XBimmers X1   XBimmers X1
  XBimmers X1
Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > General BMW X1 (E84) Forum
      02-28-2018, 07:52 AM   #1
2quik
Drives: 2015 X1 Xdrive 28i
Annoying rattle at start up
During my quest to purchase a 2015 X1 xdrive 28i, I noticed that everyone I started had a rattle on start up that disappeared. It sounded like a heatshield or catalytic cover rattling. The car I purchased also does it and I am wondering is this unique to all the 2015's?
      02-28-2018, 08:11 AM   #2
kiloTHREE
76
Drives: '13 xDrive28i
It's the linkage for the wastegate.
Number 2 in the picture.
All of the 28i's do it till it warms up, some worse than others.
Originally Posted by PrematureApex View Post
What a jackass...
      02-28-2018, 08:41 AM   #3
2quik
Thanks for your quick reply and feedback.
      02-28-2018, 09:25 AM   #4
interceptor428
29
Drives: 2013 x1 28i/2015 428 m sport
Check your muffler..the exhaust flag mechanism can cause a rattle too. I "cheated" this by zip tying the vacuum line to the flapper mechanism..no more rattle. Stick your head out the door while starting and see if the rattle comes from the rear or under the engine
      03-19-2018, 10:25 AM   #5
SharpAndCunning
100
Drives: 2014 X1 35i
my 2014 x1 35i does this. It seem to go away after the car has been running for a couple of minutes. MY local dealer told me it was wastegate rattle and many many cars do it. It's annoying.
One of the many reasons I'm starting to think this car was a bad idea.
      03-19-2018, 10:44 AM   #6
kiloTHREE
76
Just a heads up, I may have found a permanent and cheap fix.
I'll let ya'll know after I test it for a month.
What a jackass...
      03-19-2018, 10:16 PM   #7
SharpAndCunning
100
Drives: 2014 X1 35i
Test it for a month? Can you give us some more infomation. What do you think causes the rattle?
      03-20-2018, 06:29 AM   #8
2quik
@interceptor428
The rattle, as you mentioned, is definitely coming from my exhaust. Can you please be more specific as to what the exhaust flap mechanism is and where is the vacuum line that I should zip tie.
Thanks in advance
      03-20-2018, 08:45 AM   #9
kiloTHREE
76
Already posted one of the common rattles above. So far my fix is working but they usually don't last. So far so good on mine.
Thanks in advance
That actuator just to the bottom left of #8 in the picture.
Google "golf tee mod"
What a jackass...
      03-20-2018, 11:14 AM   #10
interceptor428
29
@interceptor428
Thanks in advance
If you look on the driver side of the trunk area, there is a tray..pull-up on that tray and you will see a valve with vacuum lines. Once you see it you will understand what to do.
      03-22-2018, 11:48 AM   #11
SharpAndCunning
100
Drives: 2014 X1 35i
This only fixes the rattle if it's from the exhaust flap. If the rattle is coming from the front of the car, and is indeed the wastegate linkage, we need to know what KILOTHREE's fix is.
I'm super upset that BMW can't figure this out. 2 dealers, and both say it's normal. This car was 50k new, and it's still under warranty, I shouldn't have a rattle that sounds like nails in a tin can when I start it up.
      03-22-2018, 03:16 PM   #12
kiloTHREE
76
Don't get excited, I've "fixed" this three times before... heat mitigation for my solutions seem to be the problem.
So far I've tried:
High temp silicon - failed
aluminum spacers - failed
silicon mat - failed
Now I'm on to a carbon/graphite felt washer...
What a jackass...
      03-23-2018, 03:35 PM   #13
SharpAndCunning
100
Drives: 2014 X1 35i
So far I've tried:
Interesting. What about those puck's you can put to seal exhaust leaks. They are similar to what you're talking about, but solid. You can make waskers out of them with a hole saw. Where are you putting these solutions. What is actually rattling. The linkage?
      04-02-2018, 07:36 AM   #14
SharpAndCunning
100
Drives: 2014 X1 35i
KiloThree,
Just checking in. Waiting for a write up or explanation. I started my car in front of a client today, and he asked me if my car was "okay".
He's from the parent company in Germany, and BMW's over there "don't rattle".
xbimmers
