03-12-2018, 06:45 AM | #1 |
1542
Rep 3,071
I did a search and surprisingly didn't find any good info on what the stock ride height is supposed to be for the 135i.
I just recently did coilovers so I measured mine before & after Before = stock ride height Msport suspension w/ 55k miles. Front 337 mm (arch to center) or 578 mm (arch to bottom of rim) Rear 343 mm (arch to center) or 583 mm (arch to rim bottom) Anyone willing to measure theirs? If so please post up your ride height/fender gap and mileage. Thanks.
2011 135i w/ DCT | ZSP Sport Pkg | PPK | Ohlins R
03-12-2018, 07:43 AM | #2 |
128
Rep 302
I am going to install ohlins coilovers this coming weekend and will measure if you are willing to wait that long. Currently running stock suspension on a 2012 135i.
Not sure what your use is, do you mind sharing your setup i.e. camber, toe, castor etc if you have it available? |
03-12-2018, 11:03 AM | #3 | |
1208
Rep 2,028
you can find the "target" ride heights on a dealer (BMW) alignment sheet, but I am not sure how accurate it is since it's a range. Each car is slightly different in springs and packages that might affect ride height. Also, BMW provides ride height measurement as taken from the bottom of the wheel to the fender... not from the wheel center. And technically this is a poor way of measuring ride height as GROUND CLEARANCE is what you should be using to measure rake... not fender gap clearance. Fender measurement is just a quick way for the dealer to inspect for a sagging suspension. Gangplank what was the "before" measurement? Seems like you have a lot of rake dialed in... From what I remember, the stock ride height provided for 8mm higher front measurement then rear. Here is a dealer sheet I found: http://www.1addicts.com/forums/attac...1&d=1313087067 Front 599mm/ Rear 592mm (with 16" wheels apparently) Last edited by bbnks2; 03-12-2018 at 01:17 PM.. |
MightyMouseTech4337.50 |
03-12-2018, 01:18 PM | #4 | ||
1542
Rep 3,071
The BMW numbers seem strange. Why would it be higher in the front vs. the rear? In this post by fe1rx in another thread http://www.1addicts.com/forums/showp...34&postcount=2 the Stock ride height for the 135 is listed as Front 592 mm / Rear 584 for 18" rims (measured from top of arch to bottom of rim). Same 8mm squat (reverse rake) which I don't see looking at other stock 135i's. I'm trying to figure out why mine had rake built in on the stock msport suspension? Interestingly the sheet linked by Fe1rx also lists the BMW Perf. Suspension as dropping the rear 10mm but leaving the front resulting in 10mm more squat F 592 / R 574 but that doesn't seem right either. Using the BMW method my ride height was Front 578 mm / Rear 583 mm.
03-12-2018, 09:20 PM | #5 |
1208
Rep 2,028
It's pretty simple... The arch is a useless point to measure to. Like I said, it's just how dealer techs measure suspension sag. They don't care about rake when you go in for service. What really matters for performance is ground clearance and that is what you measure rake by.
If you measure ground clearance you'll see you have over 1/2" of rake with the rear sitting higher. Yes, rake can be used to tune handling but the car was delivered with close to 0 rake for a reason (front arch sits a bit higher than the rear). It makes perfect sense because weight distribution. Desoite popular belief, very few if any cars run rake. They chassis itself is naturally raked to improved aero rather than physically running the rear suspension geometry higher. You wouldn't need to dial out understeer with rake if you've tuned it out by squaring up the tires and other means. Last edited by bbnks2; 03-12-2018 at 09:28 PM.. |
03-12-2018, 10:44 PM | #6 |
1542
Rep 3,071
Ok, now you have me curious. Where should I take the measurements from to determine the ground clearance ride height and rake?
Why would the car be delivered with close to zero rake? I may try to run a 245 or 255 square set up and more front camber which would be needed to do that.
03-13-2018, 07:48 AM | #7 | |
1208
Rep 2,028
The car does come with a slight positive rake despite the front fender sitting a bit higher than the rear. It's just enough positive rake to offset the squat of acceleration. I can't speak too much more on it other than my car handles way better with 1/4" rake then it did with 3/4" take. Then again, I am running different spring rates then most. Pretty much every BMW I see at hpde runs 0 rake. This creates a look as if the front is sitting higher when it's really not. |
03-13-2018, 10:29 PM | #8 |
1542
Rep 3,071
Ok so your saying the stock 135i has some positive rake from the factory. And we should dial it out to get a flat stance?
