KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
04-03-2018, 12:42 PM | #1 |
25
Rep 101
Wider tires on zcp wheels
Hey guys. I have an e90 zcp and was wondering if I’m able to run 255/35/19 and 275/35/19 on my zcp wheels without any issues such as rubbing. I’m currently on stock zcp suspension.
04-03-2018, 12:51 PM | #2 |
postimus minimus
31
Rep 94
Drives: M3 addiction
Easily
04-03-2018, 12:52 PM | #3 |
Stop the hate, get a V8
3851
Rep 8,625
You'll be fine. I'd bet half the people on this site run that size.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
04-04-2018, 02:43 PM | #7 |
4363
Rep 1,913
Drives: Here and There
Further confirmed. I run 255 front / 285 rear with no issues at all.
04-04-2018, 03:22 PM | #8 |
11586
Rep 12,728
You can run up to 275/30 and 295/30's without issue, but it may be brand dependent. I'm on p4s'.
Instagram; @roastbeefmike
04-04-2018, 03:42 PM | #9 |
3851
Rep 8,625
Correct, and sedans actually have a bit more room in the rear wheel wells.
04-05-2018, 08:04 AM | #10 |
168
Rep 405
Keep 3 things in mind; tire brand differences, spacers and suspension/ride height.
Personally I run RE71Rs on my ZCP with 15mm front and 12mm rear and a set of Ohlins R&T. Height is set at the 'stock' Ohlins recommended measurements(preload, strut length and height) which effectively lowers the car 20mm from factory height. I went through a set of RE71Rs with 245/265 combo and no issues. Then I decided to go up to 255/275 and the rear began rubbing. Ultimately I had to remove the 12mm spacer in the rear and all was OK. The re71r has a very tall shoulder where as I remember PSS didn't. There will always be slight differences between tire brands even at same fitments. In other words a 275 RE71R 'may' fit different than the P4S or a PSC2 or xxx. Just a thought |
04-05-2018, 10:23 AM | #11 |
65
Rep 131
255/35 - 275/35 is proven change that will work. There are the perfect tire size for the OEM Competition Wheel.
2012 E92 M3 w/ Competition Package
04-05-2018, 12:28 PM | #12 |
758
Rep 1,408
I have 255/35 - 275/35, had them with PSS and now with PS4S and it looks way better than factory sizing in my opinion. I run them with a 15mm and 5mm spacers front and back respectively and no issues at all. Looks fantastic.
05-15-2018, 09:13 AM | #13 |
804
Rep 979
I have the same sizes on my car
2008 E60 550 ? Alpine White // RPI
2011 E90 M3 Competition // Alpine White // ESS // RPI // 20" BBS LM's, blah blah 2021 G80 M3 Competition // Brooklyn Grey // KW Suspension // 12mm Spacers all around // Resonator Delete |
05-15-2018, 01:04 PM | #14 |
156
Rep 143
I'm running a 275/30/19-F & 295/30/19-R setup and clear on a Michelin PSS tire. Has anyone run the same size tire on PS4S without rubbing?
@ZCP_e90m3
05-15-2018, 02:28 PM | #15 | |
544
Rep 765
I would assume that PS4S in your 275 sizing fits fine in the front as it is only a tiny bit wider than the PSS from what I recall. |
05-15-2018, 11:38 PM | #16 | |
1250
Rep 1,501
Many miles are you seeing on your re-71’s? |
05-16-2018, 05:44 AM | #17 | ||||
168
Rep 405
That said I get about 8-10k miles and 2-4 track days. Also I don't daily the car. |
05-16-2018, 11:04 AM | #18 |
215
Rep 832
Depends on the tire. My 255/35/19 Ad08r rub bad in the front when turning(15mm spacer)
05-17-2018, 11:06 AM | #19 | |
730
Rep 3,969
As far as a 275/295 setup it will fit with no issues. It won't be optimum though. I moved on from my ZCPs to the VMR V810s due to the lighter weight which made up for the wider tires, wider width (19X10 and 19X11) and more aggressive offset. Couldn't be more happier. Dave
2020 Ford Mustang GT 6MT PP1 444rwhp
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk Last edited by Dave07997S; 05-17-2018 at 11:13 AM.. |
05-19-2018, 11:42 PM | #20 | |
12
Rep 88
05-22-2018, 11:22 AM | #21 | |
730
Rep 3,969
The VMR V810 wheels are flow formed. Lighter than the OEM ZCP wheels yet wider and more aggressive offset. http://velocitymotoring.com/wheels/v810/
(Sold)2013 M3 Coupe-MR/BLK ZCP, 2011 M3 Coupe-MR/Blk 2007 Porsche 997C2S Speed Yellow/Blk sport seats 2004 BMW M3 Imola/Blk |
05-29-2018, 07:42 PM | #22 | |
12
Rep 88
