01-24-2018, 04:50 PM | #1 |
24
Rep 86
where does this go?
OK - this is a tough one and I will be amazed and impressed if somebody comes up with the answer.
This little piece of rubber was sitting right next to the rad when I opened the hood on my 128i. It is small only 1 inch in length. I scoured RealOEM but could not find it. Anybody know where it goes? |
01-24-2018, 05:00 PM | #2 |
European Editor
10594
Rep 22,992
It goes on the inside edge of your hood. They are rubber bump stops to prevent metal on metal contact. The little one(2nd pic) goes up front about six inches from the front of the hood. The other one sits further down closer to the driver - also on the edge of the hood.
see #9... http://www.realoem.com/bmw/enUS/show...diagId=41_1611 Dackel
elitesales305383.00 Esteban43987.00 PDXE82122.50 1and11858.00 Matticus913475.50 BimmerAg425.00 shawnyeeah20.00 Bimmer TV125.00 |
01-24-2018, 05:53 PM | #3 |
43987
Rep 7,224
Just checked under my hood and I only have one so I ordered a few of them so I would have some extra because they'll probably fall off again. lol
Thanks for P/N Dackelone.
01-24-2018, 07:39 PM | #5 |
123
Rep 123
I'll be damned. I think you may have just found my random vibration/rattle over rough pavement in the engine compartment. Went out to check and I'm missing that bumper on the drivers side. Thanks Dackel!
01-24-2018, 07:40 PM | #6 |
123
Rep 123
01-25-2018, 08:59 AM | #7 |
3476
Rep 3,722
Dackelone coming in for the rescue damn that was fast haha
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
01-25-2018, 11:33 AM | #8 |
24
Rep 86
You know at first I was reluctant to post this up. I thought no one will know what this part is and no one will care.
Boy was I wrong...Dackelone responded with 10 minutes! Not only did this help me out but may have solved a problem for PDXE82. This just goes to show the value of this forum and I really appreciate the support. I just ordered 4 of the little buggers from ECS, they are $1.21 each. It gives me great pleasure to fix little things like this on my car! |
01-25-2018, 12:49 PM | #10 |
24
Rep 86
Can anyone confirm exactly where they go and which direction?
There is a spot where the lip/seam splits into two and it seems like it should go there? Does the longer side with the two flaps go on the inside? Thanks! |
01-26-2018, 06:09 PM | #11 | |
European Editor
10594
Rep 22,992
I will take some pics of my hood tomorrow. Dackel
Bimmer TV125.00 |
01-26-2018, 06:16 PM | #12 |
43987
Rep 7,224
Looking forward to the pics Dack because I'm not sure exactly how they go on and where either. lol
01-27-2018, 12:06 PM | #14 |
24
Rep 86
Sorry for the confusion - the pictures are of the same grommet, just different angles.
01-27-2018, 12:11 PM | #15 | |
24
Rep 86
Thanks in advance for your help! |
01-27-2018, 12:45 PM | #16 | |
379
Rep 317
The rubber bumper is placed with the "thicker" side into the cavity so it gets lodged in there safely. If you then slide it towards the back as far as it goes it seems to secure it in place a bit better. I also need a manicure, it seems Last edited by vinylengraver; 01-27-2018 at 01:03 PM.. |
01-28-2018, 05:53 PM | #18 |
European Editor
10594
Rep 22,992
rubber hood bump stops...
onenutt
vinylengraver YearOneOne Esteban Matticus91 PDXE82 Ok guys, I remembered to take pics of my under hood rubber bump stops today. I don't know what I was thinking but there are only ONE rubber stops, one at each front part of the hood edge. Not two on each side - as I originally posted. Here are my pics... Let me know IF there are questions. Dackel
01-28-2018, 06:48 PM | #20 | |
European Editor
10594
Rep 22,992
I guess tomorrow I will have to look at the left(passenger) side one and see. Dack
Bimmer TV125.00 |
01-28-2018, 07:11 PM | #21 |
379
Rep 317
I'm pretty sure mine are installed correctly...
Another picture found on this forum confirms that (disregard the circle around the latch but note the position/orientation of the rubber bumpers.) |
