12-27-2017, 12:10 PM | #1 |
Boost
66
Rep 108
2015 M3 F80 Sedan Dinan Signature 2
https://phoenix.craigslist.org/cph/cto/6439081096.html Mileage: ~24,500 Drive around in style in this Alpine White BMW M3 complete with the full complement of Dinan performance products and even some that never made it to market. The car exudes style and sophistication with its timeless Vorsteiner 19" forged wheels and aggressive stance courtesy of a moderate drop and carbon fiber front lip. You are sure to turn heads wherever you take this subdued but show stopping presentation of BMW class and sophistication. This already well equipped M3 has been massaged into a performance monster with various engine and suspension enhancing modifications. These additions equate to a vehicle delivering 548 HP and 549 lb-ft of torque onto the pavement with the nimbleness and traction you would expect from a track car while not sacrificing the comfort of a daily driver. Performance and looks are not the only stunning aspect of this DCT transmission equipped delight as the black Merino leather lined interior is also pristine and symbolic of its sleek performance and sophistication. This total package means that not only can you enjoy your vehicle more than the standard model but you can look good and be comfortable doing it as well. BMW Options ($10,175 value) • Executive Package - Heated steering wheel, comfort access, rear view camera, heads-up display and more. • Lighting Package - Adaptive LED lights and automatic high beams. • Other options - DCT, Navigation System and Enhanced Bluetooth. Handling Features & Upgrades ($9,874 value) • Dinan performance adjustable coil-over suspension system that lowers the ride for a more aggressive stance and improved handling capable of running on the street just as well as on the track. • Dinan High Performance Adjustable Coil-Over Suspension System. For the driver that demands the best out of their vehicle. The Dinan Adjustable Coil-Over Suspension was bred in the race lab but refined on the street for maximum versatility. • Dinan lightweight tubular and adjustable sway bar set designed to minimize body roll and inspire confidence going into any corner. • Dinan rear suspension link kit adds precision and predictability at the limit by reducing flex in the rear toe links that cause the car to be unstable (tail happy). • Dinan tension strut ball joint kit provides responsiveness you can feel by replacing the rubber bushings in the thrust arms with precision ball joints and machines aluminum housings. Performance Features & Upgrades ($9,269 value) • Stage 3 DINANTRONICS engine hardware/software that optimizes boost pressure, fuel mixture, and ignition timing resulting in increased engine power. • Dinan performance exhaust and x-pipe adds power and gives the M3 a deeper, throatier sound with no cabin drone. • Dinan carbon fiber intake system that feeds more air into enlarged filter housings ensuring the engine gets the maximum amount of breathable air. • Dinan high performance heat exchanger utilizes a larger design that elicits impressive power gains and a wider power band along with astounding cooling characteristics that nearly guarantee 'heat soak' is a thing of the past. Accessories ($8,236 value) • 19" flow-forged V-FF 106 carbon graphic wheel set for ultimate handling and performance coupled with a classic look. 19" x 9.5" in the front with 275/30-19 and 19" x 10.5" in the rear with 305/30-19 Tokohama Advan Neova AD08 R tires. • BMW M Performance carbon fiber front splitter. • BMW M Performance carbon fiber rear diffuser. • BMW M Performance carbon fiber spoiler. • BMW M Performance carbon fiber mirror caps. • BMW M Performance black kidney grilles. • BMW M Performance flat bottom alcantara steering wheel • Dinan aluminum pedal pad set.
2015 M3 DCT | Dinan Stage 3 Intake, Exhaust, Anti-roll, Mid-pipe, links, Heat Exchanger, Pedals, Coil-overs | Vorsteiner 106 CG 19-10.5 | Yokohama AD08R 305/30ZR19 | Aspen White/Black | M Flat Bottom Steering Wheel, CF Spoiler, Diffuser, Splitter Mirrors and Black Kidney Grills Last edited by C_Treadwell; 01-17-2018 at 02:15 PM.. |
12-27-2017, 01:44 PM | #2 |
2316
Rep 12,654
GLWS buddy.
C_Treadwell66.00 |
01-12-2018, 08:41 AM | #5 |
Boost
66
Rep 108
2015 M3 DCT | Dinan Stage 3 Intake, Exhaust, Anti-roll, Mid-pipe, links, Heat Exchanger, Pedals, Coil-overs | Vorsteiner 106 CG 19-10.5 | Yokohama AD08R 305/30ZR19 | Aspen White/Black | M Flat Bottom Steering Wheel, CF Spoiler, Diffuser, Splitter Mirrors and Black Kidney Grills |
