12-24-2017, 11:01 AM | #1 |
3477
Rep 3,722
Thoughts on clutch replacement - w or w/o Flywheel?
Less a question about what clutch kit to get, and more about the flywheel. I don't really want to move away from the DMFW (dual-mass flywheel for anyone new) so if it's necessary I'll be getting a new one instead of moving to a SMFW (single-mass flywheel) to avoid the extra costs.
My primary question is; has anyone resurfaced their lower-mileage DMFW instead of replacing it while installing a new clutch? My clutch is still holding strong and the car only has about 70k on it but I'd really like to pop a new (higher-rated) one in there within the next year or so. I'm aware of the pros/cons for DMFW vs SMFW so I'll list them for anyone searching. DMFW:
SMFW:
"Tobias" 2013 135i ///M-Sport 6MT • Pure Stage 1 • XDI 35 HPFP • 404whp/440wtq |
12-24-2017, 11:29 AM | #2 |
1302
Rep 2,093
Drives: '11 135i M Sport
Unsure if it would fit the N55 but you could look into the possibility of using the 1Ms lighter flywheel.
It "may" fit since the 1M uses the same manual transmission from the N55 era cars.
12-24-2017, 12:13 PM | #3 |
E82 Mudflap Ambassador
2214
Rep 2,219
Drives: '08 128i
You know this forum just as well as I, and we're all big proponents of "WHILE YOU'RE IN THERE!!!"
That said, this is a pretty expensive one. You really gotta ask yourself: Is this my sports car, or my sporty daily? I've heard the single mass in person, and I wouldn't be able to live with it. There's a nice rattle at a dead stop when you're idling with the AC on (and being in metropolitan Florida that will be frequent for me.) My 2c
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
12-25-2017, 10:28 AM | #4 |
215
Rep 988
I would change the fw. It is not mating the surface to the new clutch to be worried about, its the springs and hardware inside the DMFW that wear.
MHD | BMS | VRSF | APEX | RECARO | TC Kline | BERK | Turner Motorsport | Eibach | BMW Performance
12-25-2017, 10:37 AM | #6 | |
1302
Rep 2,093
* unsure if it'll work for S55 to Manual
12-25-2017, 12:04 PM | #7 | |
2315
Rep 4,341
If not consider lightening stock dual mass. Find shop that can clean surface of existing one and lighten a bit. You can take pictures of 1M flywheel to see where they took metal off. |
12-25-2017, 07:06 PM | #8 |
211
Rep 893
The DMFW in my car makes a constant grumbling noise... sort of like marbles rattling around in a coffee can while the whole thing is smothered in a pillow (this has been discussed in other threads and IIRC others experience the same thing). And the clutch chatters like crazy when hot (I've been driving stick for over 40 years and I cannot get a smooth take-up when it's hot). I expect the thing to explode one of these days. Worst thing about this(my) car.
2011 135i MSport 6MT AW/black, 72Kmiles, bone stock, moneymoneymoneymoneymoneymoneymoneymoneymoneymoney I LOVE THIS CAR
12-27-2017, 09:13 AM | #9 | |
3477
Rep 3,722
Thanks for the input guys, unfortunately the 1M flywheel will not fit n55 transmissions. I'm probably going to go with the 5-series IS kit (direct bolt-in) and see how it goes. I've heard good things and it's all OE BMW equipment so it's matching quality with a higher torque rating. And, it's a little cheaper, because BMW makes more 5's than 1's
Bimmer TV125.00 |
12-27-2017, 09:51 AM | #10 | |
4338
Rep 6,196
Good call with the 550 clutch. Will be my replacement if my clutch ever wears out. |
12-27-2017, 01:00 PM | #11 | |
125
Rep 750
Drives: '98 Z3M (gone), '09 135i
i went with the 550i clutch kit and a Luk flywheel, dont regret it |
12-28-2017, 09:14 AM | #13 | ||
3477
Rep 3,722
Failing flywheel is usually clutch slip at full release, vibrations in the shift lever, chatter, etc... Not too different from clutch failure symptoms. Rattles at idle are actually somewhat common in these cars, especially if everything (AC/music/etc) is off and you're sitting in silence. Vibrations/noise at any speed are not common however
Bimmer TV125.00 |
Tags |
clutch, flywheel, replacement |
