MT Slick Top | 2003.5 E46 M3 CB SMG | 2005 Audi A4 USP Black 6MT |
04-06-2018, 02:11 PM | #5 | |
612
Rep 1,326
JohnEastvold76.00 |
04-06-2018, 03:13 PM | #6 |
258
Rep 564
is your ess650 tune for E85? or 91/93?
04-06-2018, 03:27 PM | #7 |
612
Rep 1,326
it's the off the shelf ess 650 tune which requires 93 octane. ess does not tune for e85.
04-06-2018, 04:26 PM | #8 |
5257
Rep 10,628
With forced induction you get decent gains even without an E85 tune since the extra fuel quantity helps cooling and the higher octane helps meet the existing timing targets.
With an E85 tune, greater gains are possible because the timing targets can be raised. |
04-30-2019, 11:21 PM | #9 |
245
Rep 1,236
did you gain any hp going from your ots 650 tune to the ots 650 tune +afd while mixing some e85?
2007 e90 335i: Single Turbo 700whp (Sold)
2009 e82 135i: Jb4 Only (Sold) 2010 e92 M3: Macht Schnell Intake, AA Pulley, IPE F1 Full Exhaust, 100% e85, RK Tunes Custom Tune (400whp) |
Tags |
e85, flex fuel, proflex |