Please explain what effect this will have on handling - better corner entry? Reduce mid corner float? Reduce corner exit understeer?
03-14-2018, 12:42 PM | #9 |
1208
Rep 2,028
How much rake you want is your decision and is entirely setup dependent. All I was trying to say is that you were measuring rake wrong and you may want to revisit your ride height settings now that you know where to measure from.
03-14-2018, 08:36 PM | #10 |
1542
Rep 3,071
The point of this thread is to find out what the stock ride height is on a 135i with Msport suspension. You happened to point out that you think my car has excessive positive rake.
I'm not doubting what you say but I'm also not going to accept it without understanding it. I'm trying to learn about suspension set up. I've tracked motorcycles for years and am learning about cars. If others can post up their measurements to compare stock ride height we'll have more info to work with.
03-15-2018, 07:36 AM | #12 | |
1208
Rep 2,028
Rake is typically used to gain an aero advantage, but it comes at the expense of disturbing the cars suspension geometry and weight distribution especially so when you consider dynamic situations like slowing down while entering into a corner. The 135i chassis is designed in a way that, at a flat ride height (0 rake), the rear bumper is naturally raked and the rear trunk lid also sits higher than the front hood. This generates down-force even without a proper diffuser which could provide even further benefits... In essence, the chassis is designed with aero in mind. If you were to put a fancy diffuser on the rear bumper to generate even more downforce, you would not want to have excessive rake either. Too much rake would place the diffuser higher off the ground and decrease its effectiveness. You would then need to move to a diffuser with an EVEN GREATER angle to capitalize the extra rake. No aftermarket diffuser that I know of is design to be used with a high rake angle. You want just enough static rake so that under acceleration the chassis sits relatively flat at. Add a wing and you'll need to dial in a bit more rake to offset that downforce... in a non-aero car, you are far better off with 0-1/4" of rake for the aforementioned reasons. Or, you may need rake to get the car to rotate if you completely botch up your suspension setup with aftermarket parts You can google rake yourself for more information. I am no expert. I just think people dial in rake without having a clue why and I have yet to see a production race car with a high rake angle (purpose built cars are a different story): "Cars are normally set up to have the front ride height of the car (measured at the front axle) lower than the rear ride height of the car (measured from the rear axle). This relationship is known as "rake". It ensures the undertray of the car produces downforce and not lift. There is an optimum rake at which cars run though and there is a point beyond which any extra reduction in ride height may actually increase drag and promote lift." "A potential downside of this philosophy has always been that as the speed falls as the car enters into the corner and the ride height increases, it causes a big balance change - because the gap between track and the leading edge of the floor has increased, but there is not much compensation from the increased rake (as you get with a high-rake car - ie a high-rake car is even higher-rake as the speed comes down)." http://www.skysports.com/f1/news/324...es-and-ferrari https://www.caranddriver.com/feature...y-suck-feature Last edited by bbnks2; 03-15-2018 at 12:44 PM.. |
03-15-2018, 01:04 PM | #13 | |
425
Rep 545
For simplicity's sake, I assumed the CG height to be 1/2 of the car's overall height; this is likely higher than the actual CG height and will exaggerate the effect of rake. For a fairly extreme rake of 25mm, the rake angle, and it's effect on CG position can be calculated. The rake angle is 0.56°, and the CG moves forward by 6.85mm. From this, we can calculate that the resulting weight distribution is: Front=52.26% Obviously, the relationship between ride height and suspension geometry is very important, but I'd argue that rake that's slightly higher than stock isn't really the big deal that you make it out to be.
