TireRack
      03-21-2018, 01:24 PM   #1
ZFRED10
15
Drives: 2014 X5
LED Fog Lights
Hey Guys. Just purchased my 2013 35i and I'm looking to upgrade the fog lights bulbs from stock. I searched and didn't find too many successful threads in regards to this. I found these from online and they claim to be error free as they come with resistors and cancellers.
https://bimmian.com/Accessories-for-...s/?veh=70#tabs
My concern is the flickering that can happen during startup. Will I still get this or will it have to be coded out? Do you think these would work or would I save the headache by just getting a bright white Halogen bulb instead?
I also wanted to mention that I have the M Sport Package, but I think it is all fairly similar, just different bulb locations.
Any feedback is appreciated.
Thanks,
      03-21-2018, 08:27 PM   #2
RichardR0404
31
Drives: 2013 BMW X5 35D
im thibking of getting some regid blocks and light bar
      03-21-2018, 09:28 PM   #3
ZFRED10
15
Drives: 2014 X5
I went ahead and bought the Carly For BMW OBDII coding adapter so I won't have to worry about flickering or bulb errors. With that being said, would I still need load resistors for the LED fog lights or are they not necessary since I'll be coding?
      03-23-2018, 08:12 AM   #4
ggabriele3
28
Drives: 2015 228i Msport
I'd be interested to know if coding was required for this.
      03-23-2018, 08:25 AM   #5
ZFRED10
15
Drives: 2014 X5
If the H11 LED bulbs come resistors, they should not throw any error codes at all. With that being said, even with resistors and no error codes, your lights will always flicker on cold startup as the computer does the bulb check as well as during while you're driving when it does the warm check. The only way to avoid this is coding. I'm installing H11's without any resistors and coding via BMW Carly App. I will let you know how it turns out.
      03-23-2018, 08:53 AM   #6
ggabriele3
28
are you talking about the kind of quick flicker that HID bulbs used to do back in the day? I'm not sure I mind that, so long as it's not causing a problem in the car.
      03-23-2018, 09:12 AM   #7
ZFRED10
15
Drives: 2014 X5
Different BMW, same idea.
      03-28-2018, 04:24 PM   #8
DOT.
Drives: E70 N63
I bought some H11 LED kit from TRS and coded out the cold and hot check for the fogs using NCSExpert.
      03-28-2018, 09:28 PM   #9
ZFRED10
15
Drives: 2014 X5
How are you coding? I'm using Carly but can't seem to get my LED fogs to run as DRL's. Got my Angel Eyes working, but can't have both.
xbimmers
