03-29-2018, 04:48 AM | #1 |
Chief Warrant Officer
1025
Rep 1,638
So I'm fairly knowledgeable on engine tuning and performance, but fairly ignorant about suspension and suspension tuning.
I had my 2012 135 in for service recently and mentioned a cyclical shimmy I've been experiencing lately with my winter tires. End result is they said my tires were unevenly worn (scalloped). My research says worn shocks and struts are a common cause. Also my research is indicating the shimmy might be related to my front control arms and/or bearings? My car is a daily driver, never tracked, but we do have some rough roads up here in New England. Is it likely that my stock (other than white line inserts) suspension is wearing out by 80k Miles? What's likely to need replacing/refreshing around this time? I mean I know shocks need to be replaced periodically, but what beyond that? Bearings, bushings, control arms...? Thanks in advance.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
03-29-2018, 06:10 AM | #2 |
21
Rep 120
I had the same issue on a ford focus I had in college. I replaced the rear struts and it solved the problem. But just to be sure I would go have an alignment done too.
03-29-2018, 07:23 AM | #3 | |
1025
Rep 1,638
I'm switching back to summers next week.
03-29-2018, 08:09 AM | #4 |
4338
Rep 6,196
Scalloping tires is caused by alignment. Also, many tires scallop no matter what the alignment is. There are many tires, like the Pirrelli Scorpion etc, that I have ever seen worn evenly.
What kind of tire are you using? |
03-29-2018, 08:47 AM | #5 |
1025
Rep 1,638
Blizzak LM-25 (runflats) I like runflats for winter - there's nothing worse than being on the side of the road trying to change a tire in a snow storm. It sucks and is wickedly dangerous.
03-29-2018, 01:01 PM | #6 |
1542
Rep 3,071
At 80k I am sure your suspension is tired. Refresh with new shocks atleast
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
03-29-2018, 01:44 PM | #7 | |
4338
Rep 6,196
03-30-2018, 12:03 PM | #8 |
Sideways and Smiling
3027
Rep 2,860
Drives: In Exuberance
I doubt your socks are totally shot at only 80k. Mine finally blew at 160k but were fine before that. I'd first point you towards the front control arms. I had a shimmy going on, even with brand new tires, and my dad said that those were the root of all the shimmies in his former E39, which has a very similar suspension setup to the 1'er. So, we upgraded to M units and all was fixed. The M arms may also fix uneven front tire wear because the bushings deflect much less under loads and they add a hair of negative camber (fixes outside edge wear on the tires). A very worthwhile upgrade, IMHO. Good luck!
2012 BMW 328i 6-Speed Wagon | Deep Sea Blue with Grey Dakota Leather | Manual Swap, 330i Intake + Tune, 3.15 Helical LSD, Öhlins R&T
(SOLD) 2009 BMW 128i 6-Speed Coupé | Monaco Blue with Black Sensatec | chris_flies' 128i thread |
Cavpilot2k1025.00 |
03-30-2018, 12:30 PM | #9 | |
1025
Rep 1,638
While I have my suspension apart, my understanding is that's the best time to do the RSFBs. I already have Whiteline inserts (and I LOVE what they brought to the car), but they're nearly 50k miles old. Does anyone think it worthwhile to replace them with actual new bushings? Do the inserts wear over time?
03-30-2018, 12:52 PM | #10 | ||
3027
Rep 2,860
03-30-2018, 06:28 PM | #11 |
1542
Rep 3,071
Dollars for doughnuts the control arms are worn b/c the shocks are tired. Replace shocks + M3 arms + RSFB + Rear Diff Lockdown Bracket = the way it should be.
03-30-2018, 09:22 PM | #12 | |
1025
Rep 1,638
Looking at BMW PS (springs, shocks, anti-roll bars), M3 front control arms and RSFBs. I figure better to do all the suspension work i want at once while it's all apart. I'm not really familiar with the diff lockdown. I've heard of it, but can you either e'splain it or provide a link? Recommend one?
03-30-2018, 11:54 PM | #13 |
1542
Rep 3,071
Here's a link to the member I got mine from. Really locks down the rear end a bit more.
DIFF lock down bracket, no more wheel hop https://www.1addicts.com/forums/show....php?t=1171425 I looked at the BMWPS. In the end decided that for a few bucks more I could get Ohlins or TCK Single Adjustable. All are a good upgrade.
03-31-2018, 07:39 AM | #14 | |
1025
Rep 1,638
Also I don't track it, so I'm not interested in adjustable coil overs. I want a set-it-and-forget-it solution for daily street driving on crappy New England roads. Hence I think PS might be the ticket. I can get a pretty good deal on it.
03-31-2018, 11:25 AM | #15 |
850
Rep 2,276
I think an alignment twice a year is waaay too much. I use a simple tread depth gauge. If wear is uneven, only then do I get an alignment. The tread depth gauge tells you if there is an alignment problem long before you notice it visually and before there is any real adverse wear.
05-25-2018, 08:09 AM | #16 | |
1025
Rep 1,638
05-25-2018, 08:25 AM | #17 |
1025
Rep 1,638
Thread Update:
My front struts are totally shot. Gotta replace ASAP. Gonna do control arms too while I'm at it. And springs. And bushings.
chris_flies3027.00 |
