BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
EXXEL Distributions
      06-03-2008, 07:03 PM   #1
SlammedR8
SlammedR8's Avatar
521
Drives: 2019 X5 40i/2020 R8 V10 Spyder
Lowering E92 vs Lowering E93
Is it any different?
I was told that the E93 (cab) will need different lowering springs then the E92because of the added weight from the hardtop convertible?
Is this true?
If so, the way I see it is - it just might sit a little lower then it should because its not meant for the added weight which is fine by me. as the H&R only gives .6 in the back, but the RD Springs give 1 full inch in the back. So maybe it would just be more similiar to the RD Springs ?
Any insight?
      06-03-2008, 09:54 PM   #2
JMD0977
JMD0977's Avatar
69
Drives: 2010 GT3 and ....
I thought about the same thing being the I have an E93 on order also
      06-03-2008, 10:54 PM   #3
SlammedR8
SlammedR8's Avatar
521
Well anyone?
      06-04-2008, 08:00 AM   #4
08M3
MY 4TH M
08M3's Avatar
Drives: 08M3 AW
it is different.
the spring rates are different because of the weight. It's not that it would sit lower but the control/stability would be lost. For example when driving 100 k down the 401 and hitting a dip in the road the spring rate factors in the cars weight for suspension travel and suspension compression, under hard load this will prevent the shock from bottoming out or car from hitting the bump stops. if the weight of the car is too much for the spring or the spring is not correct when hitting a dip in the road or corning hard you will have a soft feel or a bouncy feel that would/could cause a car control issue, the car would propably feel crappy. I would wait for the right springs to be made.
      06-04-2008, 08:13 AM   #5
SlammedR8
SlammedR8's Avatar
521
You have a point. but consider this.. I usually drive alone or with a passenger next to me. But I rarely take passengers in the back, but say I have 2 of my buddies who are 200 lbs each in the back of the car...thats an extra 400 lbs (similiar to the added weight of the convertible). so will that make my car not handle right etc...
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      06-04-2008, 08:38 AM   #6
08M3
MY 4TH M
08M3's Avatar
Drives: 08M3 AW
It most definitely will, the extra 400 lbs in the rear will not only cause the rear to sag and suspension travel to be limited but cause excessive tire wear. You can have 400lbs of extra weight in passangers but it's also not going to be permanent.
If you think about a race car when weight gets added it get put in spots that make the car handle better not just dumped in the rear.
also think about it this way, a tennis ball will bounce when round and in normal form but if you squish the ball and take the rebound out of it it will no longer bounce it will just drop. That's what you would be doing would be taking the bounce out of the spring causing the rebound and compession to be different and the suspension would now be able to bottom out.
it might look o.k. when not driving and parked but when driving it wouldn't feel right nor look right.
      06-08-2008, 09:24 PM   #7
JMD0977
JMD0977's Avatar
69
Any word when will a suspension system come the E93?Is there on out yet?
      06-08-2008, 10:25 PM   #8
SlammedR8
SlammedR8's Avatar
521
nope
and my E93 will be here in a week, so I think I will order the H&R Sports and see how that goes...I can't drive it at stock height for very long!
Current:
      06-09-2008, 09:04 PM   #9
JMD0977
JMD0977's Avatar
69
Do you guys think these KW Variant 3 Coilover System for the BMW E90 & E92 M3 or the Bilstein B16 Electronic Ride Control Coilovers - BMW E90-E92 work on my E93 M3?
      06-10-2008, 12:13 AM   #10
SlammedR8
SlammedR8's Avatar
521
Most likely yes, but I don't want to lose EDC!
AND not because EDC is better then Full coilovers, but because I already paid extra $2000 in the car to have EDC, i dont want to lose it!
Current:
      06-10-2008, 08:05 PM   #11
JMD0977
JMD0977's Avatar
69
If anybody finds ANYTHING that works with EDC LET ME KNOW
      06-10-2008, 08:23 PM   #12
SlammedR8
SlammedR8's Avatar
521
fuck this, im ordering h&r sport springs.
Current:
      06-10-2008, 08:33 PM   #13
!Xoible
837
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
yes it is different. hit up longtran for questions he lowered most of E93's in socal
      06-10-2008, 11:18 PM   #14
SlammedR8
SlammedR8's Avatar
521
I did that..and here is his reply on this topic.
Originally Posted by longtran
i bet the difference wont even be noticeable. its like driving an extra passenger with you at all times. i've used the e90 springs on the e92 before the springs came out for the e92 and it was fine. alot of the people use e90 coilover forr e92 and no one really notice the difference.
So I will be the first... I will order the E92 M3 Springs from H&R for my E93. I will let you know how it goes
Current:
      06-13-2008, 04:27 PM   #15
Blip Bavarian
salivator
Blip Bavarian's Avatar
38
Drives: 16 GT4, 14 X5 V8 & 91 E30 LS1
if you are going to make the compromise, shouldnt you get the e90 springs for the e93?
      06-13-2008, 04:33 PM   #16
SlammedR8
SlammedR8's Avatar
521
Why ?
Current:
      06-13-2008, 07:55 PM   #17
JMD0977
JMD0977's Avatar
69
I heard people just using springs and f*cking up the EDC.I'm just going to wait,my car still not here,I should pick it up by the second week of July,hopefully there will be something out by then but I doubt it
      06-13-2008, 08:35 PM   #18
SlammedR8
SlammedR8's Avatar
521
Thats the first I've heard this... My buddy has an E60 M5, lowered for almost 3 years now and no issues with his EDC whatsoever.
And I asked my service guy and he said warrany wont be effected by the springs either!
I got my H&R Springs coming tomorrow, thanks to EDELWEISS - good man for hooking up the springs (which are on back order everywhere it seems)
thanks again
Current:
      07-03-2008, 01:00 PM   #19
JMD0977
JMD0977's Avatar
69
thanks again
Any pictures yet?
      07-03-2008, 01:30 PM   #20
SlammedR8
SlammedR8's Avatar
521
will post in the next few days
lots of new mods on my E93.
Current:
      12-05-2016, 02:22 PM   #21
Nsex1991
Drives: 2011 e93 /m3
update please?
      12-05-2016, 05:37 PM   #22
SlammedR8
SlammedR8's Avatar
521
Originally Posted by Nsex1991 View Post
update please?
WOW!
This thread is 8+ years old!
I haven't had my E93 M3 since 2010. That said, the E92 springs worked just fine, it was slightly lower in the rear but it looked awesome IMO!
Current:
m3post
