02-10-2018, 09:10 PM | #1 |
37
Rep 117
Driver Side *Buzzing* Sound
Hi all!
Is anyone experiencing the driver side buzzing noises? It's not always present which makes harder for me to locate where the noise is coming from.. It usually triggers whenever i drive over uneven pavements.. like raw asphalts. (ex) bridge can be one of good examples. The buzzing noise is definitely coming from my left ear but I really can't tell where it's coming from.. so FKing ANNOYING!! I removed the driver side air vents as i thought it was the one but I failed it. Any thoughts or ideas??? I'm thinking about removing the door panel next but i really don't know how to. LOL Please anyone advise!! Thanks |
02-11-2018, 12:17 AM | #2 |
7559
Rep 5,056
Mine is more of a squeaking/creaking noise. Many people have solved their issues by lubricating the door seals and applying teflon tape along the shadow line trim. My creaking seems to be coming from somewhere in the window seal because my noise goes away completely when the windows are down.
02-11-2018, 03:58 AM | #3 |
227
Rep 269
My noises are 1) the buzzing from centre console where the wireless charger is. 2) the high pitched varying tone which I believe is an ASD fault so i'll disconnect/code out the active sound, oh and theres definitely an intermittent whining sound when the wife sits next to me and I put my foot down.
M4 AY 2016
M4 SMB 2017 M4 Riviera Blue with CCB's 2018 |
02-11-2018, 05:26 AM | #4 |
407
Rep 559
finally figured out what mine is
quite literally was coming on to start my own post to see if others had my issue because i finally narrowed it down. the HUD "tray" if you will is loose and it rattle/buzzes over uneven pavement or acceleration. if you even just put your finger lightly on it during the noise, it stops immediately. lift your finger off and it returns instantly.
that said - has anyone else had this buzz/rattle and if so, how did you get it fixed? |
02-11-2018, 06:33 AM | #5 |
81
Rep 169
My buzzing noise was coming from the door latch button, mostly on the right door. Try locking and unlocking the door when driving over a rough road. If the buzzing goes away when unlocked the dealer can fix for free if still covered under warranty.
02-11-2018, 06:38 AM | #6 | |
Lurker
148
Rep 97
02-11-2018, 09:14 AM | #7 | |
83
Rep 64
M4_CaptFlashheart227.00 |
02-11-2018, 10:47 AM | #9 |
81
Rep 169
I had the buzz fixed in the right door, now there is not a buzz or rattle anywhere, 50,000 miles. No shame from me, very happy camper.
02-11-2018, 02:05 PM | #10 | |
37
Rep 117
zamboni1132.00 |
02-11-2018, 02:07 PM | #11 |
37
Rep 117
Done it. but no luck. noise seems coming from the front area. i dont think its the HUD though...
02-11-2018, 02:09 PM | #12 | |
37
Rep 117
02-11-2018, 02:25 PM | #13 | ||
7559
Rep 5,056
02-11-2018, 02:32 PM | #14 |
Rep 7
I get a buzzing sound from the accent lighting under the trim on the drivers door. It sounds similar to what the OP is describing and happens when I drive on rough pavement. Super annoying. If that is what your buzzing sound is, you can wedge a plastic collar stay from a mens shirt between the trim and light.
05-24-2018, 10:51 PM | #16 |
I want to drive a Zamboni
1132
Rep 5,558
Drives: 13 E93 M3 18 F80 M3 16 K71
What was the repair to make the rattle going away?
18 F80 Imola Red 6MT
16 K71 F800GT Montego Blue 13 E93 M3 Melbourne Red 2000 E46,2006 E90,09 E82,13 E93 328i,14 F30 335i,18 F80 M3 My next vehicle would be a Zamboni |
05-25-2018, 06:43 AM | #18 |
2543
Rep 3,968
My rear shade buzzes like crazy when down. Worthless feature....
2011 1M, Black loaded sans sat radio
2021 911 C4S Gentian Blue, manual 2023 X3 M40i - loaded sans Park Assist |
05-25-2018, 07:19 AM | #19 |
50
Rep 100
09-14-2018, 10:14 AM | #20 |
1618
Rep 2,161
In case anyone else is dealing with this, I recently discovered that my rear driver door tweeter grille was causing a buzzing rattle on rough roads or under acceleration. This had been going on for months and is now FIXED using just some 1mm felt tape cut into 5 very thin strips and applied to the underside edge of the grille itself (between the clips which hold it to the door card/tweeter assembly).
