XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      03-11-2018, 02:25 PM   #1
BeeHemDoubleU IksWane
BeeHemDoubleU IksWane's Avatar
16
Drives: BMW X1
Car stalled while cruising and won't start
I was cruising at 30 mph when all of a sudden the car shutdown put himself in neutral, the steering was hard as balls and same with the brakes.
Now when I try to turn the car on it does this sound. The battery is brand New and at 12.6V so it's fine. Everything Electronic in the car is working as it should. They key fob will pop out by itself after 2-3 tries
I tried to bypass the engine ground to see if that would work. It didn't.
Do you guys have any ideas where that sound could come from?
I'm done with this fucking car.. All I got is problems. Already 10+K in reparation for a 2012 car? Unbelievable
Thanks.
You talk about German technocracy and you get automobiles.
      03-11-2018, 04:15 PM   #2
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
Like any car today you need to read the CEL codes. Get some type of reader if you are going to attempt any type of repair. Could be any thing. Good luck!
2014 X1 Xdrive35i /BMS intake/JB4/ GFB DV/CPE charge pipe/ VRSF downpipe/ Alpina TCU flash
      03-11-2018, 05:26 PM   #3
interceptor428
29
Drives: 2013 x1 28i/2015 428 m sport
I hate to even think this..but...open your oil cap and poke your finger on the timing chain..how does it look?
      03-11-2018, 05:30 PM   #4
16
Drives: BMW X1
I did read the CEL codes with my Carly app.
      03-11-2018, 05:32 PM   #5
interceptor428
29
that DME MAIN RELAY error makes me think a fuse for the DME (if it exists) failed suddenly
      03-11-2018, 05:45 PM   #6
16
Drives: BMW X1
April 13 2017, they replaced the Timing chain because of noisy oil pump chain module. They replaced complete timing chain with oil pump chain module, all cleaned all looked for leaks and all is "OK". 2965.22$
Here's a list of problems they repaired in April 2017
Oil filter housing leak. Replaced oil filter housing and gasket intake
Noisy timing chain DEFECTIVE. replaced 2965$
2 stab pin loose replaced 197$
Defective VVT motor and software. replaced 1264.69$
Exessive wear on thoot of exentric shaft. replaced.
Defective rear driver side window drive. 434.85$
Steering column problem. Seized column seal 648.96$
Brand new brakes, calipers, sensors at 4 wheels 2000$
      03-11-2018, 05:58 PM   #7
16
Drives: BMW X1
I get a check engine light and in the computer It gives me a "!" sign, a transmission sign (see photo below)
[/url]
      03-11-2018, 06:07 PM   #8
16
Drives: BMW X1
Thanks Interceptor btw to take of your time to try to help me. Appreciate it
      03-11-2018, 10:22 PM   #9
16
Drives: BMW X1
It sounds an awful lot like in this video.. The guy mention the DME just like interceptor pointed out.. Hmmm.. He also gets the "!" warning sign but not the transmission one..
      03-12-2018, 07:42 AM   #10
interceptor428
29
Check your power distribution block that sits on top of the battery too...you may need a meter to check each output to be sure there's 12volts coming out of each one. my gut tells me it's a power issue
      03-12-2018, 09:19 AM   #11
16
Drives: BMW X1
And how do I check each outputs? I do have a multimeter
      03-12-2018, 10:10 AM   #12
interceptor428
29
check this out. https://www.bimmerscan.com/bmw-rear-...tribution-box/
      03-12-2018, 11:15 AM   #13
KWX1
KWX1's Avatar
25
Yep, there is a impact safety device (#2 or #3 I believe)and fuse links that can fail and give you these type of problems.
      03-15-2018, 03:58 PM   #14
interceptor428
29
Hey OP, was this resolved?
      03-17-2018, 10:21 AM   #15
16
Drives: BMW X1
Nope. The car is at a Shop for German cars right now but they are loaded. They'll diagnose my car next week.
I'll keep you guys updated
      03-17-2018, 11:58 AM   #16
interceptor428
29
ok thanks!
      03-23-2018, 04:42 AM   #17
16
Drives: BMW X1
Just got a call from the Shop. Seems like it's the positive cable that goes to the fusebox. They say BMW made a recall for this.
I did found a link
https://bit.ly/2GhjAVv
It fits what my car did to a T but they say it only affect
X1 Series vehicles produced July 3, 2013 – July 17, 2013...
Mines is a 2011 production. Weird. The car got exactly all the problems described in this PDF.
      03-23-2018, 05:25 AM   #18
Kevman
Kevman's Avatar
45
Drives: 2019 BMW X3 x30i
How many miles on your car?
      03-23-2018, 12:42 PM   #19
16
Drives: BMW X1
55K why
      03-30-2018, 06:13 PM   #20
16
Drives: BMW X1
Recall Campaign No. 2017-655: Positive Battery Cable (61 84 17RC)
Also, the Shop told me my starter was drawing too much amps. Need replacement.
138 units affected... Lucky me.
      03-30-2018, 06:23 PM   #21
16
Drives: BMW X1
Guys.. BMW was aware of the recall and didn't do the repair.. My car was in their shop for 2 weeks last year for the valvetronic issues. They couldve done the repair for the recall during that time, no? Could I possibly make them pay for the towing and the diagnostics? Keep in mind the closest BMW dealer is 500+km from me so no chance for me to tow it there..
I mean the car died on me while driving. It's a security issue. Luckily for me I was not on the highway because it would have been a disaster..
      04-01-2018, 11:12 PM   #22
TitanSilverE46
Australia
Drives: 2014 X1 E84 , 2017 2201 AT F45
Interesting that Australian delivered X1s were subject to this recall.
ALL E84 X1s made prior to 28 Feb 2011 were eligible.
http://australiancar.reviews/reviews...del=X1&gen=130
xbimmers
