12-28-2017, 03:14 PM | #1 |
Rep 4
2010 128i Eccentric Shaft Sensor - Replacement
Took my car (2010 128i, 55k miles) in to reputable shop with a 'Service Engine Light' on.
Had previously taken it to have the OBD read elsewhere, and it came back with codes for the Eccentric Shaft Sensor. The shop i took it to confirms, and to replace it, Valve Cover, and Valve Cover Gasket, they want approximately $1,000 in parts and $700 in Labor. Does that sound about right to everyone? TiA |
12-28-2017, 06:14 PM | #2 |
78
Rep 237
200 for the part (500 for Genuine BMW) , and 70 for the gaskets. No. I have no idea what shop rates are, but it should probably be about 5 hours or so. I did mine in seven, but I did a few other things while I was in there, and killed many, many beers.
Look at FCP euro for lifetime warranty OE replacement parts. |
12-28-2017, 10:57 PM | #3 |
King of Goodness
152
Rep 185
Drives: 2012 128i Coupe
Is this part generally prone to failure, and why would you need to replace the valve cover?
12-29-2017, 02:00 AM | #4 | |
701
Rep 3,268
Drives: 2010 128i
The plastic valve covers have been known to crack as well, although it is not nearly as common (as far as I can tell, keeping up with these boards) as the eccentric shaft seal. I replaced the eccentric shaft sensor on my 2010 (with slightly fewer miles than the OP's) this past summer. You can save a lot of money doing the job yourself, both on parts and (obviously) labor. It's not a small job and requires a good assortment of tools, but it can be done. My original valve cover was fine.
____________________________ |
12-29-2017, 01:20 PM | #5 | |
King of Goodness
152
Rep 185
