03-03-2018, 09:41 PM | #1 |
17
Rep 52
Drivetrain malfunction with RaceChip also
Sup guys,
I finally installed my Racechip GTS today and I also have the dreaded "drivetrain malfunction error". I know I installed it correct as I used Ben's instructions (thanks Ben). I also cannot get it the error to stop even with the "dummy" plug installed. It should just revert to normal with that on. Here are some pictures. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] I tried turning the car off and letting it set for an hour to no avail. Car seems to run perfectly fine with the dummy plug. I have not started with the chip settings yet other than first install I turned the car on with default setting of "5". I have the Bimmercode app but have not tried to clear the error with it (if thats possible??) Thanks!
2016 BMW X5 xDrive 50i White 2017 Porsche Carrera 911 S White Last edited by lilthrift; 03-03-2018 at 09:54 PM.. |
03-03-2018, 09:54 PM | #2 | |
12977
Rep 18,721
Do you mind sending me the pictures?
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
03-03-2018, 11:41 PM | #6 |
2114
Rep 2,388
So I'm not sure about piggybacks, but regarding spark plugs - official BMW policy (according to BMW SA) is to change them every 5th oil change. Of course that is for stock car. Just giving the info guys - do with it what you like
03-04-2018, 08:38 AM | #8 |
12977
Rep 18,721
lilthrift , couldn't make out if you are connected to the correct sensors from those pictures. But it is the correct location.
If you are still having trouble while the dummy plug is installed (it should clear up after engine startup or a little driving), then it could be the installation or harness issue. Did you reinstall the air box and sensors on the airbox back in place before you start the engine? I believe drivetrain malfunction will not give you a CEL code.
03-04-2018, 09:56 AM | #9 |
17
Rep 52
r33_RGSport, I am pretty sure I got the right connections both plugs seemed to be exact opposite sides of engine attached to a silver metal area. Tough to get my hands down by the radiator area to plug them in but got them snapped in. I never had to undo the 2 bolts in your instructions for the power steering reservoir to slide it out of the way. Heck i couldn't even find it on my engine
I did install the air box and sensors BEFORE starting the engine. I put it completely back before starting. I just hate to remove everything again but it looks like I may. If i do im going to send it back to Racechip...just not worth the hassle I am having for the few extra HP. Error occurs on startup all the time now, even with dummy plug in. I drove the car for an hour last night. Cant tell any issues with the error as the car runs normal.
2016 BMW X5 xDrive 50i White 2017 Porsche Carrera 911 S White |
r33_RGSport12976.50 |
03-04-2018, 10:03 AM | #10 | |
508
Rep 648
Drives: 2016 F15, 2015 F83
lilthrift do you have access to a code reader to read the pending/stored codes? Also, instead of using the dummy plug, try reverting to the stock wiring and see if that clears it up. If it does, it may be the harness.
2016 F15 X5 50i M-Sport
2015 F83 M4 |
03-04-2018, 10:17 AM | #11 |
936
Rep 1,180
Seems to be a few posts about the drivetrain malfunction with RaceChip lately. Is there a mod that can merge the threads or posts?
Might be good for the folks that are having this issue have one thread to troubleshoot from.
2018 X5 35i M-Sport
Dinan Stage 1 Tuner M-Perf Exhaust and lip Wheels: Winter - 469m; Summer - Vossen CV7 22s 2018 X1 28i M-Sport |
03-04-2018, 10:38 AM | #12 | |
12977
Rep 18,721
Try to reset it while using the dummy plug and see if it comes back.
03-04-2018, 11:07 AM | #13 |
17
Rep 52
Forgive my ignorance but how do you reset it?
03-04-2018, 11:11 AM | #14 | |
17
Rep 52
03-04-2018, 11:18 AM | #16 |
698
Rep 1,092
I saw a post before about the op let the indy mechanic to install Racechip for 50I and got error code. He insist that the mechanic have experience and should not install it wrongly. But in fact, the mechanic did installed it into the wrong connector. Later on, he uninstall everything and connect it to difference connentor. Wow , it work with no code. Maybe you can search other post to see what he did.
03-04-2018, 11:39 AM | #17 | ||
12977
Rep 18,721
Any OBD2 scanner should be able to read and clear.
03-04-2018, 02:13 PM | #18 |
17
Rep 52
Ok I removed the Racechip harness and reconnected everything back correctly and I still have the drivetrain error. Unless it goes away tomorrow i will get an apt with the dealership.
I am sending the Racechip back for a refund. Thanks for all the help in this forum but just too many unknowns and i am tired of removing/reinstalling everything
03-04-2018, 02:24 PM | #19 | |
2114
Rep 2,388
03-04-2018, 02:29 PM | #20 |
508
Rep 648
According to their website, yes it will. I do not have an iPhone (and bimmerlink looks like it's for iOS only) so I can't help you with that app. I use Dash Command. Super easy. Once you connect it to your OBD reader, you simply press diagnostics then read codes. Simple as that. I assume bimmerlink is just as easy.
2015 F83 M4 |
03-04-2018, 02:37 PM | #21 |
17
Rep 52
The problem I have using the Bimmerlink app is its mostly German and I dont know what I am selecting
03-04-2018, 02:57 PM | #22 | |
684
Rep 1,434
2022 x5 m50i - Dravit grey
2005 evo 8 (current) built 2.3 488/409 mustang dyno Old stable mates - 87 325i, 88 m3, 90 m3, 97 m3 4dr, 04 325xi, 91 gmc Syclone, 08 335xi, and 13 x3 35i msp 2014 x5 50i msport |