2011 BMW 135i ///M-Sport, DCT
Bilstein B12 kit, Dinan camber plates, M3 front control arms, Whiteline poly RSFB, MHD Stage 1, cp-e Charge Pipe, H&R Front sway bar, BMW performance diffuser |
03-15-2018, 01:35 PM | #14 | |
1208
Rep 2,028
#2 - Weight distribution is not the only affect of rake. You are also making a change to the instantaneous roll center. Whether or not it is favorable is setup dependent and could result in un-wanted bump-steer. #3 - Your assessment of weight distribution completely ignores down-force and how raking a non-aero vehicle will more than likely result in a reduction in rear down-force. #4 - Why are you calculating based on wheel-base? Overhang and the overall length of the vehicle would change your COG calculations, but I get your overall point. You also seem to assume that I am trying to present an argument AGAINST rake when I am not. I am simply doing as he requested and explaining why you MAY NOT WANT to dial in rake and trying to explain why that is. This is especially true when you don't know how to measure it. Thank you for the bit of information/math though as many here believe that you can't use math to tune suspension. As for op's question, what is the stock m-sport ride height?, here is the technical info... it varies by a lot of things so getting forums users to post their ride heights seems futile... Measure like BMW does, from bottom of the wheel to the fender (https://www.newtis.info/tisv2/a/en/e...nsion/FaPCnH1_), and then compare to the stock values as follows: Front: https://www.newtis.info/tisv2/a/en/e...ension/6h97aRc Rear: https://www.newtis.info/tisv2/a/en/e...-guide/61Xf0Co BMW says it's normal to have up to 10mm difference from left to right in an unloaded car ("normal position") so don't expect to land at exactly the defined ride height. I am guessing "Low-slung sport suspension" is for cars that came with the S704 "M-Sport" package (anthracite headliner, shadow-line trim, style 261m wheels) 18" stock M-sport wheels (261m) stock ride height should be: Front: 592mm Rear: 584mm Having re-found the TIS info, I now remember why I never bothered asking this question on the forums. Too many variables to even get the "right" number... and it's all provided by the above TIS articles. Last edited by bbnks2; 03-15-2018 at 04:51 PM.. |
03-16-2018, 08:02 AM | #15 |
1542
Rep 3,071
Wow quite a roundabout here but now that we've come full circle - bbnks2 the info you linked to is the same as the info I linked to posted by Fe1rx in another thread. It seems this thread went sideways when I used the term "rake" in regard to the measurements I was taking on my car. You are correct that wheel center or bottom of rim is not a good measurement to determine actual rake of the suspension set-up.
BTW - all US spec 135i come with the low slung sport suspension (aka Msport). The real point of this thread was for comparison to find out if my before numbers are different from others with stock suspension. Using wheel center to fender arch is a great way to compare easily. 18" stock M-sport suspension Front: 592mm Rear: 584mm My stock measurements w/ 55k miles were: Front 578 mm (arch to bottom of rim) Rear 583 mm (arch to rim bottom) So my suspension was sitting 14mm low in the front & 1mm low in the rear vs. spec. So anyone out there with stock Msport suspension want to post up their measurements for Front & Rear ride height.
03-16-2018, 08:12 AM | #16 | |
1208
Rep 2,028
M-sport is actually a completely separate package. Not all 135i are M-sport. But, I get what you mean that both a base and an M-sport 135i get the same struts and springs. I believe the sways are the only thing that is different, based on another thread. Then again, where is the proof that the struts and springs are the same on both cars? I've seen at least 3-4 different spring codes... Last edited by bbnks2; 03-16-2018 at 08:21 AM.. |
03-16-2018, 08:36 AM | #17 |
425
Rep 545
Yeah sorry for the thread derailment...I'll try to remember to get some measurements for you this evening!
03-16-2018, 10:36 AM | #18 |
2183
Rep 2,806
I think that is a typo as it only shows for 18" wheels.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
03-16-2018, 04:44 PM | #19 | ||
1542
Rep 3,071
Agreed.
03-18-2018, 05:42 PM | #20 |
1542
Rep 3,071
Anyone out there willing to measure their stock Msport ride height??
If so please post your ride height and mileage on your car. Trying to collect some data. Thanks.
03-18-2018, 09:55 PM | #21 |
2183
Rep 2,806
I think all springs are fitted based on the car and it's options (like BMWP springs which have been much discussed). I've seen at least 4 front spring codes on 1 series. My guess is the tolerance on the OE ride height sheets linked above are due to the fact that a car just over the edge D5 is going to sit higher than a car just below D6.
It would contribute to the collective knowledge base if people could also post their spring codes and vehicle options. For what it's worth, I'm at 588 / 576 front / rear. My strut mounts have only about 7,000 miles so that partially explains the relatively high front end. Also I'm on D6 front and L3 rear springs that I think would have been standard on a 135i with AT. My car is lighter than a 135i spec'd the same so the spring codes explain some of the ride height also. Also, squatting down next to the car in the garage with a tape measure is not completely accurate.
03-18-2018, 10:11 PM | #22 |
2183
Rep 2,806
Since I suggested we post vehicle options I guess I should note mine:
AT, power seats, Nav, HK sound, sunroof, xenon lights
